Running games on BeebEM
AJH
!BOOT
Postby AJH » Sun Jan 04, 2004 5:48 pm
Shift F12 does the same as pressing Break<br>
and then typing *EXEC !BOOT<br>
so you should be able to type *EXEC !BOOT manually<br>
to run a disk image. <p></p><i></i>
andykempson
beeb-em
Postby andykempson » Thu Jan 08, 2004 4:35 pm
Excellent. Thanks very much <p></p><i></i>
sith
Re: beeb-em
Postby sith » Sat Jan 31, 2004 10:11 am
Can you guys help me set up my emulators?<br>
I've done a topic in the problems section if you wouldnt mind looking? <p></p><i></i>
andykempson
Postby andykempson » Fri Mar 12, 2004 3:15 pm
I have a problem running some games.<br>
<br>
I cannot use the !BOOT function to start games using shift + f12, as when I press this, the emulator closes.<br>
I can only run games by typing *RUN <filename>, and sometimes this doesn't work either.<br>
<br>
Can anyone help? <p></p><i></i>
Return to “problems”
