The Sting
The Sting
Postby Jeremy Grayson » Thu May 16, 2002 4:05 pm
'Evening!<br>
<br>
I loved Gemini Software's bear-a-thon The Sting first time around but am having no joy at all with the version on 'ere. Loading is interrupted partway through - after STING2 is loaded, I think - to tell me a file has not been found at line whatever. LISTing the given line shows that the filename "STING3" has been entered as <br>
"STING 3", with a gap. However, whilst ridding the filename of the offending gap allows the game to load at last, the whole thing crashes after the first sheet has been cleared, leaving you with a black screen depicting the key moves you'd made on that sheet, ie ZXZX*?*XZX?*ZZZX? etc. and an error! Are the two problems related? Why should one character space make such a difference if so? Help! I've got bears to rescue!!<br>
<br>
(NB In responding, please bear in mind that I'm using a real program on a real disc on a real Beeb here (rather than an emulator), and that my ignorance of machine codes, routines, call addresses, etc. is nigh on absolute!)<br>
<br>
Cheers in advance,<br>
<br>
Jeremy<br>
<p></p><i></i>
Return to “problems”
