Stryker's Run
bob
Stryker's Run
Postby bob » Wed Feb 20, 2002 2:23 pm
I have a problem running Stryker's Run. It begins to load only to absolutly freeze at the point :<br>
<br>
"loading<br>
Stryker2 03 0301"<br>
<br>
Anybody have this problem too? Or even know how to rectify this problem? I'd appreciate some help thanks. <p></p><i></i>
Postby Arcadian » Wed Feb 27, 2002 11:43 pm
Which version - BBC or Electron?<br>
Which format - Tape Image or Disk Image?<br>
Which emulator? <p></p><i></i>
fuzzle
Stryker's Run
Postby fuzzle » Sat Mar 16, 2002 11:47 am
Anyone know how to get the master version of<br>
Stryker's run to work? My version just crashes when<br>
trying to load the data files into sideways ram<br>
I'm using beebem v1.4.<br>
It would help if you could specify which version of the<br>
zip file works and which dfs to use.<br>
<br>
<br>
<p></p><i></i>
Re: Stryker's Run
Postby Arcadian » Sat Mar 16, 2002 5:20 pm
The verson in the BBC Disk Image Archive should work ok. <br>
<br>
Just use the DFS that is automatically initialised when you switch to Master 128 mode (v2.24, I think). <p></p><i></i>
Return to “problems”
