BeebEm version 1.6
the place for discussing bbc micro & electron software, emulators, hardware and other issues
MikeWyatt22
BeebEm version 1.6
Postby MikeWyatt22 » Sat Oct 16, 2004 8:51 pm
You wait years for a new version of BeebEm then two come along at once! Version 1.6 is on my web site:<br>
<br>
<!--EZCODE AUTOLINK START--><a href="http://www.mikebuk.dsl.pipex.com/beebem/index.html">www.mikebuk.dsl.pipex.com...index.html</a><!--EZCODE AUTOLINK END--><br>
<br>
Thanks go to Ken Lowe for the IntegraB and B Plus support. The other changes are mainly bug fixes.<br>
<br>
Also check out OddJob - I previously unreleased game!<br>
<br>
Mike<br>
<p></p><i></i>
tartartar
B+ support (some problems with configuration)
Postby tartartar » Sat Oct 16, 2004 9:49 pm
You beauty Mike! I've been looking for "64K B Plus" support in BeebEm for aaggggggeesss! Thanks very much.<br>
<br>
A problem I've seen is that there is no easy way to select between a B+64 and a B+128 through the GUI. And there are issues with the Roms.cfg file. It is strange that by default there are 4 sideways RAM pages listed in the B+ configuration section, and yet choosing the B+ through the GUI only reads "Acorn OS 64K". I think this may be to do with using the Watford 1.44 DFS, because when I edit the roms.cfg to specify the Acorn 1770 DFS (version 2.26), suddenly the 4 RAM pages are recognised and the boot up reads "Acorn OS 128K".<br>
Any idea what the problem is here?<br>
<br>
Another problem is that I couldn't select the 1770 DFS through the GUI for the B+ (which would be it's natural filing system). Instead I had to edit the Roms.cfg file and replace in the BPlus section 'WDFS.ROM" with "DFS-2.26.ROM".<br>
<br>
And it would be great if the configuration of the roms.cfg through the emulator GUI options worked 100% too.<br>
<br>
Just an FYI:<br>
Another thing I did notice with "B-Em" and "Model-B" (the other prominent beeb emulators, it that they DON'T accurately emulate the model B+. I'm gonna play around with your B+ support in BeebEm v1.6 to see if it's better than theirs!<br>
<br>
Cheers for the new version. It is very encouraging!<br>
<br>
p.s. maybe you should rename the title bar to read: BBC B/BBC B+ 64/Master 128 emulator! <!--EZCODE EMOTICON START ;) --><img src=http://www.ezboard.com/images/emoticons/wink.gif ALT=";)"><!--EZCODE EMOTICON END--> <br>
<br>
<p></p><i></i>
KenLowe
HowTo Switch B+ Modes
Postby KenLowe » Mon Oct 18, 2004 4:35 pm
Selecting between B+64 and B+128 can be done from the GUI. As can another couple of modes in between. It's a matter of knowing what to do <!--EZCODE EMOTICON START :) --><img src=http://www.ezboard.com/images/emoticons/smile.gif ALT=":)"><!--EZCODE EMOTICON END--> <br>
<br>
As you've already noticed, the B+ doesn't work particularly well with the Watford DFS. This isn't a problem with the emulator. It's just that the Watford DFS wasn't written with the B+ in mind.<br>
<br>
The best combination for the B+ is the Acorn 1770 DFS v2.26 (although I'm sure there are other DFSs out there which work correctly with the B+), and the Acorn 1770 floppy controller. To set this up correctly, you need to:<br>
<br>
1. change the DFS rom in the rom.cfg file (perhaps one day, you might be able to switch roms from the GUI instead of altering the roms.cfg file). <br>
<br>
2. select the Acorn1770.dll floppy controller from the Options/Model B Floppy Controller/Select FDC Board... menu in BeebEm.<br>
<br>
Once you've changed your configuration you should get the "Acorn OS 128K" prompt. If not - don't panic... In order to get the 128K prompt, you must 'Allow ROM Writes' to the rom banks 0, 1, C & D.<br>
<br>
If you disable ROM Writes to any of these banks, then the startup prompt will change accordingly. By selectively disabling 1, 2, 3 or all 4 of the rom banks, you can get the following startup prompts:<br>
<br>
"Acorn OS 128K" (with 0 ROM writes disabled)<br>
"Acorn OS 112K" (with 1 ROM write disabled)<br>
"Acorn OS 96K" (with 2 ROM writes disabled)<br>
"Acorn OS 80K" (with 3 ROM writes disabled)<br>
"Acorn OS 64K" (with 4 ROM writes disabled)<br>
<br>
Simple really <!--EZCODE EMOTICON START :) --><img src=http://www.ezboard.com/images/emoticons/smile.gif ALT=":)"><!--EZCODE EMOTICON END--> <br>
<br>
Ken. <p></p><i></i>
