It is currently Mon Oct 20, 2014 4:21 pm
 Page 1 of 1 [ 5 posts ]
Author Message
PostPosted: Sun Jun 24, 2012 2:46 pm
I'm pleased to have finished this conversion. =D>
Link to original is here
ozone1.png [7.25 KiB]
Downloaded 483 times
ozone3.png [11.29 KiB]
Ozone_B22.zip [27.52 KiB]
Downloaded 74 times
It has been tested extensively although its possible some bugs (either present in the original or in its conversion) are still present. However it is completable.
Includes the 'B source file too for the curious as to how it was done.
Enjoy. :)
_________________
Andy
Adventure games ported across to the BBC (in progress)
Offline
 Profile
PostPosted: Fri Jun 29, 2012 4:19 pm
Jeez! - third thing I typed and I get cut in half - tough game!
So how did you fit it into the Beeb's smaller memory?
-PJ
Offline
 Profile
PostPosted: Fri Jun 29, 2012 4:36 pm
-PJ
With difficulty ;) , No it was not that bad actually as you gain a little space with no pics, but not that much. Very time consuming though. :(
Fitted reasonably well, I think the B's compression is slightly better although the original was done with patch / press which do compress it a bit (makes disassembly sometimes not quite 100%)
Quick tip: Pick up the glasses, wear them and examine them (that will explain) and finally then examine the doorway. To get through the door without being chopped into half MAEB PMUJ (reversed to not spoil it any)
Say if you require a walkthrough / more hints etc. It is a tough one, probably more so that MicroMan and I think I preferred the original a bit more, perhaps because I played that a lot back then.
_________________
Andy
Offline
 Profile
PostPosted: Sat Jun 30, 2012 11:28 am
cheers Andy :D =D> :wink:
_________________
Offline
 Profile
PostPosted: Sat Jun 30, 2012 5:20 pm
You're welcome. :)
Please feel free to check out the other new releases too if you've not already.
I know some might say "bleh, adventure games" but ultimately it is *new* software for our platform... something that's a bit thin on the ground.
_________________
Andy
Offline
 Profile
Display posts from previous:  Sort by
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
phpBB skin developed by: John Olson
Powered by phpBB® Forum Software © phpBB Group
