Tape CSW files -not working on other sites
Re: Tape CSW files -not working on other sites
Postby CMcDougall » Tue Jun 02, 2015 10:16 pm
vanekp wrote:with these switches it makes a propper hq.uef
I tried that, still does not work, gets to block 2B, then Data? and crashes....
BUT, if you use BackToLife (.CSW to .WAV) I can confirm it loads back into a actual real beeb \:D/
as the original tape does not :lol: (sideB was closest to working :x )
vanekp
Postby vanekp » Fri Jun 05, 2015 7:17 pm
:lol: I got told how to do it by the expert years ago when he was running the acorn preservation site and I was doing conversions of the software I had at the time.
:wink:
Postby CMcDougall » Thu Jul 16, 2015 8:54 pm
Revs -Acornsoft 1985
(CSW of this in first post (pg1 top))
full manual scan here : http://www.mediafire.com/download/15b1p ... Revs01.zip
revsUEFhq.zip
UEFhq
(30.42 KiB) Downloaded 46 times
Revs 4Tracks -Acornsoft 1985
(CSW of this in first post (pg1 5th from top))
revs4TracksUEFhq.zip
UEFhq
(24.13 KiB) Downloaded 45 times
Fab Four Volume 1 -ASL 1989 : (CHAIN"" 1st game (S/P), *RUN (O/T) 2nd game)
sideA
FabFourVol1a-ASL1989-Sphere2 OmegaOrb.zip
CSW
(453.66 KiB) Downloaded 50 times
UEF
(41.93 KiB) Downloaded 44 times
sideB
FabFourVol1b-ASL1989-Psycastria2 Thunderstuck2.zip
CSW
(408.58 KiB) Downloaded 47 times
UEF
(40.2 KiB) Downloaded 43 times
Did not bother with a UEFhq of these, as no 'streams' or extra blank space between the files. Can make it, if requested.... Thanks to MatthewThompson for not throwing in the bin, & at me instead =D>
Disc version here: http://www.stairwaytohell.com/bbc/archi ... abFour.zip
Postby CMcDougall » Thu Mar 31, 2016 7:32 pm
Bullseye by TV Games / Domark / Central and previously released by Macsen:
inlay A and tape
inlay B
recorded same both sides 8mins 20secs, left channel strong, right useless
BullseyeA.zip
uef
(21.38 KiB) Downloaded 30 times
BullseyeAhq.zip
UEFhq
(22.07 KiB) Downloaded 26 times
BullseyeAcsw.zip
csw
(276.35 KiB) Downloaded 29 times
BullseyeB.zip
uef
(21.55 KiB) Downloaded 24 times
BullseyeBhq.zip
UEFhq
(22.25 KiB) Downloaded 25 times
BullseyeBcsw.zip
csw
(243.24 KiB) Downloaded 26 times
Postby lurkio » Thu Mar 31, 2016 7:54 pm
CMcDougall wrote:Bullseye by TV Games / Domark / Central and previously released by Macsen:
Great! Smashing! Super!
(Sorry.)
Postby CMcDougall » Thu Jun 30, 2016 10:09 pm
Zalaga - Aardvark 1983
This needs to be *RUN, only works on bEm22 as BeebEm414 can't cope with the tape protection loader...
says V2.2 on last file
ZalagaBuef.zip
UEF
(11.54 KiB) Downloaded 32 times
ZalagaBhqUEF.zip
hqUEF
(11.91 KiB) Downloaded 31 times
ZalagaBcsw.zip
csw
(122.91 KiB) Downloaded 35 times
here are the ones from AcornPreservation.org, the site does not exist now,
and not all 262 of them worked, hence this thread! :D
grab my upload here 57mb : https://www.mediafire.com/?h13hsx7m6c4msh7
AtariSoft 1984 - Pole Position CSW here :
viewtopic.php?f=1&t=11465#p143397
keys below & instructions:
inst
Commie_User
Postby Commie_User » Thu Aug 11, 2016 10:30 am
BOOM-Shankar!
With the Beeb as spicy as this, it should have been illicit!
Postby CMcDougall » Mon Jul 31, 2017 5:12 pm
ELITE - Acornsoft 1984 - Version 1 - electron
ELITEelkAcsw.zip
csw
(211.87 KiB) Downloaded 23 times
ELITEelkAhq.zip
HQuef
(24.6 KiB) Downloaded 22 times
ELITEelkA.zip
uef
(24.06 KiB) Downloaded 23 times
Postby CMcDougall » Mon Aug 28, 2017 10:06 am
Electron :
Cybertron Mission - Program Power 1983
Frenzy - Micro Power 1984
Positron - Program Power 1983 (or Gary Partis Soft)
luckily, on all these, game recorded twice on side A, and blank on side B
so 2nd game copy worked first time, as 1st copy had the dreaded usual wind up start of tape
media
inst
enjoy! 8)
PositronELKcsw.zip
csw
(66.05 KiB) Downloaded 19 times
PositronELKhq.zip
uefHQ
(6.24 KiB) Downloaded 18 times
FrenzyELKcsw.zip
csw
(118.59 KiB) Downloaded 20 times
FrenzyELKhq.zip
uefHQ
(9.02 KiB) Downloaded 17 times
FrenzyELK.zip
uef
(8.71 KiB) Downloaded 15 times
cybertronMissionELKcsw.zip
csw
(104.38 KiB) Downloaded 16 times
cybertronMissionELKhq.zip
uefHQ
(9.11 KiB) Downloaded 17 times
cybertronMissionELK.zip
uef
(8.81 KiB) Downloaded 15 times
Postby CMcDougall » Sun Jan 07, 2018 12:24 pm
Five A Side Socca -IJK 1983 (or Star Soccer in the first loader by D M Smith) - Electron
cov
this is a weird one, completely different from the BBC version, as that has 4 files to load (SOCCA, DATA1, DATA2 & DATA3)
now, when trying to load this Electron version (SOCCA, DATA1, ? (Locked))
into a BBC, it hangs on end of block 1A00, as if tape not long enough.. :? (? is load1781 call3100 len1B7E)
so wonder if the electron ULA can handle this last locked *RUN file, and the BBC can't :shock:
in the generated .TXT file, we have :
The following block size is 280
THE EMPTY BLOCK FLAG IS WRONG.
Found :          ? 19   Checksum ok
31 data blocks written.
Carrier tone written, length 2140 waves.
Baud rate of the preceding data was 1321.596
Found :          ? 1A   Checksum ok
32 data blocks written.
Carrier tone written, length 2144 waves.
Dummy byte in carrier tone is &2A.
Carrier tone written, length 4 waves.
Dummy byte in carrier tone is &0D.
Dummy byte in carrier tone is &00.
Dummy byte in carrier tone is &81.
Baud rate of the preceding data was 1322.521
THE FIRST BYTE OF THE NEXT BLOCK IS NOT '*'.
The following block size is 7
DATA BLOCK WRITTEN WITH A BAD CHECKSUM OR NON-STANDARD BLOCK.
33 data blocks written.
MISREAD A BLOCK.
Carrier tone written, length 2 waves
anyways, one to ponder on!
The .UEFhq does not work on BeebEm414 or bEm22
But, does work fine on ElkulatorV1 ,
the .CSW does not, but put here anyways to play back to elk using BackToLife .CSW<>.WAV
(not tested as yet..) EDIT: Working 8)
fiveAsideSoccaELKbHQ worksElkulatorV1 ONLY.zip
UEFhq
(4.68 KiB) Downloaded 7 times
fiveAsideSoccaELKbCSW noWork.zip
CSW no work
(77.17 KiB) Downloaded 6 times
Postby CMcDougall » Sun Feb 18, 2018 1:53 pm
^ 6 folk not figures that out then :?
next up, just one file, sideB made a working CSW, sideA made a UEF & hqUEF
BugByte Galaxy Wars
different from the STH .SSD version, as asks "Level (1 to 4) ?"
and the high score layout is also different showing scores per levels
*T.
galaxyWarsB-bugByte1983.zip
uef
(9.93 KiB) Downloaded 5 times
galaxyWarsB-bugByte1983hq.zip
hq
(10.25 KiB) Downloaded 4 times
galaxyWarsB-bugByte1983csw.zip
csw
(114.37 KiB) Downloaded 3 times
