Felix In The Factory key choice
Michael Brown
Postby Michael Brown » Thu Sep 14, 2017 2:44 pm
Hi all,
Sometime back I had an idea of adding the option of choosing between the original Felix In The Factory keys from the original tape and the more standard ones that were used on the Micro Power compilation re-issue.
I have now taken another look and made some progress.
The original tape version is loaded.
Then you are asked if you want to change the keys.
If no then the original game gets called.
If yes then new keys are poked over the original key locations and the alternative splash screen with these new keys is displayed.
This version should give you the choice of playing it on a real BBC or emulator with either set of keys.
If anyone thinks this is a good idea then I may do the same with Fruit Monsters!
regards,
Mick.
FelixKeys.zip
(9.2 KiB) Downloaded 27 times
Note: This version uses the original tape key layout and not the ones from my Disc001 which had been altered in recent years for QWERTY keyboards.
Re: Felix In The Factory key choice
Postby Arcadian » Thu Sep 14, 2017 10:44 pm
Great work Mick, the keys were a pain on a real Beeb too!
Michael Brown
Postby Michael Brown » Fri Sep 15, 2017 7:49 am
Glad you like it.
Here's Fruit Monsters - done the same!
FelixFruitKeys.zip
(8.46 KiB) Downloaded 18 times
Hope you enjoy them!
I was also originally going to add a detect BeebEm routine so that you were only asked if you want to change the keys under BeebEm leaving the original keys if you played it under B-em or on a BBC, but because Micro Power had changed the keys themselves when re-issuing the game later in their compilation, I thought I'd offer the choice of both sets of keys to all users of all media.
Now here's the question - do I add these to my discs 001 and 002?
leenew
Postby leenew » Fri Sep 15, 2017 8:05 am
I would say yes :D Make these the default versions, and I will add them to bbcmicro.co.uk too.
Lee.
billcarr2005
Postby billcarr2005 » Fri Sep 15, 2017 9:14 am
Great minds think alike :D
Felix and the Fruit Monsters (8 years ago!)
viewtopic.php?f=1&t=2498&p=19699#p19699
Felix in the Factory (almost 10.5 years ago :roll: )
viewtopic.php?f=1&t=1370&p=7920#p7920
Michael Brown
Postby Michael Brown » Fri Sep 15, 2017 9:33 am
Hi Lee,
Working on Disc001 and Disc002 as we speak.
This will, of course, mean re-posting these discs once more.
For the better I hope!
Mick.
Postby CMcDougall » Tue Sep 19, 2017 9:35 pm
the key selection on the original tapes are utter #-o
but noticed that the Disc version of FITFactory does have them 'correct' with ZX*/ Return :D
any chance, could someone also do Rocket Raid - Acornsoft, as it was crap on High Score Challenge recently,
as got a sore left hand after a while :x
billcarr2005
Rocket Raid keys changed
Postby billcarr2005 » Thu Dec 14, 2017 10:13 am
CMcDougall wrote:any chance, could someone also do Rocket Raid - Acornsoft, as it was crap on High Score Challenge recently,
Using the disk image on bbcmicro.co.uk
*LOAD RAIDOBJ
The controls are in the following places and I've changed them to the following
23D5 LDX#&BE   A      UP        :      B7
23DF LDX#&9E   Z      DOWN      /      97
23F3 LDX#&9D   SPACE  BACK      Z      9E
23E9 LDX#&FF   SHIFT  FORWARDS  X      BD
2405 LDX#&9F   TAB    BOMB      SPACE  9D
2421 LDX#&B6   RETURN FIRE
2B9E LDX#&8F   ESCAPE
Disc001-RocketRaid MOD.zip
Rocket Raid with "standard" keys
(8.58 KiB) Downloaded 12 times
Re: Rocket Raid keys changed
Postby CMcDougall » Thu Dec 14, 2017 7:57 pm
billcarr2005 wrote:controls are in the following places and I've changed them to the following
Cheers! =D>
just had a quick blast, much better, but I slowed emulator to 75% & still not that good at it! ..... :oops:
