Trivial Pursuit Young Players Edition
billcarr2005
Postby billcarr2005 » Sun May 14, 2017 12:12 pm
TRIVIAL PURSUIT YOUNG PLAYERS EDITION.zip
(155.02 KiB) Downloaded 25 times
Re: Trivial Pursuit Young Players Edition
Postby CMcDougall » Sun May 14, 2017 5:34 pm
how do you play this, does it have all the DAT1-8 files from the .WAV file/s from both sides of tape?
just looked at them, and they are Left only, and had to boost /gain them by 15-20db :shock:
usually with my normal version, I press 1 then Space, and off it then goes :?
billcarr2005
Postby billcarr2005 » Sun May 14, 2017 6:23 pm
CMcDougall wrote:how do you play this, does it have all the DAT1-8 files from the .WAV file/s from both sides of tape?
It's taken from the disk version.
Select 1 - 8 then <SPACE> and it'll get the correct DAT? and run the game... unless there's some incompatibility with certain DFSs that has crept in :roll:
Postby CMcDougall » Sun May 14, 2017 6:42 pm
billcarr2005 wrote:unless there's some incompatibility with certain DFSs that has crept in
yes, on 1770FDC DFS2.26 (as always), it does not even like *OPT 2,1 in the Trivial file,
but goto20 then gets me to intro scn, but no further :x
still says"Insert Data Tape" top left, so hence why thought was the tape version hacked....
billcarr2005
Postby billcarr2005 » Sun May 14, 2017 9:16 pm
Think you must be getting it confused with another SSD, this one says "INSERT DATA DISK.ENTER BLOCK.PRESS FIRE" :?
Postby CMcDougall » Mon May 15, 2017 8:53 pm
^yeah #-o tonnes of files all over the place... :x
just got my original Genus edition working, used MMFS back to 31/2" then UPURS into laptop, so now 200k not 3k :?
seems I had the 40T disc version (going by manual), hence the two discs, below for completeness.
how does one get past the Question /Answer, when it says "did you get it right (yes no)" :-s
TrivialPursuit-Genus-GAMEdisc0.zip
ssd 40T side0 game
(18.45 KiB) Downloaded 11 times
TrivialPursuit-Genus-DATAdisc0.zip
ssd 40T side0 questions
(148.5 KiB) Downloaded 11 times
billcarr2005
Postby billcarr2005 » Mon May 15, 2017 9:13 pm
CMcDougall wrote:seems I had the 40T disc version (going by manual), hence the two discs, below for completeness.
AFAIK the game was supplied on 2 disks... The first having drive 0 being 40 track and containing the game code. Once this is loaded, based on an earlier check, DRIVE 2 is issued to access DAT1-8 on the 80 track drive 2, or you're prompted to replace the game disk with a question disk, side A or B depending on which set of questions you're answering.
That's how Genus, Baby Boomer and Young Players editions all were... I just saved off the game code and copied the DATs over to make things simpler.
+ since the data disc is > 100KB, it must be more than 40 track? :?
CMcDougall wrote:how does one get past the Question /Answer, when it says "did you get it right (yes no)" :-s
Move the cursor left or right to select the correct response and press fire <SPACE>
Users browsing this forum: Bing [Bot] and 1 guest
