Emulating original low resolutions?
Trypticon
Postby Trypticon » Sat Apr 25, 2015 6:07 pm
I've defined custom resolutions under a Windows XP installation, using a 31 Khz (minimum) CRT VGA monitor. So I can output 320x256 or 640x256 with 100 Hz (double PAL) refreshrate for example.
Are there any Archimedes/Risc PC emulators that support this in fullscreen? I tried a brief test with Sim City under RPCemu for example, but the lowest it goes for me is 640x480.
minwah
Re: Emulating original low resolutions?
Postby minwah » Wed Jul 22, 2015 10:41 am
I wanted to do something similar but using a CRT TV at 15khz, but also could not find an Archimedes emulator that would run at low resolutions.
I think the best bet might be to try recompiling Arculator to do this, but I have not attempted it...
sbadger
Postby sbadger » Thu Oct 15, 2015 11:47 am
if the emus are running in windows xp you could try soft15khz
http://wiki.arcadecontrols.com/wiki/Soft-15khz
it doesn't work on all gfx cards but check it out, it's used to run MAME emulators on old 15khz arcade monitors so should fit the bill.
A3020| A3000x3| BBCBx3 | Electrn | Masterx3 |RiscPC| RPix3
A600 | C64 bbin x2|C64C | Toastrack |QL | XB360&1X |GB |GBC |GBA |GBASP | DS | 3DS XL x2| MD | MS
Atari 7600 | PS1-2-3-4| PSP |Vita |SNES |GC |N64 |Wii & U |Switch |JammaCab |Sony PVMx2
