How do you add a Hard Drive to Arculator please?
pixelblip
Postby pixelblip » Sat Jul 09, 2016 5:23 am
Hi there
I have been looking for some instructions ( easy ones !) on how to add a hard drive / windows folder to Arculator.
Please can anyone point me in the right direction please?
I also added 4 floppy ADFS to Arculator but can only see 0: and 1: - how do you see the other floppy drives please?
pixelblip
Re: How do you add a Hard Drive to Arculator please?
Postby pixelblip » Thu Jul 14, 2016 8:07 pm
Can anyone please help.....sorry to ask again. Thank you
Postby DutchAcorn » Fri Jul 15, 2016 5:53 am
pixelblip wrote:Hi there
Floppies
To access the other floppy drives you need to configure RiscOS to use them. In RiscOS3 you can do that by launching the !Configure application from the Apps folder in the icon bar and configure the number of floppy drives.
Or (also works on RiscOS2) go to a * prompt (F12 from desktop) and type
*configure floppies 4
Reset the emulator to apply the changes.
Hard discs
Do you get the ArculFS icon in your icon bar? There should be a folder called FS in the Arculator root folder. If you drop files there Arculator should be able to access them.
To access a hard drive image (.hdf file) the hdf file needs to be in the root directory of Arculator and be called hd4.hdf for disc 4 (the first hard disc, numbers 0-3 are reserved for floppy drives). To access it RiscOS needs to be configured to use an IDE Disc. Again, use the !Configure application or type the following command at a * prompt:
*configure idediscs 1
and reset the emulator to apply the change.
pixelblip
Postby pixelblip » Sun Jul 17, 2016 4:10 am
Thank you so much Paul.
Return to “emulators”
