Arculator on Linux?
dgrubb
Re: Arculator on Linux?
Postby dgrubb » Fri Mar 17, 2017 5:18 pm
bakoulis wrote:Yes, that I mean =1 is present but does no difference on speed.I tried also 0, 2, 4, 5, 8, 16 but nothing works.
Then I'm out of ideas, sorry.
bakoulis wrote:By the way, your debian version didn't exits as it should, even with "kill" command.
True. It needs some proper signal handling so it can shutdown things like Allegro cleanly before exiting. It needs a lot of things, really. :)
litwr
Postby litwr » Fri Mar 17, 2017 5:45 pm
bakoulis wrote:The ArcEm works great for me with RISCOS 3.1 and run games about 90% of original speed, so is very playable.
Thank you very much for this information. :) So what is wrong with my ArcEm? Is it working with 64-bit Linux? It works with problems with ArthurOS, it can't work with discs. :( I use the next line to start ArcEm with ArthurOS
arcem --rom roms/a1_20/a --processor ARM2 --memory 1M
I use the next line to start with RiscOS 3.11
arcem --rom roms/3_11/rom --processor ARM2 --memory 4M
and get the screen
`a' and `rom' are names of the appropriate ROM images.
Any help? Is there any documentation for Arc-Em? How to use hostfs with it? Thanks in advance.
BTW Arculator fo Microsoft Windows doesn't work for me with Windows XP under VirtualBox.
dgrubb
Postby dgrubb » Fri Mar 17, 2017 7:24 pm
litwr wrote:Thank you very much for this information. :) So what is wrong with my ArcEm? Is it working with 64-bit Linux?
I've never had issues running it under Debian Jessie for x86_64, so I'd expect it to work fine under related distros like Ubuntu, Elementary etc.
litwr wrote:get the screen
Are you sure that OS ROM is kosher? What does the output on the console say?
litwr wrote:Any help? Is there any documentation for Arc-Em? How to use hostfs with it?
http://arcem.sourceforge.net/manual/arc ... semuhostfs
bakoulis
Postby bakoulis » Fri Mar 17, 2017 9:13 pm
My command line is:
padsp ./arcem --memory 16M --processor ARM3
Works also very well with:
padsp ./arcem --memory 4M --processor ARM2
The commands must executed from inside ArcEm directory.
No ROM parameters needed for me, of course the ROM files must be into the proper folders.
padsp command needs for sound (actually OSS sound with pulseaudio, or the emulator will haven't sound).
Try it and let me know.
:wink:
Edit: Also put your files into hostfs folder and will boot with this!
litwr
Postby litwr » Sat Mar 18, 2017 8:23 am
Thank you very much for the link to documentation. It would be good to have it with the sources.
I made my ROM-file by
cat IC24.ROM IC25.ROM IC26.rom IC27.ROM >ROM
I placed it into a directory with `arcem' file. Then I used
micro@my2:~/arcem-src$ ./arcem --memory 4M --processor ARM2
and got the same blank screen and the next log.
extnrom_size = 65536, extnrom_entry_count= 3
HDC: Couldn't open image for drive 0
HDC: Couldn't open image for drive 1
HDC: Couldn't open image for drive 2
HDC: Couldn't open image for drive 3
X visual: TrueColor 24bpp found, RGB shift/masks = 16/8, 8/8, 0/8
floppy format ADFS 800KB used for drive 0's r/w, 819200 length, image.
inserting floppy image FloppyImage0 into drive 0: ok
floppy format ADFS 800KB used for drive 1's r/w, 819200 length, image.
inserting floppy image FloppyImage1 into drive 1: ok
floppy format ADFS 640KB used for drive 2's r/w, 655360 length, image.
inserting floppy image FloppyImage2 into drive 2: ok
floppy format ADFS 800KB used for drive 3's r/w, 819200 length, image.
inserting floppy image FloppyImage3 into drive 3: ok
New mode: 0x0, 4000000Hz (CR 0 ClockIn 24Mhz)
New mode: 640x-20, 25Hz (CR 0 ClockIn 24Mhz)
New mode: 640x291, 50Hz (CR b2 ClockIn 24Mhz)
arcem: user requested exit
I had to press `q'. :( BTW your command line works because you have `ROM'-file in the arc-em root folder. ;)
Is `.arcemrc' essential? Mine contains the next two lines
MFM disc
1 612 4 32 256
It is about HDD geometry and look not important for me.
I can't test hostfs because I can't even use floppy image. :(
I am using Debian 8.3 so please attach your executable. Maybe it will work.
bakoulis
Postby bakoulis » Sat Mar 18, 2017 1:09 pm
The ROM file must be into ArcEm/rom/Riscos311 folder, not just into ArcEm folder with binary file.
And the binary file after compiled, must be moved from ArcEm/src folder to ArcEm.
:wink:
bakoulis
Postby bakoulis » Sat Mar 18, 2017 1:12 pm
And as hardisk, just use the hostfs folder into ArcEm directory. Put your files into hostfs folder and boot!
litwr
Postby litwr » Sat Mar 18, 2017 4:21 pm
Thanks for support. :) It looks like I had made something wrong with sources. I downloaded them again, compiled, and things began to work! :) HostFS works too but I still fail with floppy images. They didn't show themselves at GUI panel. :( It is the only HostFS and mysterious :4 drive.
sirbod
Postby sirbod » Sat Mar 18, 2017 5:21 pm
litwr wrote:but I still fail with floppy images
Which OS version are you using? Unless the sources have been updated since I reported the issue last year, floppies fail under everything except RISC OS 3 (new FDC)
litwr
Postby litwr » Sat Mar 18, 2017 8:28 pm
I am using version 3.11. 3.00 doesn't work with Arc-em for me, it gives the blank screen. Is there a way to set up a proper configuration for floppies?
sirbod
Postby sirbod » Sun Mar 19, 2017 12:18 am
litwr wrote:I am using version 3.11. 3.00 doesn't work with Arc-em for me, it gives the blank screen. Is there a way to set up a proper configuration for floppies?
Ah, sorry, I thought this thread was about Arculator. I was referring to builds of Arculator from the GitHub source.
