BeebEm3s Hard Drive Image and ADFS Explorer
Postby daveejhitchins » Fri Mar 18, 2016 10:35 pm
I'm trying to load some files onto BeemEm3s hard drive: scsi0.dat using ADFS Explorer. I can load the image into ADFS Explorer and create the Directories I need and fill them . . . However, I don't seem to be able to save the updated image file scsi0.dat.
Firstly, should I be able to do this and secondly, if I can (?) where am I going wrong?
Thanks - Dave H :D
stevei2791
Re: BeebEm3s Hard Drive Image and ADFS Explorer
Postby stevei2791 » Fri Mar 18, 2016 10:58 pm
I believe that the save function requires you to purchase a license from Jon, its disabled in the free version.
Postby daveejhitchins » Sat Mar 19, 2016 8:33 am
stevei2791 wrote:I believe that the save function requires you to purchase a license from Jon, its disabled in the free version.
I have the paid-for-version for both DFS Explorer and ADFS Explorer . . . I can save normal sized disc images OK . . . So I'm stumped :?
Postby daveejhitchins » Sat Mar 19, 2016 9:12 am
A little more information:
I created a new Hard Drive image (16MB), within ADFS Explorer, and transferred all the files from the BeebEm3 Hard Drive (scsi0.dat) Saved as scsi0.dat, however, BebEm3 reports a Broken Directory - This may have something to do with the associated file: scsi0.dsc - Darn, better read the BeebEm3 instructions :oops:
Edit: Hmmm! Nothing there :(
Postby daveejhitchins » Mon Mar 21, 2016 8:22 am
I've moved forward with this issue . . .
I installed and registered the Windows versions of ADFS Explorer (and DFS Explorer, while I was there :D ) and the problem doesn't exist. On contacting Jon Welch he offered to look at the problem and provide a fix. That's refreshing, what a nice guy =D>
Postby daveejhitchins » Mon Mar 21, 2016 6:26 pm
It's now sorted :D
One of the first things I did was to check for an update of ADFS Explorer. I looked on the site and found that the version to download was the same version I was running (2.0). So didn't look any further. Jon, however, said there was an updated version (2.1) that actually fixed the problem I was seeing. He also attached the updated version - which did fix this issue.
When I went back to the Mac ADFS Explorer page and scrolled down - the version history showed version 2.1 - but the download link still showed version 2.0 with a 2007 date. Not sure if the link points to 2.1 though!
Anyway all sorted :D
