RPCEmu 0.8.13
flibble
RPCEmu 0.8.13
Postby flibble » Wed Oct 21, 2015 5:19 pm
A new version of RPCEmu is available, 0.8.13
http://www.marutan.net/rpcemu/
Changes in this version
* All Platforms
- Dynamic recompiler is no longer StrongARM specific. It supports a wider range of OSes with more processors. (RISC OS 3.50, 3.60, 3.70, 3.71, 5.22).
- Host pointer integration (follows host mouse) now works in rectangular pixel modes (e.g. Mode 12).
- The daylight saving time flag in CMOS should be automatically set on startup based on the timezone information from the host machine.
- ARM Core
- Abort handling of LDM/STM now follows the varying Abort Model of the different ARM processors.
- LDM/STM now check for abort on each data transfer, which gives accurate abort detection.
* Linux
- The display now supports pixel doubling of rectangular pixel modes (e.g. Mode 12) in the same way as the Windows version.
Note: Using the windows install to upgrade from
previous versions may overwrite your cmos.ram
and rpc.cfg files.
Matthew Howkins
Peter Howkins
sirbod
Re: RPCEmu 0.8.13
Postby sirbod » Thu Oct 22, 2015 9:26 am
Does this release fix the two issues I reported back in 2013 / 2014?
CMP without S flag generates an error
Permission Faults
Re: RPCEmu 0.8.13
Postby davidb » Thu Oct 22, 2015 10:03 am
Thanks for making a new release. :D I'll have to give it a try when I next do anything at the A7000+ level - I've been focusing on the older machines in recent months.
flibble
Re: RPCEmu 0.8.13
Postby flibble » Thu Oct 22, 2015 1:59 pm
sirbod wrote:Does this release fix the two issues I reported back in 2013 / 2014?
Permission Faults
The LDM/STM fixes were a prerequisite of the TLB changes needed for the permission faults, the TLB fixes are next on the list.
The CMP without S falg is undefined behaviour, as such it's taken a low priority compared to the bugs in the defined bits.
VincentVega
Re: RPCEmu 0.8.13
Postby VincentVega » Fri Oct 23, 2015 10:55 am
Is there any work planned to upgrade RPCEmu to use Allegro 5? Recent versions of Mac OS X don't support Allegro 4, thanks to Apple removing QuickDraw and various other bits and pieces.
I have had a look at porting it to Allegro 5, but it does seem like a lot of work. As a programmer myself, I am not entirely sure why they decided to change *everything*.
Re: RPCEmu 0.8.13
Postby Rich Talbot-Watkins » Fri Oct 23, 2015 11:24 am
VincentVega wrote:I have had a look at porting it to Allegro 5, but it does seem like a lot of work. As a programmer myself, I am not entirely sure why they decided to change *everything*.
I think sometimes it's better just to make breaking changes than cripple the API by attempting to provide backwards compatibility. The Windows API is a great example of the extra complication that backwards compatibility adds to a library, although I guess Windows wouldn't be where it is today without it.
Seems like the main change is a move away from polling towards an event-driven system which is most likely a performance win as well as reducing latency. Other changes seem to be mostly about keeping up with now-standard hardware capabilities, remembering that Allegro was originally designed to run on DOS with no hardware acceleration at all!
There's a bit of information here: https://wiki.allegro.cc/index.php?title ... m_A4_to_A5
flibble
Re: RPCEmu 0.8.13
Postby flibble » Fri Oct 23, 2015 2:32 pm
A chap on the mailing list has a build system setup for mac os x and the older allegro (that works on new macosx). He'll probably be rolling a new build in the next few days, I'll update when it's available.
geraldholdsworth
Re: RPCEmu 0.8.13
Postby geraldholdsworth » Fri Oct 23, 2015 4:06 pm
version 0.8.12 for Mac OS here:
https://bitbucket.org/caliston/rpcemu-s ... /downloads
Been working fine on my Mac OS El Capitan, using RISC OS 5.23, although someone has reported issues with using a USB Mouse on El Capitan.
Gerald Holdsworth
Repton Resource Page
www.reptonresourcepage.co.uk
flibble
Re: RPCEmu 0.8.13
Postby flibble » Sat Oct 24, 2015 12:00 am
geraldholdsworth wrote:version 0.8.12 for Mac OS here:
And version 0.8.13 as of about 3 hours ago
