Creating Master 512 Disks
Re: Creating Master 512 Disks
Postby hoglet » Thu Jan 29, 2015 9:17 pm
Or maybe this just isn't going to work, because of the 8bit/16bit differences.
Postby danielj » Thu Jan 29, 2015 9:27 pm
There is apparently a way of doing it with dd, but it takes several hours:
http://www.stardot.org.uk/forums/viewto ... f=2&t=3556
Jon's got the CF utils compiled for the Mac - perhaps he'd be able to compile them for linux?
Postby hoglet » Thu Jan 29, 2015 10:10 pm
Success, at least in getting the CF Card written.
All I needed to to was to insert zero bytes between every byte of your image, to turn it into a 16 image, that I could then used with dd.
#!/usr/bin/perl
$srcfile = "dosfordave.dat";
$dstfile = "test";
open(FILE, $srcfile) or die "can't open $srcfile: $!";
open(DST,">".$dstfile) or die "can't open $dstfile: $!";
binmode(FILE);
binmode(DST);
while (read(FILE, $buff, 8*1024)) {
    foreach (split(//, $buff)) {
        print DST $_;
        printf(DST"%c",0x00);
close(FILE);
close(DST);
This is now recognised by Data Centre.
Unfortunately, the 80x86 Co Pro seems very temperamental on the Model B (this contains my DataCentre at the moment). I can't even get this to boot from Floppy. I might try moving the DataCentre over to the master, and give this a go.
Postby danielj » Fri Jan 30, 2015 9:14 am
Excellent, pleased that worked Dave!
Postby BeebMaster » Fri Jan 30, 2015 1:11 pm
hoglet wrote:Success, at least in getting the CF Card written.
Some info here on doing the padding business, with a handy bit of code written by Sweh to replace the code I'd been given originally on the Ubuntu forums:
viewtopic.php?f=12&t=8079&start=0
Mainly about USB transfer speeds though, but the code is there!
Postby leenew » Mon Dec 14, 2015 4:25 pm
Is there anyone here who could copy me the 4 Master 512 discs on 5.25" floppy and getting them to me please?
(Version 2.1 DOS if possible)
It would save me the pain of attempting to create them myself...
Alternatively, could someone post DSD type images that I could use a datacentre beeb to write to disc??
I need them to test a 512 I am working on.
Thanks in advance!
Lee.
Postby danielj » Mon Dec 14, 2015 4:57 pm
Ergh - Lee, they're a pain to make as you can't write them with a datacentre using the usual methods. They're double density, and the datacentre's only geared up to deal with single. I did it on 3.5" floppies ages ago, and it was a right pain in the proverbial. I burned the disk in anger, and now I've only got a CF image which I think I uploaded a while back.
I did it with the Datacentre using information here: http://www.cowsarenotpurple.co.uk/bbcco ... ystem.html, JGH's USB filer to get the disk images onto the CF ADFS hard drive, then ImgToDisk to write the images out to floppy: http://mdfs.net/Apps/DiskTools/
After I did it, I distinctly remember having a stiff drink.
Postby leenew » Mon Dec 14, 2015 4:59 pm
Oh rats! :evil:
I don't think I have the time or patience to face this at the minute :( but I sure could do with the stiff drink :lol:
Lee.
Postby danielj » Mon Dec 14, 2015 5:14 pm
Have you got a PC that can write 5.25" floppies? Or a pair of 3.5" drives for the beeb and PC that'll write floppies with omniflop?
Postby leenew » Mon Dec 14, 2015 5:17 pm
err... no and no.
I have an UPURS cable, a datacentre beeb with UPURS ROM, and a PC with a serial port.
I also have little patience left at the minute :lol:
This may be the solution to everything: http://www.stardot.org.uk/forums/viewto ... 85#p126906
:D
Lee.
Postby danielj » Mon Dec 14, 2015 5:18 pm
Yeah, sod it, head for the booze.
Postby leenew » Fri Dec 18, 2015 3:34 pm
I am sober again :D so I will give this another shout....
If anyone is capable of creating 2 sets of the 4 Util disks for the M512 I would be very grateful indeed.
That's 8 disks, which I could either supply, or purchase from whoever steps up to the plate... :wink:
Am I right in thinking that if someone has the 'right' set up, and a set of these disks to hand, this is as easy as copying any disks?? :-k
Thanks in advance,
Lee.
Postby danielj » Fri Dec 18, 2015 4:02 pm
Yup - that's the easiest way.
geraldholdsworth
Postby geraldholdsworth » Fri Dec 18, 2015 6:24 pm
I have a Master 512, with the discs. However, I haven't a scooby on how to copy them, nor if I have the correct setup.
What I can do though, is, if you PM me your snail mail addy, I can post them to you, and you can then copy them yourself (don't worry, I have two copies of said discs...the originals and a copy).
Gerald Holdsworth
Repton Resource Page
www.reptonresourcepage.co.uk
Postby danielj » Fri Dec 18, 2015 6:32 pm
You can use the "DISK" application and choose the "Copy Diskette" option. I believe you have to format the disks appropriately first though. Disk 1 is the 640kb format, the other 3 are the 800kb format. Section 2.3 (and beyond) of the user guide here:
http://www.cowsarenotpurple.co.uk/bbcco ... -acorn.pdf
Postby leenew » Sat Dec 19, 2015 9:50 am
Hi Gerald And Daniel,
Firstly, Thank you Gerald for a fantastically festive offer =D>
Secondly, Daniel, does Gerald have the 'right' set up merely by having the discs, the M512, and any common-or-garden working disc drive?
Thirdly, if the answer is "YES"... Gerald, would you prefer to copy them and charge me for the discs? or send them to me as you mentioned above??
Thank ya,
Lee.
geraldholdsworth
Postby geraldholdsworth » Sat Dec 19, 2015 10:12 am
Hi Lee,
It would probably be best way would be for me to send them down to you - so much going on at the moment that getting discs copied would get pushed to the bottom of the pile, but popping discs into the mail doesn't take five minutes which then lets you take your time over copying them (and no rush getting them back to me).
Gerald.
Gerald Holdsworth
Postby leenew » Sat Dec 19, 2015 12:34 pm
Ok!
I will p.m. you my address now!
Thanks!!
Lee.
Postby leenew » Mon Jan 04, 2016 11:01 pm
I received the M512 discs from Gerald, and after a bit of a slow start (due to some of my dodgy discs and a dodgy disc drive), I now have made 3 sets of the discs.
Thanks to all!
Oh, and Gerald - I will get your discs back to you asap :D
Lee.
jbnbeeb
Postby jbnbeeb » Sun Jul 03, 2016 8:43 am
Hi there,
resurrecting old thread ..
At the last Halifax, Simon kindly helped put together a 6522-via-Master-modem-port circuit so that I can plug in an sd card for use with a modded MMFS -- this circuit now being the basis for the "MEUP" board that DaveH is producing. DaveH has also kindly sent me a board with MMFS and another rom (SD2?) to plug in to cartridge port so that the sdcard-via-modem--port will work. This means I can plug in a mouse in to the user port, sd card in to modem port..and via Matchbox Copro, boot DOSplus and run GEM via the 286 copro option.
BUT
to do that I need to get the M512 disk images on to an sdcard.
Has any kind soul got an image for the relevant disks so that I can transfer to SDcard on my PC? All the above looks a bit hard :) and also seems to be for CF cards.
Any assistance greatly appreciated.
Thanks,
Jason
I'm going to ..
ABUG North Halifax June 10-12
george.h
Postby george.h » Mon Jul 04, 2016 4:35 pm
You can find images of the disks here:
http://www.g7jjf.com/512_disc_images.htm
George
:wink:
Postby DutchAcorn » Mon Jul 04, 2016 6:13 pm
jbnbeeb wrote:... BUT
Or you can use the MMC Hard Drive solution with the image Dave provided. It has the M512 discs pre-installed.
See this thread: http://stardot.org.uk/forums/viewtopic.php?f=3&t=10519&p=141133&#p139786
jbnbeeb
Postby jbnbeeb » Mon Jul 04, 2016 8:12 pm
Thanks DutchAcorn and george.h - I spent ages yesterday searching for it but couldn't find it. I was using search terms like "Master 512" and "sd card". Just spinning up win32diskimager now :)
I'm going to ..
vanpeebles
Postby vanpeebles » Sat Jul 23, 2016 7:17 am
I'm struggling to get the discs for my Master 512. I've got twin 3.5" drives but no aform (for the adfs). Would I be able to format the discs and move the files onto them using my risc pc?
Postby DutchAcorn » Sat Jul 23, 2016 5:07 pm
vanpeebles wrote:I'm struggling to get the discs for my Master 512. I've got twin 3.5" drives but no aform (for the adfs). Would I be able to format the discs and move the files onto them using my risc pc?
JGH hosts quite a lot of RISC OS disk tools. Did you have a look there? http://mdfs.net/Apps/DiskTools/
vanpeebles
Postby vanpeebles » Sat Jul 23, 2016 9:05 pm
I'll give that a look :)
Postby jgharston » Sun Jul 24, 2016 12:39 am
You can format ADFS-L (ie, 640K) disks on RISC OS, and then copy whatever you need onto them. ImgToDisk will let you write an AcornDOS 800K disk image to a floppy, ImgToDisk filename 0 800K -format should do it, add -verbose to get verbose info.
vanpeebles
Postby vanpeebles » Sun Jul 24, 2016 6:13 pm
I gave this a go today with varying success. I got a partial write of the master 128 disc using size 640k but nothing worked on it, and it wrote the acorn dos one using 800k but that didn't work at all. I'll keep trying! :)
vanpeebles
Postby vanpeebles » Sun Jul 24, 2016 6:46 pm
I just tried the boot one as a 640k disc and it comes up boot strap loader, then says it can't find system file 6502 .sys on boot disk. Best I've got so far :D
vanpeebles
Postby vanpeebles » Sun Jul 24, 2016 7:33 pm
I've managed to write a full version of the welcome disk with all the files. I can see all the files and folders but what ever I run I just get bad command? So following the 128 user manual, adfs then chain"welcome40" or chain"welcome80" bad command, same if I try to run anything else?
Users browsing this forum: stevendt, sydney, Yahoo [Bot] and 6 guests
