P.R.E.S. AP5 - Original and Re-Design
Re: P.R.E.S. AP5 - Original and Re-Design
Postby daveejhitchins » Wed Jun 28, 2017 11:09 am
Getting near . . .
Here is the final (?) AP5 Schematic and PCB view - Please, if you have time, check this for 'stupids' - Thanks - Hi res copy attached.
AP5 Schematics 28-06-17.PDF.zip
(217.91 KiB) Downloaded 21 times
Postby daveejhitchins » Sun Jul 09, 2017 5:55 pm
PCBs ordered . . . Due on the 25th of this month. Now to finalise the Case design and get those made.
M Sadler
Postby M Sadler » Mon Jul 31, 2017 6:42 pm
Hi David
Please I would be very interested in a ready built P.R.E.S. AP5.
Please add me to your growing list.
Regards Michael [-o<
Postby daveejhitchins » Mon Jul 31, 2017 9:52 pm
M Sadler wrote:Please I would be very interested in a ready built P.R.E.S. AP5.
Added . . .
Extra Note . . . PCBs have arrived - Looking good :D
Dave H :o)
stevebubs
Postby stevebubs » Wed Aug 02, 2017 9:34 pm
Is it too late to be added to the list?
Postby daveejhitchins » Wed Aug 02, 2017 9:37 pm
stevebubs wrote:Is it too late to be added to the list?
Added :D
Postby CMcDougall » Thu Aug 03, 2017 5:50 pm
Super job as per usual Dave! =D>
can one please have a kit, as not soldered for a while :shock:
not fussed about case, as you know, all my stuff works better in bits 8-[
cheers, Col
Postby daveejhitchins » Thu Aug 03, 2017 8:06 pm
CMcDougall wrote:can one please have a kit, as not soldered for a while :shock:
On the list, Col . . .
JonC
Postby JonC » Thu Aug 03, 2017 9:58 pm
Dave, could you post the current order list, not sure if I'm on it? :lol:
Jon
Postby daveejhitchins » Fri Aug 04, 2017 7:02 am
JonC wrote:Dave, could you post the current order list, not sure if I'm on it? :lol:
Jon . . . The list is too big for a single post :^o :lol: I also have you down for 6 built with 7 cases? That may be wrong though :mrgreen: Is it 8 cases?
Down for 1 built with case :D
Hmmm! Just tried to add the list - How on earth can you add a formatted table to a post? Anyone?
Postby 1024MAK » Fri Aug 04, 2017 7:46 am
daveejhitchins wrote:Hmmm! Just tried to add the list - How on earth can you add a formatted table to a post? Anyone?
Hmmm! Master Dave, list formatted, possible is not! Instead use the code tag force... Use fixed spaces, not tabs. Some text editors can produce tabbed columns using spaces instead of tabs.
Example:
One two three
 1   2   3
 A   B   C
Or export a picture image from your favourite PC spreadsheet...
Postby daveejhitchins » Fri Aug 04, 2017 7:57 am
1024MAK wrote:Use fixed spaces, not tabs.
Thanks, Mark . . . Spaces it is, then.
Postby Elminster » Fri Aug 04, 2017 8:21 am
It is why I moved hardware list off of forum, doing tables is not that great in phpbb, very basic.
fatbob_gb
Postby fatbob_gb » Fri Aug 04, 2017 9:23 am
Could you put me down for a kit + case please Dave
JonC
Postby JonC » Fri Aug 04, 2017 12:13 pm
Or you could attach the list as a file? :D
Just saying! :lol:
Jon
Postby daveejhitchins » Sat Aug 05, 2017 7:47 am
List now added :D Please check it here.
marcusjambler
Postby marcusjambler » Sat Aug 05, 2017 11:33 am
1 built and 1 case please Dave
Postby danielj » Sat Aug 05, 2017 4:17 pm
Case please with mine Dave :D
Bitstik
Postby Bitstik » Mon Aug 07, 2017 9:16 am
1 built and cased please Dave.
thanks
Andrew
stevebubs
Postby stevebubs » Mon Aug 14, 2017 12:48 pm
Built with case, please?
Steve
jms2
Postby jms2 » Mon Aug 14, 2017 8:28 pm
I see you've got me down for a cased one Dave, but not whether I want kit or built up. It's definitely the kit please, building these projects is half the fun! :D
1987akaTheMoneyPit
Postby 1987akaTheMoneyPit » Thu Aug 31, 2017 11:29 am
I'd would be interested in a Kit & a case if that is possible? =P~
[-X if it ain't broke don't fix it :idea:
Postby CMcDougall » Wed Sep 06, 2017 3:28 pm
Here is where nearly 1.5hrs of soldering gets me, received yesterday, many thanks Dave 8)
Kit
To save yourself 4x those wee caps thingy ma bobs, you already had them soldered on to prog that square chip, so only need 8 in kit.
also the angled jumper changer at right hand side
J1/J2/J3 needs to be 6 long, I had 2x 4 long.
now IF I get another hour to myself, can try the DataCentre on it , as the internal version works fine from a mobile phone USB 5v 1amp adaptor :)
Postby daveejhitchins » Wed Sep 06, 2017 5:39 pm
CMcDougall wrote:J1/J2/J3 needs to be 6 long, I had 2x 4 long.
Col . . . You were following the instructions in the User Guide, weren't you?
From Page 20: Note: C20, C21, J3 and R12 are not fitted. :mrgreen:
Postby CMcDougall » Wed Sep 06, 2017 7:01 pm
daveejhitchins wrote:following the instructions in the User Guide, weren't you? Page 20: Note: C20, C21, J3 and R12 are not fitted
was using the picture at back of guide Pg19, as a pic tells me a thousand words! :mrgreen:
So I've actually picked the right jumpers, not using J3 (see pic above) so done it right 8)
Now to get kids in bed, & heat the iron for the ports :) then 1:30am bed for me :-s ...again #-o
Postby CMcDougall » Thu Sep 07, 2017 10:08 am
All working fine! :D :) :D 8)
Data centre to play E00 tape to disc version of Repton The Lost Realms! =D>
eUPURS =D>
Matchbox Co pro =D>
If building from kit, blueTac is your friend :wink:
The 5x cap 10u 'fatter' on right of writing on it has to go to the white dot for + on PCB.
very nice indeed :shock:
The wire jungle
Postby hoglet » Thu Sep 07, 2017 10:53 am
Col,
Here's the the patched version of RAMFS 1.04 (now called RAMFS 1.05).
ERAMFS105.zip
(10.19 KiB) Downloaded 12 times
The only change was to relocate the Tube registers from &FEE5 to &FCE5.
You might also want to try my Elk port of ADFS 1.30:
https://github.com/hoglet67/ADFS130/releases
The ROM you want to try on an Elk with a Data Center is ELK103.rom.
Postby daveejhitchins » Thu Sep 07, 2017 4:12 pm
Prices and options . . .
The cases are not yet available and probably won't be until next month.
So, if you would like your kit or built AP5 now, please let me know.You'll only pay for the kit or built unit now.
The down side: When the cases are available you'll have the extra postal charges. Sorry, I'm still no nearer a price for the case, however, I'm aiming for £5.00.
Price for an AP5 kit is: £29.00
Price for a built AP5 is: £35.00
TheCorfiot
Postby TheCorfiot » Thu Sep 07, 2017 9:16 pm
hoglet wrote:Col,
ERAMFS105.zip
Dave, Does that patched ADFS 1.30 include IDE drivers ?
If not do you have any plans for an ELK version of ADFS 133 Please
Thx
Postby hoglet » Thu Sep 07, 2017 9:17 pm
TheCorfiot wrote:
hoglet wrote:Col,
ELK103 does indeed include the IDE drivers.
Return to “hardware”
