EPROM Programmer collectors roll call
duikkie
Re: EPROM Programmer collectors roll call
Postby duikkie » Wed Oct 19, 2016 7:41 am
i have a 27c128a , with all bytes ff(h) if i program byte 0 with 4c(h) or an other byte , the result is 00 :(
every time from ff to 00 error
duikkie wrote:mmmm, then i don't know why it is not possible to program 1 byte al all ? , reading no problem , but programming error no communication with epp ? so modern computers is not that simple anymore ? , communication with rs232 port changed ?
poink wrote:
duikkie wrote:not looked closely but i think is has to do with the timerchip ah=0 , int 1a(h) , what is not working anymore. but maybe i am wrong.
The only reference to an EPP-2 programmer I can find is the one made by Art Programming Systems, which is a serial programmer, and has a simple text based protocol and supports flow control. It'll do the timing internally, indeed the manual explicitly says in Appendix A, 'Any terminal emulation program using the RS232 communication port of the host can be used to operate the EPP-1F/2.'
1980s_john
Postby 1980s_john » Tue Nov 01, 2016 1:16 am
I have Celectronic Promicron 2000 and 2300: http://vintagecomputers.site90.net/ce/
Can handle 2708 to 27512, RS232 interfaces to PC.
However I usually use a Dataman S4.
Regards,
John
Postby tricky » Tue Nov 01, 2016 8:36 am
I did try a couple of ways of getting my epp-2 to work with different PCs, but ended up installing an old one with win98 and then using DOS.
duikkie
Postby duikkie » Tue Nov 01, 2016 3:05 pm
With windows xp making a msdos upstart disk then ppdos on a: extract it del german and french lan and hlp files. On other a: disk ffc.exe to make .s2f files
tricky wrote:I did try a couple of ways of getting my epp-2 to work with different PCs, but ended up installing an old one with win98 and then using DOS.
sirmorris
Postby sirmorris » Wed Nov 02, 2016 8:49 am
Just bought another programmer - MINI PRO USB TL866A because there's open source software available for Linux/OSX. I sprang £50 for a UK seller of the 'A' model, which has the ICSP facility enabled because I use that a lot. It doesn't do PIC32 but I can live with that.
There is a cheaper 'CS' version which doesn't come with ICSP enabled but can be user upgraded with some soldering and firmware hacking. I have too much firmware hacking to do of my own hence swapping cash for convenience. You can get the CS on ebay along with a boatload of smd/plcc adapters for under £50.
ac3
Postby ac3 » Mon Mar 27, 2017 4:52 pm
simes wrote:Stag Orbit 32
Stag P301
Stag Orbit 48
Don't have any manuals but as the designer of these programmers I may be able to answer questions if anyone needs help.
Did you have anything to do with the Stag System 3000 programmer by any chance?
I didn't set out to collect programmers but over the years I've accumulated quite a collection. :lol:
Stag System 3000 - by far my favorite, it's pure quality and looks like it cost a lot back in the day, only problem is there's only dos software for it.
Galep-4 - My most used now I've got it working on a modern pc with a pci parallel card.
GQ-3X - USB but otherwise pretty poor, the fake 3m zif socket has pretty much had it.
Top2048 - Completely useless.
Batronix - My first programmer, early model not sure which one exactly. You have to set jumpers on it for each type of chip. :roll:
Labtool48 - Clone version so have to be careful to only use old software this one.
I think that's all of them, for now anyway. :mrgreen:
Seldon2k
Postby Seldon2k » Sat Apr 01, 2017 12:18 am
Hi Dave (CanonMan),
Sorry, I have only just checked back.
The EPP-1 I have worked as an EPP-1F under later software.
It IS a serial programmer and is VERY slow with larger EPROM's.
I used it mostly with Win9x but did succeed in using it with WinXP.
I see no reason why it wouldn't work in XP compatibility mode, preferably with a Dell as they have real serial ports.
I do remember that I had to go to a later version of PromProg, it may even have been a 3rd party app for the EPP-1F/2 that I found online.
I will try to find this software, more later.
Hope this helps,
Terry (Seldon2k)
CanonMan
Postby CanonMan » Sat Apr 01, 2017 9:52 pm
Seldon2k wrote:Hi Dave (CanonMan),
Hope this helps,
Terry (Seldon2k)
Hi Terry
Thanks for the info. If you manage to find the software that would be great. It will make a nice change from the Data I/O 288 that I'm working on at the moment!
boba
Postby boba » Wed Apr 05, 2017 7:59 pm
Homebrew 'Willem' programmer (yeugh! But it does work).
Stag P301 - does everything I need under WinXP.
Postby Coeus » Thu Apr 06, 2017 10:03 am
sirmorris wrote:Just bought another programmer - MINI PRO USB TL866A because there's open source software available for Linux/OSX. I sprang £50 for a UK seller of the 'A' model, which has the ICSP facility enabled because I use that a lot. It doesn't do PIC32 but I can live with that.
I got the CS version of this. I wasn't aware of the difference but I really only program EPROMs, at least at the moment, so I was looking for something cheap that I could use from Linux. The minipro program on Linux was worked flawlessly. I can't comment on how reliable the Windows drivers are.
cmorley
Postby cmorley » Thu Apr 06, 2017 10:24 am
I bought a TL866CS a while ago essentially free with Nectar points through eBay. You can put the ICSP header on and mod it to an "A" if you wish. I did because I could but never used it! It programs EPROMs fine but won't program a lot of ATMEL PLDs (e.g. 22v10) - it does do some but won't do others from the same batch of chips using the generic 22V10 and setting VPP manually. So I bought a Wellon VP598 too... that was not free... by any stretch.. :S
But yes, I too can fully recommend the TL866CS if your main goal is EPROMs and EEPROMs. They haven't updated the device list or software for years now so it looks like they have given up on that... (P.S. on windows 7)
geka
Postby geka » Thu Sep 14, 2017 9:42 am
Stag P301
Stag Orbit 48
Hello simes,
I have got an STAG Orbit 32 hand held programmer and would like to instal
the latest firmware update (FLASH102.SBN or *.bin file for 29F040 Flashrom).
Could you send it to me, please? My current firmware is Ver. 05.01 and Rev 06.03.
Thank you.
Best Regards.
geka
Boydie
Postby Boydie » Thu Sep 14, 2017 11:19 am
Watford Electronics Adder and ROM
Has the added plus that you can go for tea while it's programming a 27128, and still not miss it finishing.
Postby tricky » Thu Sep 14, 2017 12:45 pm
Seldon2k wrote:...I do remember that I had to go to a later version of PromProg, it may even have been a 3rd party app for the EPP-1F/2 that I found online. I will try to find this software, more later...
Did you ever find this, as I would like to get my EPP2 working on XP, although I guess it may just need a different motherboard.
robert24
Postby robert24 » Wed Oct 18, 2017 8:05 pm
Hello, we just bought a Micron Eprom Programmer (user port version) without any supporting documentation or software. We searched around and found your post saying that you might have some.
If possible, could you make whatever you have available ? we found some stuff for the "plus" version but it uses the 1mhz bus and obviously different. Couldn't find anything on the older version... but then we found you :-)
Let me know if you can help... and how we can transfer/read, etc. thanks, robert
Edit: Answered by MartinB in thread http://stardot.org.uk/forums/viewtopic.php?f=3&t=13939
Thanks for a great Beeb resource :-)
eXne
Postby eXne » Mon Oct 30, 2017 6:44 pm
I’ve build my own Epromprogrammer.
It’s attached the userport.
Etienne
robert24
Postby robert24 » Fri Dec 01, 2017 8:01 pm
herein the results of our eprom investigations...
the one that worked for us is "WE & HCR Iss 1 Programmer.zip"
however the rest may help your quest if it helps : )
@user port eprom.7z
eprom files
(2.87 MiB) Downloaded 13 times
we have more but star dot says file too large. we'll think about how to transmit
=== update
how do we store files on the web? used to know about rapidshare ? now ? ? ?
Postby MartinB » Fri Dec 01, 2017 9:12 pm
Dropbox is pretty good, you just want the Basic account which is free and gives you 2GB of storage. You can have private and public areas for which you can post sharing links in the usual way and there’s also an app for phones and tablets.
Users browsing this forum: Baidu [Spider], myelin and 7 guests
