BeebSID
lazarusr
Re: BeebSID
Postby lazarusr » Wed Oct 05, 2016 8:51 am
My fingers can take it. The nixie tubes I was playing around with have a startup voltage of 170V. That really has an interesting affect on your fingers when you touch that. :shock:
boba
Re: BeebSID
Postby boba » Wed Oct 05, 2016 11:00 am
hoglet wrote:If you are feeding the board with 12V, then the 7805 is going to be dissipating 770mW.
The ST L7805 I used has a thermal resistance of 50°C / Watt without a heatsink.
So at 21°C ambient the package would quickly reach temperatures of 21 + 50 * 0.770 = 59.5°C which is very toasty
I'm not sure that's quite correct. The thermal resistance (for a device) is usually quoted as chip to ambient in free air so in this case the CHIP temperature would be 59.5 (with the case temperature unspecified). This is only very rough though as airflow round the case is pretty uncertain.
Re: BeebSID
Postby hoglet » Wed Oct 05, 2016 11:06 am
I'm not sure that's quite correct. The thermal resistance is usually quoted as chip to ambient in free air so in this case the CHIP temperature would be 59.5 (with the case temperature unspecified). This is only very rough though as airflow round the case is pretty uncertain.
You are indeed correct there.
The data sheet says:
Can you calculate the "case to ambient" by subtracting the two figures, giving 45°C / Watt?
boba
Re: BeebSID
Postby boba » Wed Oct 05, 2016 11:14 am
Yes, thermal resistances are additive just as for electrical resistances. The difficulty with a package is that it's not likely to be uniform although the metal tabs are generally continuous from the chip substrate so not much of a gradient there I guess.
lazarusr
Re: BeebSID
Postby lazarusr » Thu Oct 27, 2016 6:31 pm
1024MAK wrote:This may be a suitable heatsink.
Those heatsinks make a huge difference. Runs much cooler now.
Holmes
Re: BeebSID
Postby Holmes » Sat Oct 29, 2016 7:15 pm
Hey, I was just wondering how many of you guys with BeebSIDs are grounding the input to the SID chip. The SID input pin (#26) was a source for noise on the C64s, and one of the tricks to reduce that was to ground it, thus improving the sound output. Apparently this floating input picked up a lot of interference.
I believe there's a jumper for it on the BeebSID board.
Recently discovered this in the C64 literature.
Re: BeebSID
Postby 1024MAK » Sat Oct 29, 2016 10:36 pm
Um.... I'm about 500 miles away from my board at the moment, and I forget what I did. But I'm sure that this point either came up before, or I remember reading about it somewhere else. So it's likely I looked into it. But too long ago to remember :?
Re: BeebSID
Postby MartinB » Sat Oct 29, 2016 11:05 pm
I don't think I actually did anything with pin 26 in the end. I originally drew it on the schematic as an input connector but I thought (hazy memories) I read the opposite to you and understood it could happily be left floating due to the internal biasing. I'll confirm on a BeebSID PCB tomorrow but I reckon it's untracked... :-k
(Maybe Phill HS added a link on the second batch of boards ?)
Holmes
Re: BeebSID
Postby Holmes » Sat Oct 29, 2016 11:48 pm
On the Mk2.3 board design (which is what I based my board on), pin 26 on the SID is linked to a 2-pin header for connecting an audio input. The other pin on the header is connected to ground, so I presume it should just be a matter of throwing a jumper on that header which will ground the SID input.
I saw on one of the completed board pictures, a pull-down resistor soldered across the top of the SID from what looks like pin 26 to pin 14 (GND).
http://www.retro-kit.co.uk/user/custom/ ... plete2.jpg
I just connected pin 26 directly to ground on my board, without a resistor, so I hope that approach is okay. Seems to work well, because I found the sound to be very clean playing through the BBC speaker on mine.
Re: BeebSID
Postby MartinB » Sun Oct 30, 2016 8:08 am
Ok, fog clearing now... :wink: I left it untracked (probably just forgot in the end!) whereas on the second batch of boards, Phill added an input connector with an option to ground the line. Because there was no track on the original boards, there would be very little chance of picking up stray noise and any issues with the C64 implementation shouldn't necessarily be assumed to read across to BeebSID. It's generally where there's a length of unterminated PCB track to an input that noise pick-up problems can arise because the track can act as an antenna and this was seemingly the case with the C64.
That all said, there's certainly no harm at all in adding a resistor (ideally) or a ground short, the input impedance is apparently around 100k, but a quick 'quiet' test on mine (no resistor etc.) certainly shows no pick-up.
Holmes
Re: BeebSID
Postby Holmes » Sun Oct 30, 2016 12:15 pm
Ok, that makes sense. No trace, no antenna effect. The c64 connected the SID input all the way to the external audio/video connector.
Re: BeebSID
Postby 1024MAK » Wed Nov 02, 2016 3:33 pm
Holmes wrote:Hey, I was just wondering how many of you guys with BeebSIDs are grounding the input to the SID chip. The SID input pin (#26) was a source for noise on the C64s, and one of the tricks to reduce that was to ground it, thus improving the sound output. Apparently this floating input picked up a lot of interference.
On the Mk2.3 version board (picture here) pin 26 is routed to a pin header ("Audio in") but I don't have anything connected to this header. So pin 26 floats. The track is not very long. I can't hear any noise, so I don't think it matters.
One thing you can't see in that picture, is the added resistor on the track side between pin 27 and 0V/GND. This is the audio output bias that was talked about in this post.
Edit: pictures added :D
BeebSID Mk2.3 version board showing output bias resistor
BeebSID Mk2.3 version board showing output bias resistor (close-up view)
Normally when using my BeebSID, I connect it to an external audio amplifier via the "Audio out" pin header.
PitfallJones
BeebSID Disk#17 Pet Shop Boys
Postby PitfallJones » Thu Dec 22, 2016 1:25 pm
It's been one long year since the last one... so here's the latest installment in the series...
The best of 80s electronica... The Pet Shop Boys!
- PJ
beebsid17.zip
(26.33 KiB) Downloaded 41 times
storhemulen
Re: BeebSID
Postby storhemulen » Thu Jan 26, 2017 12:46 pm
Hi all!
I just got my first beeb. A Master, to be precise. It worked just fine for about 15 minutes, then *fizzle* *pop and white smoke to signal the new popes divine appointment. Changed the exploded cap (and all other caps prone to failure) and I'm back in business.
Found this outstanding community and of course this very cool BeebSID device. Being an old C64 guy, this is a must have for me. Now, the questions is are there any PCBs left? I suspect the answer to be no, but no harm in asking.
Cheers!
Re: BeebSID
Postby Prime » Thu Jan 26, 2017 1:47 pm
storhemulen wrote:Found this outstanding community and of course this very cool BeebSID device. Being an old C64 guy, this is a must have for me. Now, the questions is are there any PCBs left? I suspect the answer to be no, but no harm in asking.
I have a few left, send me a PM and I'll let you know costs etc. May not reply till next week tho, as I'm going to be away at the Acorn meetup over the weekend. If you can't PM yet, I'm sure Daniel will be along presently to enable it for you.
M Sadler
Re: BeebSID
Postby M Sadler » Fri May 19, 2017 9:03 pm
Interested in a BeebSID, are they still available. I would love a ready built one if you have any left. Thanks
Re: BeebSID
Postby Zarchos » Fri May 19, 2017 9:05 pm
M Sadler wrote:Interested in a BeebSID, are they still available. I would love a ready built one if you have any left. Thanks
If you've got a second and a third unit, I'm interested too.
marcusjambler
Re: BeebSID
Postby marcusjambler » Fri Oct 20, 2017 3:23 pm
Registering my interest in a BEEBSID board if anyone is having some made...
There is a replacement for the SID chip on ebay
http://www.ebay.co.uk/itm/Commodore-64-NANO-SwinSid-Replacement-sound-chip-/272890938662?hash=item3f89914526:g:T2EAAOSwmo5ZnXQf
trixster
Re: BeebSID
Postby trixster » Fri Oct 20, 2017 9:21 pm
Hi guys,
I finally tried setting up the beedsid that came with my Master. It needed a new 8580 and a 34 pin idc to daisychain the beebsid ahead of the datacentre. Lk2 is south for a 9v SID.
I'm assuming the power lead goes the way I connected it as the connector wouldn't fit the other way round!
Unfortunately I'm not getting any audio from it. I've tried the beebsid5a Movies ssd in DTRAP mode. I've also tried the lk1 jumper to see if audio will come from the Beeb speaker but I still don't get anything.
With the old dead 8580 in place the datacentre ram drive won't initialise with power applied to the beebsid. With the new 8580 installed the datacentre works fine with power applied to the beebsid, so I think the new 8580 is ok.
Any ideas where I'm going wrong?
PitfallJones
BeebSID Disk#18 - Club Hits!
Postby PitfallJones » Tue Nov 21, 2017 12:12 pm
Time to get down to the DISCO!
Here comes Sid Disk #18 - Club Hits!
26 Massive Tracks Remixed for the SID!
beebsid18.zip
(44.12 KiB) Downloaded 16 times
Pernod
Re: BeebSID Disk#18 - Club Hits!
Postby Pernod » Tue Nov 21, 2017 1:01 pm
PitfallJones wrote:26 Massive Tracks Remixed for the SID!
Thanks, some top tunes in there, though some of the renditions are rather dubious.
dominicbeesley
Re: BeebSID
Postby dominicbeesley » Tue Nov 21, 2017 1:56 pm
woop woop, I'll get me whistle...no hang on which of the boxes did I pack the SID....
Return to “hardware”
Users browsing this forum: No registered users and 10 guests
