| Author |
Message |
PitfallJones
Posted: Thu Oct 07, 2010 2:31 pm |
Here's a Madonna disk! I've discovered a lot of SIDs have a play address of $0000. After reading up about it - it appears the sid_init call will setup an IRQ routine at the C64 vector $314. $314 is some graphics workspace on the BBC so shouldn't matter. Anyhow as the BBC IRQ routine has to do some BBC special stuff you can't call the C64 one. I was trying to be clever with the following code to call down to their IRQ routine from my BBC one, but it doesn't seem to work, anyone got any ideas? (I can post a SID that works like this) Also SIDs don't seem to store a song length - anyone know anything about that? ._BBC_IRQ: .... PHP LDA #HI(next_addr) PHA LDA #LO(next_addr) PHA JMP ($0314) ;;does an RTI at the end of the SID IRQ .next_addr: RTI Attachment:
beebsid6.jpg [17.19 KiB]
Downloaded 1456 times
Posted: Thu Oct 07, 2010 5:20 pm |
Joined: Mon Mar 31, 2008 10:04 pm Posts: 3376 Location: Obscurity
Nice one yet again PJ - I will give that a play later and report back  On that bit of code, I think I get what you're trying to do but in trying to simulate an IRQ for the C64 RTI, the normal order is PCH, PCL and finally P(status) so on a quick look, shouldn't that PHP should be after the Lo push? I wouldn't mind seeing some more detail if you can post anything useful or maybe you could put together and attach an info bundle? Not sure I can join in immediately but I'd like to get more into BeebSID programming as time permits. I really should, shouldn't I...
TomWalker
Posted: Thu Oct 07, 2010 7:45 pm |
PitfallJones wrote: I didn't know the SID could do PCM - we could have speech!
I'm amazed it works at all - at 44100 Hz that leaves 1,000,000/44,100 = 22 cycles per sample - no time to do anything... and how much song can you fit in 64K? There's an interesting article on it here : http://www.livet.se/mahoney/cubase64 - like most demo stuff it's cheating a lot but still very clever. There are all sorts of ways to play PCM samples on the SID. The traditional way is to put a 4-bit value into $D418 (the volume register). This works on 6581 due to a volume leak internal to the chip - on an 8580 you either have to create a standing voltage using one of the voices, or put a voltage on the Audio In pin. The more modern way uses the triangle waveform and some very clever timing. I'm not entirely sure how it works, but the results are impressive : http://www.youtube.com/watch?v=ZMioAPZcays (about a minute in)
PitfallJones
Posted: Fri Oct 08, 2010 7:42 pm |
@tom - excellent document - he really goes into it, in detail - and source code!
@martin - I Tried the PHP after as well with no luck - you do hear it playing the first note so it does get called properly but it never returns.... I'll email you my example.
Posted: Wed Oct 13, 2010 12:50 am |
Hi PJ - can you have a read of this post (by me) and see if you can enlighten me as to what might be going on with your compilation discs. (e.g. how do you produce your disc images.)
PitfallJones
Posted: Wed Oct 13, 2010 1:09 am |
I create the disk image from a 'c' program I've written on the PC, rather than a BBC - that must be the source of the problem.
So as you say it sounds like I'm creating the directory in the wrong order - I'll try it with higher sector first then...
- PJ
Posted: Wed Oct 13, 2010 8:27 am |
Mark wrote: Couldn't have put it better  Oh well, they do say that imitation is the sincerest form..... @ PJ : Actually I'm just relieved to hear that it's your own utility because I'd have had some work to do if that was a widespread layout! In one sense it matters not because as stand-alone discs they appear to work but I guess that sooner or later someone was going to get confused and you can always count on me to be that person  One thing though, if you remember I previously concluded that the <Shift><Break> problem appeared to some sort of timing issue so I wonder if it's related to the fact that your !BOOT files are at the opposite end of the disc to Sector 0 causing a longer than normal seek at boot
Posted: Wed Apr 27, 2011 10:20 pm |
It's just emerged that the Issue 2 schematic isn't attached anywhere on this thread so here it is. (Full-size BMP version attached.) Attachment:
BeebSID Issue 2.PNG [92.08 KiB]
Downloaded 1189 times
Posted: Wed Apr 27, 2011 11:21 pm |
retroclinic wrote: HAXX!!!!!!1!! http://cgi.ebay.co.uk/110597870187BeebSID has been cloned into a SAMSID?!?!?! Humm as I'm playing around with ZX80/81 hardware at the moment.....ZX-SID anyone ?  Cheers. Phill.
Posted: Fri May 06, 2011 12:36 am |
Is the source of the SID player available, I want to check how often it's bashing the SID registers, incase that's the cause of the slowness I'm experiencing with my SwinSID emulation.
Posted: Wed Jul 20, 2011 8:26 pm |
@ Tom W : Hi Tom - someone has commented on You Tube and asked what the first piece of music is in this BeebSID demo. I think you told me once but I can't remember....  ?
TomWalker
Posted: Wed Jul 20, 2011 8:51 pm |
It's the intro music to Cubemagik.
sirmorris
Posted: Wed Jul 20, 2011 9:32 pm |
Joined: Wed Feb 11, 2009 1:18 pm Posts: 368 Location: oxfordshire uk
Did I imagine it or did someone at InDa80s have an AtomSID going??
mga1103
Posted: Wed Jul 20, 2011 9:47 pm |
Joined: Mon Jan 24, 2011 5:00 pm Posts: 184 Location: Galway, Ireland
(When I saw this thread active again, my heart skipped a beat! ...but, alas..  )
Samwise
Posted: Wed Jul 20, 2011 10:01 pm |
Sounds dubious to me Martin. Pretty unlikely they'd have everything to hand ... so unless they started ripping the pub fixtures down, I don't see how it would have happened ...  Sam.
_________________ I will be running the London Marathon 2015 and aim to raise £1,500 for the PSP Association. Any sponsorship gratefully received! http://www.bagshot-row.org/marathonformum
sorvad
Posted: Wed Jul 20, 2011 10:05 pm |
Joined: Wed Aug 24, 2005 1:13 pm Posts: 2128 Location: Back of beyond
As impressive as the stuff always is at these shows I don't remember an AtomSid, only remember there being one Atom working there for a start and that was constantly running Chuckie Egg ! Very impressively actually
Posted: Wed Jul 20, 2011 10:26 pm |
It is was true then  (It's probably the way you wrote it but I promise I'm not laughing on the inside...  ) What popped - it wasn't the SID was it ?
Samwise
Posted: Wed Jul 20, 2011 10:30 pm |
naah, they found a replacement to check that.
Sam.
Posted: Wed Jul 20, 2011 10:37 pm |
Samwise wrote: naah, they found a replacement to check that. Wow! That's some venue - not only is it a pub but there's SID chips just lying about the place...
sirmorris
Posted: Wed Jul 20, 2011 10:47 pm |
Not lying exactly, more ... mounted  There is a display of broken computers literally screwed to the wall. I asked the landlord nicely and he said I could get the '64 down to check for a SID... Result! Still didn't work tho - same fault with new SID - I suspect some other circuitry got it...
Posted: Thu Jul 21, 2011 10:42 pm |
mga1103 (or 'A' Martin as I prefer to call him) wrote: When I saw this thread active again, my heart skipped a beat! ...but, alas.. Curiously, a previous BeebSID PCB buyer has taken pity on wretched 'A' Martin's obvious despair and is returning an unused board for me to pass on to him  . He's got the luck of the Irish this muppet look-alike....  This has actually given me a thought - if there were sufficient interest (say 25) people interested in getting a PCB, someone ( not me this time) could order another 25 and distribute them as I did for the first batch. That person would need about £150 up-front (or could take pre-paid orders) and I could supply the necessary Gerber files needed. (If the same supplier were used, they might even still have the patterns.) Just a thought in case anyone feels so inclined
mga1103
Posted: Thu Jul 21, 2011 10:54 pm |
MartinB wrote: mga1103 (or 'A' Martin as I prefer to call him) wrote: When I saw this thread active again, my heart skipped a beat! ...but, alas.. Curiously, a previous BeebSID PCB buyer has taken pity on wretched 'A' Martin's obvious despair and is returning an unused board for me to pass on to him  . He's got the luck of the Irish this muppet look-alike....  ... Yippee !!!  . Someone's just made me a happy camper  .  . (Note to self: do the lotto tomorrow...just in case there's any more of that luck around  ). My 6581 and beeb are finally going to get together... Thanks Martin...(and of course to the doner)  .
mga1103
Posted: Thu Jul 21, 2011 11:23 pm |
Now, in anticipation of becoming a BeebSID owner (  ), the mind is racing ahead and of course, questions arise: I've seen various values mentioned earlier in this thread for the C1 & C2 caps (6800pF for the 9V 8580 and 1000pF/2200pF for the 12V 6581), which would appear to influence the audio quality output. (1) As I'll be using the 6581, I'm just wondering if anyone's experimented with various values with this chip and if so, what were your findings? (2) If I wanted to experiment with different cap values, I wouldn't want to torture my pcb to death with a solder iron, so has anyone successfully socketed caps before to allow for easy substitutions? Is there an off-the-shelf gizmo available? (3) My local component suppliers (RS, Farnell, Maplin) don't seem to supply sticky pads with pole mounts (well, as far as I can tell), which seems a bit odd  . [I'm already having visions of my BeebSID boxed!  ]. Can anyone recommend a supplier? Thanks in advance for any pointers & tips...! -Martin.
retroclinic
Posted: Fri Jul 22, 2011 12:02 am |
Joined: Thu Jul 03, 2008 2:22 pm Posts: 2955 Location: East Riding of Yorkshire
mga1103 wrote: (2) If I wanted to experiment with different cap values, I wouldn't want to torture my pcb to death with a solder iron, so has anyone successfully socketed caps before to allow for easy substitutions? Is there an off-the-shelf gizmo available? You can always cannabalise a turned pin IC socket, if you don't fancy buying some SIL strip sockets mga1103 wrote: (3) My local component suppliers (RS, Farnell, Maplin) don't seem to supply sticky pads with pole mounts (well, as far as I can tell), which seems a bit odd Au contraire, RS and Farnell indeed do sticky posts, lots of different types (although I'd forgive you for not finding any on the RS website as they've sure screwed it up recently) - however RS 580-001 are one type I use, but there are others of different lengths, and for 3mm or 4mm PCB holes. Mark.
_________________
mga1103
Posted: Fri Jul 22, 2011 12:41 am |
I certainly couldn't find those boys  . Just what I was looking for. Will check out the SIL strip sockets. Thanks Mark.
