Pictures of my ELK IDE disk interface
AlanD
Postby AlanD » Wed Jun 24, 2009 7:56 pm
Hello All
This my little project to interface an IDE drive with my ELK
task 1 designed hardware no problem there
task 2 design CPLD
task 3 patched ADFS 1.33 from the BEEB relatively simple to do and named my version ADFS 1.34
result everything worked BUT i was unhappy with page being stuck at &1d00
task 4 added some sideways ram 2 banks of 16K to my plus1 changed the plus1 rom to the
slogger 2.02 rom so i the sideways ram utils *RLOAD,*RSAVE
task 5 patched the BEEB Advanced DFS 1.32 i now call this version 1.35
Result Hey Presto now i can run just about any games DFS or ADFS
here are some pics
picture of elk plus1 with Sideways ram lashup and IDE interface in cart slot
Elk Booted into ADFS
List if Side roms and Advanced DFS load into RAM
Loaded Exile still a great game
A Pic of the IDE interface with on board ADFS ROM
Hope this is of some interest
AlanD
MartinB
Re: Pictures of my ELK IDE disk interface
Postby MartinB » Wed Jun 24, 2009 8:39 pm
Nice job Alan =D>
Looks like you're wasted on GE - you're needed here. The wages are poor but the job satisfaction is second to none :D
So, exactly how long did Tasks 1-5 take then? You made it sound like at least a good half day :)
Martin
Greybeard
Postby Greybeard » Wed Jun 24, 2009 9:18 pm
Nice one, Alan.
So what was it? Half a day and then off for a quick round of golf?
Looking forward to more of your posts, Mate. :)
retroclinic
Postby retroclinic » Wed Jun 24, 2009 9:31 pm
Looks good! Well done! =D>
So....does the cart work on a Master then, if you use ADFS 1.53 in the ROM instead?
Also, we really need to try and arrange to get some generically sized, or maybe slightly taller plastic cartridge cases made up. Several people have made cart slots things, but having them open leads to all sorts of possible problems, like damage, insertion backwards etc.... I did look into having some plastic casings done for 3.5" drives a while back, but got told some rediculous price and minimum quantities for the mouldings which made it far from being worthwhile.
Wrecking vast quantites of Electron View and ViewSheet Carts - whilst being morally acceptable :lol: - still would not yeild that many, as they are hard enough to find anyway, and I think too small for some projects.
Mark.
Postby Arcadian » Wed Jun 24, 2009 9:52 pm
Woah! :shock: I want one!
If you ever were to release the patched Rom Images into the wild, perhaps it might be a good idea to suffix each version number with an "E" to denote them as being for the Elk? e.g. ADFS 1.34E, ADFS 1.35E
As for cartridge shells I agree that it would be nice to source a load of them, as then we could release Retro Software games on Rom Cart for the BBC Master and the Electron! :D
AlanD
Postby AlanD » Wed Jun 24, 2009 10:02 pm
Hello Martin , Greybeard
started about a month ago after i did the board
i did the cpld then it was half time for a week or so
initially i used it with J. Harstons HADFS but found it did not suite my needs
decided i needed adfs for games later adfs in swr
then i realised the easiest way to get ADFS's was to patch the beeb ones
all you have to do is
find all the tube accesses FEEx on the beeb FCEx on elk
find all the 1770 accesses FE8x on the beeb FCCx on elk
find the page register accesses FE30 on the beeb FE05 on the Elk
and of course version number
substitue the addresses it really does only take a couple of hours for that
a saturday afternoon to make some sideways ram out of odds and ends i had around
purchase J.Welch's ADFS explorer
copy a load of games on to CF card
spend a week playing games
then post here
AlanD
AlanD
Postby AlanD » Wed Jun 24, 2009 10:12 pm
Hello Mark
it should be possible to make it work in a master so long as ifj bit is set in ACCCON register and the masters cart clock selsct is set to 16MHz optoin
if ifj is not set i sure it would possible to patch 1.53 to do this
also i agree about the case thing i have been looking at the usual suspects sites rs farnell etc to see if i can find a small box i can shoehorn it in to
AlanD
AlanD
Postby AlanD » Wed Jun 24, 2009 10:16 pm
Hello Arcadian
you are right i will look at changing the version numbers to have an E suffix or something like that
let me know if you really do want one it may be possible for me to sort that out
AlanD
Elk Towers
Postby Elk Towers » Wed Jun 24, 2009 11:26 pm
Can I have one as well please.
Is it possible to put a laptop ide hdd on that instead of the memory card?
Nick
sorvad
Postby sorvad » Thu Jun 25, 2009 6:53 am
It's become scary the talent we have on here hasn't it ! :D :D :D :D
AlanD
Postby AlanD » Thu Jun 25, 2009 3:58 pm
Hello corelki2005
yes it should work with any IDE drive obviously a laptop has a 44 way ribbon cable so it would need some sort of adapter (44way to 40way) also probably would need an external or alternative power supply don't think the standard elk one is really upto a harddrive i will have a looksee and post back when i have tried it
AlanD
Elk Towers
Postby Elk Towers » Thu Jun 25, 2009 4:02 pm
Cheers Alan
have got an adaptor for laptop hdds
because of the add ons I already run, I use an old AT PC power supply, so I have all the correct power connectors. :D
Nick
Postby CMcDougall » Mon Jul 06, 2009 10:18 am
Arcadian wrote:Woah! :shock: I want one!
2nd that =D>
well done AlanD :D
AlanD
Postby AlanD » Thu Jul 16, 2009 4:07 pm
Hello All
now i am back from my holidays i have got back to the projects
i have got most of the bits i need so i will be looking at populating the remaining 8 IDE interface pcbs in the next week or 2 also i have found a much easier way to implement a sideways ram in the plus1 so it can be used with page E00 dfs
i will take some pics and post them over the next couple of days
Alan
Postby CMcDougall » Fri Jul 17, 2009 8:09 am
AlanD wrote:implement a sideways ram in the plus1 so it can be used with page E00 dfs
well done Alan =D> if DFS, i need one, just like another holiday!!
AlanD
Postby AlanD » Fri Jul 17, 2009 2:51 pm
Hi CMcDougall
sorry i made a typo it is not DFS i have Advanced DFS (ADFS) that runs from swr and page is &E00 , i have downloaded and over 100 DFS images from STH disk archive and have them running with little or no problems
Aland
AlanD
Postby AlanD » Fri Jul 17, 2009 5:53 pm
hello all
Heres a bit of progress report have completed a few ide cards also heres a pic of them and my tidier swr solution which uses slot 13 basicllay mostly it is piggy backed on the plus1 rom except four pins which are ce rw and a13 wired to the bottom of a cart socket
Aland
AlanD
Postby AlanD » Fri Jul 17, 2009 7:46 pm
Hello some more swr mod details
firstly i removed the vanilla plus1 rom
got a 27c256 blew slogger 2.02 @ H0000 and H2000 and H4000 and H6000
because i am to lazy to work out which of the 8k offsets it addresses
i got an hm62256
bend out pins 20,22,26,27
piggy back it on the 27c256 solder all pins except the above 4
link pins 20,22 then link these to B10 cart slot
pin 26 (a13) link this to A6 on cart slot
pin 27 (wr) link this to A8
any questions or unsure just ask
AlanD
i know i have wasted 16k in the ram but it is the cost of a tidy mod
Elk Towers
Postby Elk Towers » Sat Jul 25, 2009 1:47 pm
Got mine today 8)
here are some pics
with it installed and powered up
all the files in the adfs folder
with elixir started
very quick on loading
Very well done Alan =D>
Nick
sorvad
Postby sorvad » Sun Jul 26, 2009 8:45 am
Looks really good, another thing for my (eventually I'll buy one list !)
Postby CMcDougall » Tue Jul 28, 2009 8:42 am
lookin good :)
Postby CMcDougall » Fri Jul 31, 2009 12:38 pm
so, how do i get all the .ads/l/m discs onto the CF card? can i use my PC as it does have a CF reader on the front of it, so that will save £1 for a card reader!
or do i do everything on the elk side? ie load tapes/DFS discs, and transfer them over to ADFS and put the files all in a game folder? i have a 'new' Phoenix DFS board for plus1 cart, with a spare ROM socket =D> , so ADT1.41 rom will be going in there, and can use the commands on that to transfer over!
thanks for the offer by the way Alan, its like Deal or no-deal on here nowadays! :lol:
AlanD
Postby AlanD » Fri Jul 31, 2009 3:08 pm
Hello Colin
I used Jon Welches DFS explorer to extract the DFS games from the DFS disk images (mainly ssd images on STH) to my PC harddrive which you can do without paying registration.
and then used adfs explorer which costs about £5 to register to copy them into an adfs image this needs to registered as that enables saving images and once this image is stored. there is a utility called cfrestore to copy this image to a cf card
i have no idea if the tape2disc roms will work with my interface as i have not tried any of these
thats about it
AlanD
irrelevant
Postby irrelevant » Fri Jul 31, 2009 5:37 pm
AlanD wrote:I used Jon Welches DFS explorer to extract the DFS games from the DFS disk images to my PC harddrive and then used adfs explorer to copy them into an adfs image
You realise that if you have them both open, you can just drag from one into the other .... much easier :-)
Postby CMcDougall » Mon Aug 03, 2009 8:35 am
AlanD wrote:a utility called cfrestore to copy this image to a cf card
where do i get that? a quick google gives me a torrent site, which i hate! can you upload it here, so i can try it out.
You say 'image' not images, so is it one 'big' file (like superMMC card)? ie with all the images in it? or does it just take all the single game files and stick them in a directory?
I have A/DFS explorer from Jon, but version2 does not work on my new PC as it aint got the same Computer ID# as old PC :twisted: , but i can use the older versions that are without Xfer51 and txt read in them. Plus ive already got 200mb+ of .adf 300kb files already =D> .
won't need it, as they are all hacked anyways, also PAGE is @E00, so thats the main battle won!
retroclinic
Postby retroclinic » Mon Aug 03, 2009 1:12 pm
JW wrote CFBACKUP and CFRESTORE for me when I first developed the CF kit for the Beeb, and we had a distribution agreement as I would ship those utils free with a copy of ADFS exloprer and the hardware, so people would register the main software.
The programs are (C) by JW, so I would just check with him before distributing them with another system. I have no issues with them being used with another system myself, and I can't see him having a problem, as he'll still get more ADFS registrations from it, but it's a curtosey to ask.
Mark.
AlanD
Postby AlanD » Mon Aug 03, 2009 5:52 pm
Hello Mark
I will certainly ask Jon Welch i would not intentionally distribute anything without permission
AlanD
Update
I have asked Jon Welch's permission and he says he is happy for me to bundle ADFS/DFS explorers and the cf utils in the same way you are Mark Again thanks for pointing out an oversight on my part.
AlanD
Elk Towers
Postby Elk Towers » Wed Aug 12, 2009 7:52 pm
Here is my elk with a hdd attached :D :D :D :D
All I have to do now is fill it up :D
Nick
AlanD
Postby AlanD » Wed Aug 12, 2009 8:08 pm
Hello Nick
Thanks for the pic Nick
i must say a big thank you to Nick for his patience whilst i fixed his disk interface.
i have now ironed out a problem that the cf cards / harddrives could not always be read in an elk that had alot of expansion (ie MRB and sideways memory board)
Nicks machine has just about every expansion there is
i have added a data bus buffer to the disk interface this seems to have fixed it
AlanD
Elk Towers
Postby Elk Towers » Wed Aug 12, 2009 8:17 pm
Alan
you have mail.
Nick
Users browsing this forum: dominicbeesley and 2 guests
