MMC card interface
Re: MMC card interface
Postby MartinB » Wed Apr 27, 2016 3:56 pm
Daniel wrote:It's 115200 bps...
That sounds very precise for the MMC synchronous SPI, are you mixing it with UPURS? (Which is 115k)
(I don't have the MMC stuff so you could well be right bw - it just sounded a bit precise :) )
Postby CMcDougall » Wed Apr 27, 2016 4:21 pm
When the MMC is active, the shift lock led on the keyboard flashes..... Take wires from that :?
waltermixxx
Postby waltermixxx » Wed Apr 27, 2016 5:24 pm
lol I never noticed the shift light flashes with the mmc,
I've always just staired at my MMC ( the previous one i made had an activity light (adafruit sd breakout) ....
I think that's fine... I just wanted some kind of indicator,
that seems to be sufficient... Heck' I'll just look at the shift led. :) ...
sorry folks...
Postby daveejhitchins » Thu Apr 28, 2016 8:36 am
What you need is something to 'detect' the fast TTL logic level: Maybe a series capacitor, followed by a resistor to 0V and then a diode to rectify and produce a 'trigger' for a multivibrator circuit that would flash your LED at a speed you can see!
waltermixxx
Postby waltermixxx » Thu Apr 28, 2016 10:31 pm
Thank you. Just what I needed. :0)
Thanks again eh!!!
nudelooney
Postby nudelooney » Fri Apr 29, 2016 8:09 am
waltermixxx wrote:Thank you. Just what I needed. :0)
Thanks again eh!!!
I'd very much like to see a diagram of the circuit you finished up with! My solution would have been something complicated involving taking the MSB of a binary counter - yours sounds much simpler!
Postby tricky » Fri Apr 29, 2016 8:21 am
nudelooney wrote:... My solution would have been something complicated involving taking the MSB of a binary counter ...
Mine too, with some king of r resister capacitor pair building up charge to reset the counter when activity ended. I have near 0 electronics knowledge :shock:
waltermixxx
Postby waltermixxx » Sun May 15, 2016 1:32 am
ok, so i managed to get 4 micro SD cards, and printed a little case for it. :)
attached a zip of the STL :)
here is a link to more pictures:
https://www.flickr.com/photos/66577016@ ... 016667415/
microsd.zip
(950 Bytes) Downloaded 29 times
Postby 1024MAK » Sun May 15, 2016 2:01 am
daveejhitchins wrote:What you need is something to 'detect' the fast TTL logic level: Maybe a series capacitor, followed by a resistor to 0V and then a diode to rectify and produce a 'trigger' for a multivibrator circuit that would flash your LED at a speed you can see!
A 555 timer may be able to do this.
Fwapp
Postby Fwapp » Sun Jun 12, 2016 5:55 pm
Hello - I've got some Acorn time coming up and I'd like to get my SD card thingy up and running on my Iss.7 BBC B
From reading the previous pages, am I right in thinking that:
I take the SUPERMMC.ROM and burn it to one of these-
and then plonk the PROM in my BBC? Any particular ROM socket?
I then take the files from here viewtopic.php?f=3&t=8176#p87705, plonk them onto a SD card and then put it in this-
and then connect to the user port on my Beeb?
Acorn Atom (iss.4[WIP]) AtoMMC V2.0, BBC B (iss.7) Sir Morris SD Card and MMFS 1.27, Acorn Electron (iss.4), A3000
Postby sydney » Sun Jun 12, 2016 7:54 pm
Yes, but I'd recommend using the latest version of mmfs which I think is 1.27. Or smartspi.
Fwapp
Postby Fwapp » Sun Jun 12, 2016 8:02 pm
Thanks - would you happen have a link to the latest mmfs?
Scrub that :D Is this it linked here? viewtopic.php?f=3&t=10621&start=270#p135847
Postby hoglet » Sun Jun 12, 2016 8:08 pm
Fwapp wrote:Thanks - would you happen have a link to the latest mmfs?
Yes, the latest version, 1.27, is at the bottom of that post.
Fwapp
Postby Fwapp » Sun Jun 12, 2016 8:09 pm
Perfect - thanks Dave.
Time to fire up the Mini-pro :)
Postby DutchAcorn » Sun Jun 12, 2016 8:22 pm
Fwapp wrote:Perfect - thanks Dave.
The BBC has 16K sockets, the EEPROM you referred to is a 32K EEPROM. If you burn the (16K) image it should go in the top half of the 32K iirc. Or simply put it in there twice :wink:
Fwapp
Postby Fwapp » Sun Jun 12, 2016 8:25 pm
Nice catch! I'll double the file up - dos command line here I come!
Fwapp
Postby Fwapp » Mon Jun 13, 2016 2:06 pm
Up and running! Thanks gentlemen :)
I'm very, very new to the BBC so assuming that *DBOOT0 is the correct command to start the menu?
Postby hoglet » Mon Jun 13, 2016 2:09 pm
Fwapp wrote:Up and running! Thanks gentlemen :)
On the Model B, Shift-Break should work.
On the Master, you might need to do a Ctrl-Shift Break.
Fwapp
Postby Fwapp » Mon Jun 13, 2016 2:36 pm
Yep - that works here :D
mm67
Postby mm67 » Tue Jun 28, 2016 10:04 am
Couldn't resist having one last go at improving the ROM - so here is "Ultra DFS".
It's based on a slimmed down version of MMFS 1.00 (the original version), with its limitations i.e. no SDHC/FAT32/Turbo etc.
But one big improvement is: You can use real disk drives too!
If the floppy disc controller is present, by default all drives are 'Real'.
You can use *DIN and *DOUT to insert/remove 'Virtual' disks.
So, say drive 0 is 'real', and you want to backup a real floppy to a virtual one:
1) Insert the floppy in drive 0
2) Insert the virtual disk in drive 1, e.g. *DIN 1 25
3) *BACKUP 0 1
Voila
The *DDRIVE command has a 'R' or 'V' after the drive number to show its state (Real/Virtual).
Notes:
1) There are three versions of the ROM: 1.20 for 8271 beebs, 2.26 for 1770 beebs and 2.24 for the Master.
2) If the FDC is present by default all drives are real and Ultra DFS should appear no different to the normal DFS, until you use a command that implies access to the MMC/SD card is required, e.g. *DIN.
3) If the FDC is not present, drives 0 to 3 by default contain virtual discs 0 to 3 (like MMFS).
4) You can temporarily disable the FDC by pressing X-Break (followed by a Ctrl+Break to reset the drive states).
To fit all this in one ROM some things had to go, e.g. the SRAM utilities, *MAP/*FREE etc., but you do get *FORMat/*VERIFY/*ROMS in 1.20.
I've used BeebEm to develop/check the code was working - but that doesn't mean it works properly on real hardware as I found when I finally tried it on my real beeb where a few bugs revealed themselves.
I HAVE ONLY BRIEFLY TESTED VERSION 1.20 ON MY BEEB.
FOR THAT REASON THE ATTACHED ROMS ARE FOR TESTING PURPOSES/CURIOSITY ONLY!
I DO NOT INTEND TO MAKE ANY MORE CHANGES TO THIS CODE (UNLESS I FIND A BUG MYSELF) - FEEL FREE TO ADAPT TO YOUR NEEDS.
Happy coding
Martin
BeebEmDLL2.zip
mmbeeb2.dll file + source
(55.15 KiB) Downloaded 25 times
UltraX asm files.zip
asm files
(123.47 KiB) Downloaded 27 times
UltraX batch files.zip
batch files
(1.64 KiB) Downloaded 24 times
UltraX ROM images.zip
ROM images
(68.84 KiB) Downloaded 37 times
mm67
Postby DutchAcorn » Tue Sep 20, 2016 6:04 am
This sounds very elegant, I love the real & virtual combo! =D>
I finally found some time to actually give the 1.20 version a go in my BBC B (8271 interface).
My real floppy drive works but if I try a *DIN command (eg. *DIN 3 6) I am greeted with the "Card?" error.
If I switch back to SmartSPI I can access the card again.
The same error occurs when I try the rom in BeebEm (BBC B mode) with the MMBeeb FDD interface enabled.
Has anyone else experimented with this yet?
Postby DutchAcorn » Sat Oct 01, 2016 8:53 pm
DutchAcorn wrote:This sounds very elegant, I love the real & virtual combo! =D>
Ok tried a few more options. Master version: no joy (Card?)
I found that the original MMFS 1.00 that this was based on gives the same error on my configuration. The card I use is FAT16, and SD (not SDHC). The original MMBDFS and SuperMMB work fine with this (99P) reader and card.
What other known limitations does MMFS 1.00 have that I could look at?
Thanks!
Postby hoglet » Sat Oct 01, 2016 9:46 pm
DutchAcorn wrote:I found that the original MMFS 1.00 that this was based on gives the same error on my configuration. The card I use is FAT16, and SD (not SDHC). The original MMBDFS and SuperMMB work fine with this (99P) reader and card.
What size is the card?
Are you 100% sure it is FAT16?
Postby DutchAcorn » Sat Oct 01, 2016 9:52 pm
The card is 1GB.
Pretty sure it is FAT16. Iirc SuperMMC also does not work with FAT32 and SuperMMC works fine on these cards.
If I try to reformat windows shows FAT as the default option.
Postby hoglet » Sat Oct 01, 2016 9:59 pm
It's very strange that it works with SuperMMC but not with MMFS 1.00. My understanding was they had the same limitations, because the SD Card initialization code was essentially the same. Only later did Duikkie add support for SDHC and FAT32, and I merged those changes back into later versions of MMFS.
Just to avoid doubt, where did you get MMFS 1.00 from?
With MMFS 1.00, is the error "Card?" or "Card format?"
Are there other files on the card, or just BEEB.MMB?
If you have a way of imaging the card, I'd be happy to take a look (I like mysteries like this!)
duikkie
Postby duikkie » Sun Oct 02, 2016 6:35 am
if it works with the old super rom , it must be fat16/ byte access and beeb.mmb in first 8 names table
itmeans cmd0, cmd1.
Thanks!
Postby DutchAcorn » Sun Oct 02, 2016 7:39 pm
hoglet wrote:It's very strange that it works with SuperMMC but not with MMFS 1.00. My understanding was they had the same limitations, because the SD Card initialization code was essentially the same. Only later did Duikkie add support for SDHC and FAT32, and I merged those changes back into later versions of MMFS.
Thanks for taking the trouble Dave. :D
The MMFS 1.00 was from here.
The error is "Card?"
BEEB.MMB is the only file on the card. I placed a zipped image of the card on my dropbox account. The image was made using Win32DiskImager.
simonc
Postby simonc » Sun Oct 02, 2016 9:49 pm
Thanks are due for the ongoing work on MMFS. This weekend my "99p for 2" Micro SD adaptor modules turned up from China so out came the breadboard and patch wires, plus an old user port ribbon cable and a £2 SD card. After a lot of faffing around transferring SuperMMC onto disk - I've no EPROM programmer, RS232 ports or PCs with floppy interfaces in the house and was reduced to loading MMFS into BeebEm, saving it as a UEF, then using MakeUEF to turn it into a WAV for playback at maximum volume using Audacity. I'd forgotten how awful using tape can be when the levels aren't right. I thought I'd seen that last of data? rewind tape messages behind in 1988 when we finally got a disk drive. Anyway, turns out SuperMMC doesn't work with this particular type of card, so I had to do it all over again (BEEP data? rewind tape) with the latest version of MMFS. Then it worked 8)
For reference, the adaptor is another one of the the Catalex cards that looks like this:
Next job, find a suitable plug for the card in the box of bits and bobs in the attic and attach it to the user port cable in the right configuration.
One request, please could the MMFS zip file have subfolders called UserPort and MemoryMapped (or BeebEm if that's the only thing that uses memory mapper currently), to make things a bit more obvious! It's not easy googling for the meaning of M.
(28.27 KiB) Not downloaded yet
(26.84 KiB) Not downloaded yet
Postby hoglet » Mon Oct 03, 2016 11:20 am
DutchAcorn wrote:Thanks for taking the trouble Dave. :D
I've has a quick look at this. The image seems correct, and is definitely FAT16.
The Card? error definitely points the finger at your card. Looking at the MMFS 1.00 initialization code, the only way this error is generated is if the MMC_INIT routine fails. This attempts to put the card in SPI mode, and then sends CMD0 and CMD1. It doesn't look at the contents of the card.
Is there any chance this card could be a fake (i.e. a larger SDHC card that has just been reformatted to a small capacity)?
Do you have another small (2GB or less) card you could try?
Postby DutchAcorn » Mon Oct 03, 2016 11:53 am
Thanks for checking! :D
It is not unlikely the cards I use are fake Sandisk cards (they come from China). I don't currently have other low capacity cards to try, I'll get some and try again.
It's unlikely to be an SDHC card; SuperMMC should fail on one of those, right?
Return to “hardware”
Users browsing this forum: Yahoo [Bot] and 9 guests
