MMC card interface
duikkie
Re: MMC card interface
Postby duikkie » Mon Oct 03, 2016 12:02 pm
you never know about cards :) , maybe some SDHC are back ward competble , if cmd1 give respons then supermmc will work. all the cards and the specs :)
DutchAcorn wrote:
hoglet wrote:
DutchAcorn wrote:Thanks for taking the trouble Dave. :D
The MMFS 1.00 was from here.
The error is "Card?"
BEEB.MMB is the only file on the card. I placed a zipped image of the card on my dropbox account. The image was made using Win32DiskImager.
I've has a quick look at this. The image seems correct, and is definitely FAT16.
The Card? error definitely points the finger at your card. Looking at the MMFS 1.00 initialization code, the only way this error is generated is if the MMC_INIT routine fails. This attempts to put the card in SPI mode, and then sends CMD0 and CMD1. It doesn't look at the contents of the card.
Is there any chance this card could be a fake (i.e. a larger SDHC card that has just been reformatted to a small capacity)?
Do you have another small (2GB or less) card you could try?
Thanks for checking! :D
It is not unlikely the cards I use are fake Sandisk cards (they come from China). I don't currently have other low capacity cards to try, I'll get some and try again.
It's unlikely to be an SDHC card; SuperMMC should fail on one of those, right?
Postby hoglet » Mon Oct 03, 2016 12:23 pm
DutchAcorn wrote:It's unlikely to be an SDHC card; SuperMMC should fail on one of those, right?
Yes, an SDHC card should fail on SuperMMC.
I've just compared the source code of MMFS 1.00:
http://www.stardot.org.uk/forums/viewto ... 339#p49437
and SuperMMC:
https://swhs.home.xs4all.nl/bbc/mmbeeb/DFS4C/DFS-4C.ssd
The MMC initialization code is not identical, but it looks like both versions should be exercising the card in the same way.
So it still doesn't make sense that you have a card that works in SuperMMC but not MMFS 1.00.
The SuperMMC ROM you are using is the original version, not one that Dukkie further developed?
Postby DutchAcorn » Mon Oct 03, 2016 1:12 pm
Yes, an SDHC card should on SuperMMC.
The SuperMMC ROM image I used comes from this site: https://swhs.home.xs4all.nl/bbc/mmbeeb/. The original DFSMMB rom also works fine with these cards and comes from the same location.
Can it be related that SuperMMC works on BeebEm (with the modified FDD interface definition) but MMFS does not?
Postby hoglet » Mon Oct 03, 2016 1:56 pm
DutchAcorn wrote:Can it be related that SuperMMC works on BeebEm (with the modified FDD interface definition) but MMFS does not?
I think that's a different issue.
BeebEm emulates a memory mapped SPI interface (at FE08) and the original MMC ROMs check for both this and a user port interface.
I added support for BeebEm back into later versions of MMFS (separate M and U builds)
So still a bit of a mystery!
Postby DutchAcorn » Sat Oct 08, 2016 1:50 pm
Today I received a batch of used 2GB Sandisk cards. They are from a UK seller and I am quite sure they are genuine. Same symptoms with these cards though. Next thing to try is a different type of SD card reader, I am currently using these. Anyone else here who successfully used the original MMFS with these 99P cards?
Postby CMcDougall » Sat Oct 08, 2016 3:20 pm
^yes :D
but 99p is a bit steap 8) I just got 5 for £2.06 Inc P&P :)
I think the issue you have with the other UltraDFS /Card? thing is the speed the MMC takes to find it, thus needed to be put up (at start of this thread!) unless you have old MMC memory cards, then may work....(my one never did)
I find formatting SD cards to FAT in any PC>winXP are crap, ie take 10mins to format wrongly. I use my desktop WinXP machine or old laptop with WinXP on it, was win98., & takes 2seconds :shock:
Postby DutchAcorn » Sun Oct 09, 2016 9:48 am
CMcDougall wrote:I think the issue you have with the other UltraDFS /Card? thing is the speed the MMC takes to find it, thus needed to be put up (at start of this thread!) unless you have old MMC memory cards, then may work....(my one never did)
Thanks! I just re-read the start of the thread but I have trouble finding what you refer to. :oops: Do you mean it could be that MMFS 1.0 is compatible only with MMC cards and not SD cards?
If not, just to eliminate possible causes, can you confirm you have successfully used one of these modules?
CMcDougall wrote:I find formatting SD cards to FAT in any PC>winXP are crap, ie take 10mins to format wrongly. I use my desktop WinXP machine or old laptop with WinXP on it, was win98., & takes 2seconds :shock:
I use a separate formatter (SDFormatter 4.0) on Windows or use MacOS to format FAT16.
Postby CMcDougall » Sun Oct 09, 2016 10:13 am
DutchAcorn wrote:Do you mean it could be that MMFS 1.0 is compatible only with MMC cards and not SD cards?
yes, that's what I meant, some code had to give it more time to find a SD card, less for a MMC card.
that's the 40p card's I have, just checked this very moment with MMFS1.21 as get all mixed up with all interfaces / beebs on floor :shock:
here's a pic:
41p micro card
I always use SanDisk as not had much luck with Toshiba etc SD cards...
Postby DutchAcorn » Sun Oct 09, 2016 12:16 pm
here's a pic:
I use the same configuration. I just tried MMFS 1.18 with this card and card reader, and that works fine. Can you use MMFS 1.0 with the card & card reader in the photo?
Postby CMcDougall » Sun Oct 09, 2016 12:29 pm
^whats MMFS 1.00?? is that not just the first buggy one before DaveB /Hoglet ironed out all the bugs to v1.21?? or do you mean the UltraDFS that Mr Mathers just put up a page back?? :? if so not had time to play :(
Postby DutchAcorn » Sun Oct 09, 2016 12:57 pm
CMcDougall wrote:^whats MMFS 1.00?? is that not just the first buggy one before DaveB /Hoglet ironed out all the bugs to v1.21?? or do you mean the UltraDFS that Mr Mathers just put up a page back?? :?
Well, I started off with UltraX DFS and failed. Then I read in the UltraX post that Martin based it on the initial MMFS 1.0 (yes, the version that Dave started work on).
So I tried to get that to work using different MicroSD cards.
CMcDougall wrote:if so not had time to play :(
Alternatively: did you manage to get UltraX DFS to work with the Catalex adapter and a SanDisk MicroSD card?
Postby CMcDougall » Mon Oct 10, 2016 9:21 pm
DutchAcorn wrote:did you manage to get UltraX DFS to work with the Catalex adapter and a SanDisk MicroSD card?
just had a go of this, with a beeb with 1770FDC & DFS2.26
used the files per mm67/MartinMather being >Ultra X ROM images/ ULTRA226 & U226UP
ULTRA226 does not work
U226UP does work, but did'nt initalise with just *DIN 0 0
per Martin was to use CTRL-X-Break, this then shows up on banner, and can *. from SD card
*DDRIVE shows the V after each drive number, but can't get it to do the R for real discs, or have both going together :?
but as Martin said, he only tries with his 8271FDC & DFS1.20
might try 8271 beeb another night, as going to bed :shock:
Postby DutchAcorn » Tue Oct 11, 2016 7:29 am
CMcDougall wrote:used the files per mm67/MartinMather being >Ultra X ROM images/ ULTRA226 & U226UP
I just found from the asm files that the ULTRA variants are probably memory mapped and that the UP variants are probably User Port variants. I've been using the ULTRA variant so that may be why it is not working :oops: :?
Hope to be able to check this tonight.
Postby daveejhitchins » Tue Oct 11, 2016 8:26 am
CMcDougall wrote:might try 8271 beeb another night, as going to bed :shock:
With a post time of 9:21 :shock: Pussy :lol:
Dave H :lol:
TopBanana
Postby TopBanana » Tue Oct 11, 2016 4:22 pm
Dave H :lol:
Oooooo that's harsh Donkey Dave, 9:21pm is sometimes classed as an all night rave at Top Banana Mansions :shock:
Postby DutchAcorn » Tue Oct 11, 2016 7:03 pm
That was it! The UP variant ROM I used was corrupted (FS manager is not always reliable), that did not help.
Attached are the UP variants of the ROM in an SSD image; the ones to use on real hardware.
One thing I found is that, to use this, you cannot have an other MMC FS real DFS in a higher priority ROM socket. If so, it will not access the physical disc drive but will default to MMC. I used it on a model B with a 8271 interface.
I am very pleased with the combination of physical drive and virtual discs, it works great! =D> =D> =D>
ultrax.zip
(54.26 KiB) Downloaded 27 times
lazarusr
Postby lazarusr » Sun Oct 16, 2016 11:13 am
I have an issue which I am unable to understand, let alone look at solving.
I have an MMB file with two SSD images on it (in positions one and two). When I try to use this on my Model B, the first file, on the first image is OK. However, the remaining files on that image are totally corrupted (large blocks of &00 and &FF, with occasional random bytes thrown in). The second image doesn't appear to have any files on it at all.
I have tried three different card readers, all with the same result. I have the same results using one of the latest builds of the MMFS rom and also with the latest build of SmartSPI. With the latter, I have also tried connecting to different data pins on the User Port, again with the same result.
Over on Windows, I have done a full reformat of the SD card (using the official formatter from the SD Association). The disk images were built with BeebASM. But I have tried creating a new image on BeebEm and then copying the files across. Using MMBImager, I can extract images direct from BEEB.MMB on the SD Card and then load them into BeebEM where all the files are fine. Likewise, I can use DFSImager to extract individual files and examine them too - they are, again, all fine.
All this suggests to me that the problem is with the User Port or the 6522. However, if I put the image on a USB stick, I can use my DataCentre (via the Beeb) to import it directly to one of the slots on the SD card. When I do that, everything is just fine.
So every element of the process seems, individually, to be working fine - yet the problem remains. I would really welcome any suggestions.
sweh
Postby sweh » Sun Oct 16, 2016 2:44 pm
My guess would be a sector size issue... If you format from scratch, then import via USB and DC and then look at the results on the PC, does it still look good?
Rgds
Stephen
lazarusr
Postby lazarusr » Sun Oct 16, 2016 3:53 pm
sweh wrote:My guess would be a sector size issue... If you format from scratch, then import via USB and DC and then look at the results on the PC, does it still look good?
No! The image that was created on the Beeb now has the same, corresponding, problem on the PC in that all bar one of the files are large blocks of &00.
sweh
Postby sweh » Sun Oct 16, 2016 4:40 pm
That definitely sounds like a "size" issue, somewhere. What SD card are you using? Might it be a SDHC or similar?
We see similar with CF cards. In that case the Beeb only uses the first 8 bits of a 16bit wide word so for that we need to pad every other byte when working on a PC.
Rgds
Stephen
lazarusr
Postby lazarusr » Sun Oct 16, 2016 4:45 pm
It's a (genuine) SanDisk 1GB Micro SD card. I have been using it for ages in the Beeb without a problem. This issue only arose today (albeit after a format).
Postby DutchAcorn » Mon Oct 17, 2016 8:27 pm
lazarusr wrote:It's a (genuine) SanDisk 1GB Micro SD card. I have been using it for ages in the Beeb without a problem. This issue only arose today (albeit after a format).
To rule out formatting issues you are welcome to try the 1GB image I have on my dropbox account. You can use Win32DiskImager to write it to the card.
Postby CMcDougall » Sun Oct 30, 2016 3:41 pm
DutchAcorn wrote:you cannot have a real DFS in a higher priority ROM socket. If so, it will not access the physical disc drive but will default to MMC. I used it on a model B with a 8271 interface
just tried this on my Acorn 1770FDC with DFS2.26 (inD, MMC inE), and it now *'works'*, as now shows 0 V 1,2,3 R
but when going back to actual disc, ie drive 2 (also tried 1&3), it just gives "Disc error x"
so would presume the same with the M128 DFS2.24 version too.
still to try the 8271FDC beeb with DFS1.20, but you say works for you, so proberly does.
duikkie
Postby duikkie » Tue Jan 10, 2017 10:11 pm
i did make this one , two things , first the board is 1 mm thickens then the space between the flatcable pins.
second it is not very robust.
so i was thinking why not put the hole in a resin bath . like selvo kristal polyester xor resin. but as dutchman i found it very expensive :roll: ,
so question . will every polyester or resin do ? what is very ,very cheap #-o
DutchAcorn wrote:
skinnymathew wrote:Success with my 99p card.
That inspired me to do this:
And I was amazed to find it worked right away, sheer luck given the quality of my soldering. :oops: :D
Postby tricky » Sat Dec 02, 2017 3:55 pm
Did anyone say for sure if there is any danger when connecting CB1 directly to PB1?
I've looked around and having had a problem on a couple of my beebs, I was wondering if this might have been a contributing factor, when combined with badly behaving software.
Would it be better to connect them with a resistor? (I like resistors :))
If so, 10K is my resistor of choice, but maybe someone has an answer based on something more that I like 10K :roll:
Postby CMcDougall » Sat Dec 02, 2017 4:35 pm
^no danger at all, my 10x 33p china cards running on all my beebs /elks /masters /compact with no problem! :D
KenLowe
Postby KenLowe » Fri Jan 26, 2018 10:49 pm
Thought I'd also have a go at building my own interface using the microsd board from China. To keep the wiring neat, I decided to remove the 6 pin 90deg header that was supplied with the microsd board and replace it with an equivalent 90deg header that had two rows of pins. I then removed all but one of the pins from the upper row, so that there are two pins at the sck location of the card. I cut short this upper pin so that it was no longer trying to go through the microsd board, and soldered it to the lower pin. This gave me two connections for sck, which is needed by the beeb / MMFS. I then wired pins 2 thru 8 from the user port onto the new microsd board header. Working a treat with MMFS and a 16gb microsd card.
Pictures probably tell the story a bit better:
Edit: New photos showing card with new ribbon cable. The original ribbon I was using was actually too fat and didn't fit in the 20 way IDC correctly. I'm now using the correct ribbon, and it's working much better!
Postby tricky » Fri Jan 26, 2018 11:30 pm
Very neat.
Users browsing this forum: 1024MAK, 8bitkick, Baidu [Spider] and 2 guests
