Which pin on the Microvitec CUB socket is the composite in?
Commie_User
Postby Commie_User » Wed Mar 21, 2018 11:17 pm
I heard tell that it uses a composite-in for sync but that it views well enough through that alone.
If it does, would I connect my VCR, modded Atari 2600 or C64 straight to it?
dp11
Re: Which pin on the Microvitec CUB socket is the composite in?
Postby dp11 » Thu Mar 22, 2018 3:38 am
A standard cub doesn't do composite in. You need an extra Pcb which is rare.
Postby 1024MAK » Thu Mar 22, 2018 9:20 am
Don't get confused between composite sync and composite video.
Composite sync is a signal where the horizontal and vertical synchronisation signals are combined.
Composite video is a signal where the horizontal and vertical synchronisation signals are combined and a monochrome video signal is mixed in as well. If a colour encoding system is in use, such as PAL, NTSC etc, then the colour signal will be added also.
With some display systems, they are often happy with a composite video signal fed to their composite sync inputs. But the reverse does not work...
Commie_User
Postby Commie_User » Thu Mar 22, 2018 1:57 pm
Thank you.
crj
Postby crj » Thu Mar 22, 2018 4:41 pm
1024MAK wrote:With some display systems, they are often happy with a composite video signal fed to their composite sync inputs.
I believe other displays, especially ones from NTSC-land, are happy with composite video on their green input, because that's how "component video" works.
Postby 1024MAK » Thu Mar 22, 2018 9:16 pm
Ahh, but that would then be RGB with sync on green (SoG or RGsB) (as opposed to RGB with separate sync input (RGBS) or RGB with separate H and V sync inputs (RGBHV)). See here.
Some of the 625 line 15625Hz 50Hz monitors at my work use RGB SoG 8)
crj
Postby crj » Thu Mar 22, 2018 11:04 pm
Nono - I actually mean composite video on the green input.
In NTSC-land, YPbPr with sync on luma is the norm, rather than RGB with any of its syncing variants. Devices are often capable of accepting/emitting composite video on Y, instead of having a separate composite socket.
NTSC/PAL dual-standard devices usually map Y=G, Pb=B, Pr=R when handling RGB, which (a) means they'll also cope with PAL composite video on the Y/G socket and (b) is probably why PAL-land chose sync-on-green instead of sync-on-blue or sync-on-red.
Postby 1024MAK » Thu Mar 22, 2018 11:52 pm
crj wrote:Nono - I actually mean composite video on the green input.
Well, Y or luma is close to monochrome composite video...
crj
Postby crj » Thu Mar 22, 2018 11:56 pm
1024MAK wrote:Well, Y or luma is close to monochrome composite video...
Close? I thought it was monochrome composite video.
