Testing all 4 Ports on the New AP5
Re: Testing all 4 Ports on the New AP5
Postby daveejhitchins » Sat Mar 17, 2018 1:02 pm
hoglet wrote:Try running the test with this cable removed.
Sorry Dave, I missed this one, but did try without the cable in the end.
Postby 1024MAK » Sat Mar 17, 2018 1:41 pm
daveejhitchins wrote:Could I use one of the control pins to latch-out from Port B and Latch-in to Port A ?
Yes, I think there is (using one control pin to indicate new data and another control pin to receive thus signal), but as I don't use this mode very often, I'll have to go and eat the datasheet...
Postby CMcDougall » Sat Mar 17, 2018 1:58 pm
Just playing my AP5, mine is CPLD version 93 with P.~?&FCD7
So Port 1 is on the right for 33p MMC MMFS, just done a *FORM 80 0 (per hog let test) all is well!
Port 2 is on left for UPURS, & plays unzipped .UEF tape images perfectly too!! :D
Postby hoglet » Sat Mar 17, 2018 3:24 pm
Dave,
If you are trying to write a loop back test (with a cable connecting ports A and B) then you just need to do the following:
To test Port A as an output and Port B as an input:
?&FCB3=&FF: REM Set Port A as an output
?&FCB2=&00: REM Set Port B as an input
FOR X%=0 TO 255
?&FCB1=X%
Y%=?&FCB0
IF X%<>Y%:PRINT "A=>B: wrote ";X%;" read back ";Y%
NEXT
?&FCB3=&00: REM Set Port A as an input to be safe
To test Port B as an output and Port A as an input:
?&FCB2=&FF: REM Set Port B as an output
FOR X%=0 TO 255
?&FCB0=X%
Y%=?&FCB1
IF X%<>Y%:PRINT "B=>A: wrote ";X%;" read back ";Y%
NEXT
?&FCB2=&00: REM Set Port B as an input to be safe
Postby 1024MAK » Sat Mar 17, 2018 3:51 pm
Yeah, generally speaking you should set up the port for input first, then set up the port being used for output. Then you lessen the chances of two active outputs fighting one another.
Postby daveejhitchins » Sat Mar 17, 2018 4:16 pm
hoglet wrote:If you are trying to write a loop back test (with a cable connecting ports A and B) then you just need to do the following:
Thanks Dave, that's effectively what I'm doing - in a more complicated way :roll: I set the Ports up every time I do a Write and Read - then do the comparison in a procedural call. I'll ensure I follow Mark's instructions re Set-output-up-first. Then just go with what I have and see how it goes over the number I have to test.
Dave: I remember Simon changing the FPGA code, in association with a minor issue you found. I've not re-programmed, as yet! Will this have any impact if not carried out? Jonathan made change in the AP6 ROM, serial code issue. That's now in all future ROMs.
The 1 MHz Bus is easy to test: Either the BeebSCSImini works or not :wink: Now I have the UserPort Code working I may try and write a small BASIC program to run under Hi BASIC on the DE0-Nano - at least that should be quick :D
Thank you all for sorting this - Problem/niggle - not sure what to call it? Anyway it seems, after all, it wasn't a problem - just lack of understanding.
Postby hoglet » Sat Mar 17, 2018 4:23 pm
daveejhitchins wrote:Dave: I remember Simon changing the FPGA code, in association with a minor issue you found. I've not re-programmed, as yet! Will this have any impact if not carried out?
I don't think there will be any impact, as long as you are running AP5 CPLD version .94.
(It certainly won't affect the user port).
Postby daveejhitchins » Sat Mar 17, 2018 7:12 pm
hoglet wrote:I don't think there will be any impact, as long as you are running AP5 CPLD version .94.
Thanks, Dave . . .
