Using a ZIF socket for testing Chips in DIL board sockets
Postby 1024MAK » Sun Dec 03, 2017 11:07 am
The cheap textool and 3M clone sockets that you can get from China have rectangular pins and are impossible to fit into a turned pin socket. But if you apply a bit of force, they will push into a stamped pin socket. And then the stamped pin socket should fit in a turned pin socket.
Using a ZIF socket for testing a Z80 CPU
Using a ZIF socket for testing - socket pins highlighted
Using a ZIF socket for testing - side view showing socket stack
Using a ZIF socket for testing a 2114 SRAM chip
cmorley
Re: Using a ZIF socket for testing Chips in DIL board sockets
Postby cmorley » Sun Dec 03, 2017 11:46 am
I used 0.1" SIL turned pin male-male headers & soldered these directly to the cheap ZIF socket pins.
Push the headers into a turned pin DIP socket as a solder jig and solder header pin-zif pin from the side. You can then fit the whole lot into any socket on any project easily. I am away from home at the moment so can't post a photo of one... they aren't pretty but very functional. They get tall too but work fine while you're repgramming a PLD or regularly replacing and EPROM.
I prefer the turned pin SIL headers to the turned pins on DIP sockets because they are a smaller diameter so don't damage the springs on (crusty) old DIP sockets...
cmorley
Postby cmorley » Thu Dec 14, 2017 3:14 pm
I finally took a photo of one of my ZIF's I keep in the parts drawer. Fairly straightfoward to assemble and reusable.
They really do lift the ZIF quite a bit which is good for clearance of other components on the PCB.
Not as quick & easy as pushing it into a stamped socket though Mark.
Return to “hardware”
Users browsing this forum: BigEd, pbw72 and 4 guests
