Beeb Modem Cable
jjthacker
Beeb Modem Cable
Postby jjthacker » Sat Dec 02, 2017 12:14 pm
Does anybody have a wiring diagram for a beeb to 9 pin modem cable (not null-modem)?
Tried searching for this, but every link seems to come back with a null-modem cable, which is not what I need.
Thanks,
Jason
Re: Beeb Modem Cable
Postby danielj » Sat Dec 02, 2017 12:27 pm
http://www.cowsarenotpurple.co.uk/bbcco ... cable.html
You just need to make sure rx/tx go to tx/rx, and rts/cts go to cts/rts. If null isn't working, swap the rx/tx and cts/rts over on one end.
jjthacker
Postby jjthacker » Sat Dec 02, 2017 1:07 pm
Thanks for the reply, but the link seems to be for a null-modem cable, which is exactly what I don't want.
To convert to a regular modem cable do I just need to reverse the CTS/RTS lines? Or are there other cabling changes?
Postby danielj » Sat Dec 02, 2017 1:08 pm
Yes, and the rx/tx lines. Only on one side!
Edit: sorry, rd and td - basically the data receive and transmit lines.
Users browsing this forum: Telemedic and 6 guests
