What are these called?
dominicbeesley
Postby dominicbeesley » Mon Nov 27, 2017 11:37 am
The riser/header/dil plug/board to board connector things?
I'd like some for my experiments, but also to replace the broken ones on my WE 1770 boards (all have at least one missing pin!)
I've just spent an hour on RS and Farnell but don't seem to be able to find anything.
D
Re: What are these called?
Postby danielj » Mon Nov 27, 2017 11:51 am
They're sort of unobtanium - the standard method is to use some turned pin headers, then stack up turned pin sockets underneath to the right height.
Postby RobC » Mon Nov 27, 2017 12:37 pm
Samtec make them and call them APA adapter plugs.
Toby Electronics sell them but you have to contact them to get the right size:
https://www.toby.co.uk/datasheets/secti ... 2016103015
The 40-pin 0.6" version was called APA-640-T-N when I ordered some a good while back.
Postby danielj » Mon Nov 27, 2017 12:48 pm
Thanks Rob - what's the ballpark price for them?
Postby daveejhitchins » Mon Nov 27, 2017 1:05 pm
I may have some of these - Let me check and get back with details . . .
KenLowe
Postby KenLowe » Mon Nov 27, 2017 1:16 pm
This outfit is quoting for them @ £5.59 each (+ £12 shipping - or free shipping if your order is > ~£33). I'm guessing VAT will be on top:
https://www.digikey.co.uk/products/en?k ... PA-640-T-N
Postby RobC » Mon Nov 27, 2017 1:21 pm
danielj wrote:Thanks Rob - what's the ballpark price for them?
I'm afraid you'll have to call/email them. They were £2.99 each when I bought them but that was back in 2008!
Postby danielj » Mon Nov 27, 2017 1:30 pm
erk :D
Postby daveejhitchins » Mon Nov 27, 2017 1:31 pm
The ones I was thinking about are these:
Probably no good with a width of 0.3"!
But, courtesy, of Simon Inns, I have a few of these. They would need extra height e.g. other turned pin sockets (there're only 16mm high - top to bottom of pins!), however, that would be good to save damage to the delicate pins.
Let me know - Postage only!
dominicbeesley
Postby dominicbeesley » Mon Nov 27, 2017 1:42 pm
Yes please Dave, they look like they would work. I'll PM you.
I'll probably solder an socket upside down on the duaghter board anyway as I've had nothing but bother with these things.
D
dominicbeesley
Postby dominicbeesley » Mon Nov 27, 2017 1:48 pm
Thanks RobC for that part-number that's led to a few more avenues...
Digikey have them listed at £5.59 each and reckon a lead time of 18/12/17
D
dominicbeesley
Postby dominicbeesley » Mon Nov 27, 2017 1:56 pm
Farnell also have these http://uk.farnell.com/samtec/bbs-120-t- ... dp/1766246 single row jobbies but they're only 1.5cm of rise....
Postby crj » Mon Nov 27, 2017 3:25 pm
Personally, I'm looking for that kind of thing but as low profile as possible, not as high. Does anybody know of something cheaper and/or more available than the Precidip ones which cost about 5p/pin?
JannievanZyl
Postby JannievanZyl » Sun Dec 31, 2017 6:31 am
crj wrote:Personally, I'm looking for that kind of thing but as low profile as possible, not as high. Does anybody know of something cheaper and/or more available than the Precidip ones which cost about 5p/pin?
Could you not use these strips for a low profile jobbie?
dominicbeesley
Postby dominicbeesley » Sun Dec 31, 2017 4:30 pm
You "can" but I wouldn't for anything that I'm sending to somebody else. The square profile pins are a bit fatter than the smaller turned pins and tend to overbend the contacts in IC sockets rendering them unreliable on normal chips. I've spent a lot of time trying to fix beebs that turned out to just have dodgy sockets, often cause by me jamming in appropriately sized things into them! The newer sockets with springier stainless steel / shiny (not sure of the material) springs seem to take it better the older dull nickel/zinc finished ones seems to fair worse though that may just be due to age or more cycles.
D
Postby crj » Mon Jan 01, 2018 4:34 am
Also, most header pin strips aren't especially low profile.
Preci-dip round-pin headers space the board 3.5mm from the socket; I'd prefer a couple of mm less.
