Cheap SD/MMC Readers
Postby danielj » Mon Oct 23, 2017 8:26 am
This is a placeholder post for the latest versions of SmartSPI and MMFS. These are bugfixed and more up-to date file system ROMs that work with Martin Mather's MMC reader design, the TurboMMC hardware, and the cheap SD Card Readers available on ebay.
Latest version of SmartSPI: viewtopic.php?f=2&t=9208&start=150#p129221
Latest version of MMFS: https://github.com/hoglet67/MMFS/releases
With MMFS, you need to use the correct ROM version - see: https://github.com/hoglet67/MMFS/wiki/Release-structure
Wiring for SD reader to userport: viewtopic.php?t=1919&start=330#p99449
sirmorris
Re: Cheap SD/MMC Readers
Postby sirmorris » Mon Oct 23, 2017 8:47 am
If you don't want to solder or otherwise build your own adapter then a compatible inexpensive reader is offered for sale in the trading topic, other inexpensive compatible readers are available ;)
(Feel free to delete this post if inappropriate)
Postby danielj » Mon Oct 23, 2017 8:55 am
No, that's fine :D
Postby lurkio » Mon Oct 23, 2017 9:40 am
danielj wrote:Latest version of SmartSPI: viewtopic.php?f=2&t=9208&start=150#p129221
If it helps, here's the current latest version (1613) of the SmartSPI ROM-image as a raw data file (inside a zip file) -- and not on a .SSD disc-image:
(Scroll down to attachments to first post.)
Return to “hardware”
Users browsing this forum: nama and 12 guests
