Initialising PiTubeDirect
Galaxy High
Postby Galaxy High » Sun Oct 01, 2017 5:59 pm
Hello everyone,
Is anyone out there using the PiTubeDirect internal version?
Bit of a noob at this but tried using *fx151,230,# to try different cores but I can't seem to get it working.
I read I have to *CONFIGURE EXTUBE for internal tube but that doesn't seem to do anything.
Here's what the ST. is spitting out:
Baud 4
No Boot
Caps
Data 4
Delay 50
No Directory
Internal Tube
FDrive 0
File 9
Hard
Ignore 10
Lang 12
Mode 7
No Tube
Loud
Print
Repeat 1
Scroll
TV 0,1
...and the *ROMS *all unplugged apart from 11
F Terminal
E VIEW
D ADFS
C BASIC
B DFS 5A
A ViewSheet
9 DFS 79
8 DFS 5A
Thanks for looking,
Sam
BBC Masters 128
MMC Rom
OS Switch 1.20, 3.20 and 3.50
PiTubeDirect (Internal)
dp11
Re: Initialising PiTubeDirect
Postby dp11 » Sun Oct 01, 2017 6:02 pm
*con. tube
Then ctrl break
To enable tube
Postby danielj » Sun Oct 01, 2017 6:03 pm
*configure intube for the internal tube, then, as dp11 says, *configure tube to turn it on :)
d
Postby hoglet » Sun Oct 01, 2017 9:45 pm
danielj wrote:*configure intube for the internal tube, then, as dp11 says, *configure tube to turn it on :)
If you only have an internal Co Pro, and nothing external, it's actually more reliable to *CONFIGURE EXTUBE - see this post for why:
http://www.stardot.org.uk/forums/viewto ... 07#p146507
But as Dominic said earlier, *CONFIGURE TUBE is what's needed here.
Postby crj » Mon Oct 02, 2017 1:04 am
Also, where is the Tube Host System hiding on the Master? On the BBC Micro it was sneaked into the DNFS ROM, but that doesn't exist on the Master.
I'm wondering if anything needs to be *INSERTed.
Postby jgharston » Mon Oct 02, 2017 2:20 am
crj wrote:Also, where is the Tube Host System hiding on the Master? On the BBC Micro it was sneaked into the DNFS ROM, but that doesn't exist on the Master.
It's in the MOS, nothing needs to be INSERTed, as you can't UNPLUG the MOS.
Galaxy High
Postby Galaxy High » Sat Oct 07, 2017 1:58 pm
Sorry I've been late responding, it's been a busy week.
Thanks for all your replies.
Still not getting any joy. Going to open up the beeb and have a look at the PiZero.
I'll let you know what happens.
BBC Masters 128
MMC Rom
Galaxy High
Postby Galaxy High » Thu Oct 12, 2017 4:30 pm
Hello everyone.
Another busy week and only just got round to looking inside the beeb.
While trying to use *con.(figure) extube and *con. tube I noticed the pizero getting rather warm.
I saw a blob of solder on the pitubedirect pcb and removed it. Forgot to turn the beeb off and plugged it back in. :oops:
Burnt one of the tracers out so I've used a bit of ethernet to bridge it. (SK2 Pin 4 to JP1 Pin 2)
Still got the same problem though. PiZero still getting warm without initialisation.
Any help very much appreciated.
Thanx,
Sam
BBC Masters 128
MMC Rom
dp11
Postby dp11 » Thu Oct 12, 2017 9:03 pm
Can you post lots of photos of the setup?
dp11
Postby dp11 » Sat Oct 14, 2017 3:59 pm
Can you tell us about how the sdcard is setup ? You did unzip the PiTubeDirect files and put them all on a blank SDCard ?
Galaxy High
Postby Galaxy High » Sun Oct 22, 2017 1:37 pm
Hello again,
The SD card setup (from PiTubeDirect_Anaconda.zip)
bootcode.bin
config.txt
fixup_cd.dat
kernelrpi.img
kernelrpi2.img
kernelrpi3.img
kernelpibplus.img
kernelrpizero.img
LICENCE.braodcom.txt
README.txt
start_cd.elf
Here are my roms
This is the jungle
PiTubeDirect v1.3 with PiZero attached and bridge
Burnt out tracer :oops:
PiZero is still getting hot when plugged in and I can't initialise it.
This the method I'm using to test:
Acorn MOS
Turbo MMC
BASIC
>*CON. TUBE
>*CON EXTUBE
>*FX151,230,0
>*DIN45
>*TUBEELT
This program needs a 6502 Second Processor
I'm completely at a loss with this. Is it the way I have the SD card setup?
Thanx again for your help,
Sam
BBC Masters 128
MMC Rom
dp11
Postby dp11 » Sun Oct 22, 2017 1:55 pm
After the *con. tube command you need Ctrl-Break.
I would also try the Dimondback release.
PiZero shouldn't be getting warm I wonder if it damaged some way.
Galaxy High
Postby Galaxy High » Sun Oct 22, 2017 2:27 pm
Thanks for your reply.
Still no joy with the Diamondback release (or CTRL Break)
Think I'm going to order the parts myself and build from scratch. I paid someone for the complete package before so there could be a number of variables concerning problems.
Thanks for you help.
BBC Masters 128
MMC Rom
Postby danielj » Sun Oct 22, 2017 3:08 pm
What does it display after ctrl break?
Galaxy High
Postby Galaxy High » Sun Oct 22, 2017 3:10 pm
Just the same screen as without CTRL Break
Acorn MOS
Turbo MMC
BASIC
BBC Masters 128
MMC Rom
vanekp
Postby vanekp » Sun Oct 22, 2017 3:26 pm
What happened to the track that got replaced by a wire did you short circuit something, may be permanent damage to your Pi or the level converter board.
Can you try the Pi on its own to see if that works with Pi software.
Peter.
Galaxy High
Postby Galaxy High » Sun Oct 22, 2017 3:30 pm
vanekp wrote:What happened to the track that got replaced by a wire did you short circuit something, may be permanent damage to your Pi or the level converter board.
Peter.
Hi Peter,
I have no means of testing the PiZero at the moment. I'll order a micro-HDMI adapter.
I stupidly plugged the PiTubeDirect back into the machine not realising it was powered on.
The device wasn't working before I burnt the tracer out though but it another factor I have to consider now.
Sam.
BBC Masters 128
MMC Rom
