Compudata Hard-drive CS-1057
Multiwizard
Postby Multiwizard » Thu Sep 28, 2017 10:59 am
I few weeks ago a received this nice Compudata Hard-drive (see pisc)... :D
I like to connect it to a Beeb, but I suppose I need drivers for this (or not)... :(
The only Compudata I found on *. was this:
viewtopic.php?f=41&t=5594&p=119930&hilit=compudata#p119930
Does anyone know how I get this hard-drive working on a Beeb?
Greetings, Wim... :-)
yellowpig
Re: Compudata Hard-drive CS-1057
Postby yellowpig » Thu Sep 28, 2017 11:17 am
I don't know about this model, but does it plug into the 1MHz bus? If so, what happens if you simply connect it and run SUPERFORM? (You will need ADFS, of course)
David
Multiwizard
Postby Multiwizard » Thu Sep 28, 2017 11:33 am
yellowpig wrote: does it plug into the 1MHz bus?
David
I don't know... :?
rharper
Postby rharper » Thu Sep 28, 2017 2:08 pm
David
I don't know... :?
The plug will only be the right size for one socket under the beeb.
Just offer it up to see.
Ray
Raycomp
Boydie
Postby Boydie » Thu Sep 28, 2017 2:20 pm
What's inside the case? I'm assuming that's a 34-way ribbon cable hanging out the back, in which case it ought to be connected to a 1 MHz -> scsi/sasi adapter board, which in turn connects either directly to the drive (if scsi/sasi) or to a sasi->st506 adapter board (if st506 drive).
If this is the configuration, it should plug into the 1MHz bus and ADFS should recognise it by default as drive 0 (ie floppies and HDs are opposite numbers to riscos). As already said, SUPERFORM should format it if not already done.
Boydie
Postby Boydie » Thu Sep 28, 2017 2:22 pm
rharper wrote:
David
I don't know... :?
Ray
Both floppy and 1 MHz bus sockets are 34-pun, aren't they?
Boydie
Postby Boydie » Thu Sep 28, 2017 2:24 pm
Although there's something funny about a 34-pun socket.
Postby oss003 » Thu Sep 28, 2017 2:49 pm
I would be carefull with that because Compudata was an old company which became Tulip so it could be an external PC IDE harddisk.
Maybe if you open the case, you can wee if a controller is build in.
Multiwizard
Postby Multiwizard » Thu Sep 28, 2017 2:52 pm
Yep,
the Disc Drive & 1 Mhz Bus have the same connector size...
Multiwizard
Postby Multiwizard » Thu Sep 28, 2017 3:07 pm
It has a nice Bigfoot MFM SCSI hard drive... :-D
Sadly I can't (at the moment) get one of the screws loose to remove the drive to see how this SCSI board looks like... ;-(
Postby DutchAcorn » Thu Sep 28, 2017 3:14 pm
Multiwizard wrote:Yep,
Do you have any reason to believe this is an Acorn BBC harddisc?
Knowing Compudata it is very unlikely they ever made anything for Acorn computers. I'd advise not to connect it to the 1MHz bus. It is more likely to be an MFM hard disk that could be hooked up to an early PC (control cable is also 34 pins socket).
Boydie
Postby Boydie » Thu Sep 28, 2017 3:34 pm
The hard drive is ST506 (you can tell by the connectors coming off the drive itself). This is confirmed if you say it's MFM (AFAIK this was only ever a subtype of ST506).
The scsi (likely actually sasi) connector you can see will be connecting the two boards which I described above. The upper board (which should be about the size of an arc podule) does 1 MHz to sasi, and the lower (about the same footprint as a 5.25" drive, or slightly bigger, and usually made by Adaptec for Acorn stuff) does sasi to ST506.
The photos look pretty much like the arrangement for real Acorn winchester systems. Ideally, I'd want to see the upper, smaller board to prove it.
Boydie
Postby Boydie » Thu Sep 28, 2017 3:44 pm
There appears to be a booklet stuffed between the drive and the boards.
Don't suppose you'd be lucky enough for this to be relevant to the unit?
Multiwizard
Postby Multiwizard » Thu Sep 28, 2017 3:46 pm
Yes, I did manage to open it up... :-D
I did leave these pics in full size so you guys can zoom in close... 8)
So what is it, tell me tell me... :D
Multiwizard
Postby Multiwizard » Thu Sep 28, 2017 3:49 pm
Boydie wrote:There appears to be a booklet stuffed between the drive and the boards.
It's a part of a Dutch Vidimodem Manual...
Boydie
Postby Boydie » Thu Sep 28, 2017 3:54 pm
Take a look at http://cpu-ns32k.net/Acorn.html, figure 12. This shows the HD controllers for the Cambridge Workstation, which is are the same as Acorn used for their standalone winchester units.
I'll try to photograph and upload better pictures of Acorn controller boards, so you can compare components. But at first glance yours are looking rather familiar.
Postby oss003 » Thu Sep 28, 2017 3:56 pm
Multiwizard
Postby Multiwizard » Thu Sep 28, 2017 3:58 pm
Boydie wrote:Take a look at http://cpu-ns32k.net/Acorn.html, figure 12. This shows the HD controllers for the Cambridge Workstation, which is are the same as Acorn used for their standalone winchester units.
Like this...
Boydie
Postby Boydie » Thu Sep 28, 2017 4:03 pm
Check out the Acorn Winchester 110 and 130 Service Manual on Chris's Acorns. The appendices contain the parts list (and layout) of the 1 MHz -> scsi adapter board, as well as saying which Adaptec board they used.
From what I can tell, the layout of all the ICs is the same, as are the ICs themselves. That's either a rip-off of the Acorn scsi board (or unbadged oem version) or one heck of a coincidental design!
Postby DutchAcorn » Thu Sep 28, 2017 4:14 pm
It looks very similar.
Multiwizard
Postby Multiwizard » Thu Sep 28, 2017 4:25 pm
DutchAcorn wrote:It looks very similar.
Thanks for all this information guys... - =D>
Paul,
if I'm correct, I could put it all together again and connect it to my Master 512, which is already connected to a Winchester Disc 130
And see what happens?
Postby DutchAcorn » Thu Sep 28, 2017 5:02 pm
Thanks for al this information guys... - =D>
Paul,
if I'm correct, I could put it all together again and connect it to my Master 512, which is already connected to a Winchester Disc 310
Yes! After you disconnect the other drive. :D
Multiwizard
Postby Multiwizard » Thu Sep 28, 2017 5:09 pm
I couldn't wait,, I was too curious... :mrgreen:
It does do something... :D
Multiwizard
Postby Multiwizard » Thu Sep 28, 2017 5:17 pm
I thought perhaps C: would do something,, it didn't... :(
But D: did... :-k
Greetings, Wim... ;-)
Postby DutchAcorn » Thu Sep 28, 2017 5:20 pm
Multiwizard wrote:I thought perhaps C: would do something,, it didn't... :(
But D: did... :-k
*configure noboot
<ctrl>-<break>
*cat
Multiwizard
Postby Multiwizard » Thu Sep 28, 2017 5:24 pm
But D: did... :-k
*configure noboot
<ctrl>-<break>
*cat
Let me guess,,, Shift+Break?
Multiwizard
Postby Multiwizard » Thu Sep 28, 2017 7:14 pm
Nope, Shift+Break didn't do the trick... :-(
KenLowe
Postby KenLowe » Thu Sep 28, 2017 7:42 pm
A bit of a guess, as I don't have a Master, but try
*CONFIGURE NOTUBE
and then try a CTRL-BREAK or CTRL-SHIFT-BREAK
If that doesn't work, enter:
*TYPE !BOOT
and post the results.
Postby danielj » Thu Sep 28, 2017 7:44 pm
It looks like a disc from a level 3 fileserver!
Someone should have an idea about how to get the stuff off it?
johnkenyon
Postby johnkenyon » Thu Sep 28, 2017 8:54 pm
danielj wrote:It looks like a disc from a level 3 fileserver!
Connect the ACB SCSI interface to a Linux PC with a SCSI card and image the drive?
Return to “hardware”
Users browsing this forum: duikkie, KenLowe, markdryan and 12 guests
