Master 128 PSU schematic
dominicbeesley
Postby dominicbeesley » Tue Sep 26, 2017 10:03 am
The PSU is playing up in the Master (slow startup) before I take it for a recap does anyone have a schematic for the Master PSU or a run down of what caps? I've got one for a Model B, but without component values, it would be good to know what caps to bring...
D
duikkie
Re: Master 128 PSU schematic
Postby duikkie » Tue Sep 26, 2017 10:41 am
Not the same as the bbc b one ? Bbc b one somewhere on this forum
dominicbeesley
Postby dominicbeesley » Tue Sep 26, 2017 11:25 am
The one I found has no component values on it, the question is whether its the same or not i.e. is C9 on the BBC the same C9 as the Master....I'll have a go without a schematic as I should be able to work out which is the startup cap...
D
Postby danielj » Tue Sep 26, 2017 11:50 am
dominicbeesley
Postby dominicbeesley » Tue Sep 26, 2017 12:54 pm
Thanks daniel, I had seen that but it doesn't specifically say Master.
Anyway, I replaced C9 and the two main reservoir caps (I left the X2's as they look to be non-RIFA parts and I find I've run out of suitable X2's).
It's still slow to start up though...around 3.5s cold around 2s for a off/on cycle...that's until the keyboard LEDs light and the cassette relay clicks. Am I just being impatient?
Ottly
Postby Ottly » Tue Sep 26, 2017 1:32 pm
Hi.
I had a similar problem. Turned out to be a resister. I can't remember the one it was right now but can let you know if your interested. It's apparently quiet a common fault.
Scott.
Postby 1024MAK » Tue Sep 26, 2017 1:54 pm
Ottly wrote:Hi.
Scott.
One of the 100k ohm ones?
dominicbeesley
Postby dominicbeesley » Wed Sep 27, 2017 9:48 am
Thanks, I've got something with component values (Service manual scan with scribbled in numbers) and though it's for an original BBC seems to match the Master closely enough. I'll try the R2/R3 which look to be part of a tickler to get the osc started...
D
dominicbeesley
Postby dominicbeesley » Tue Oct 31, 2017 2:33 pm
Thanks Ottly, Mark,
I finally dug out some 3W resistors and replaced R2, R3, it now starts up instantly again. One (I can't remember which but I think R2) had gone to 275K from 180K.
All the electrolytics tested fine for both ESR and leakage, though I'd already removed the main smoothers before I tested them so they've been replaced by default. I suspect this machine was rarely used.
Note: for future reference on the Master PSU here R2, R3 were both 180k rather than 100K as suggested elsewhere.
Return to “hardware”
Users browsing this forum: No registered users and 12 guests
