NuLA demos
Re: NuLA demos
Postby sydney » Fri Aug 18, 2017 4:00 pm
I've been having trouble getting this to work on my machines. I presume it's due to the fact they are both sd card equipped and have no floppy drives. I've had a quick look at the source code and I have a feeling the disksys library won't be smartspi/mmfs compatable.
Re: NuLA demos
Postby danielj » Fri Aug 18, 2017 5:58 pm
Only works in dtrap mode on the data centre.
simonm
Re: NuLA demos
Postby simonm » Sat Aug 19, 2017 9:53 pm
I'm happy to have a go at fixing it for you... but not sure where the problem would lie. I admit the disksys code is pretty hacky and assumptive, only needed it for loading data into sideways ram - basically it loads a sector at a time and copies it to a paged SWR bank. To be honest, I've often considered *LOADing to &3000 and memcpy'ing it into SWR. Might even be faster!
I'll take a look at the code when I get a mo.
Re: NuLA demos
Postby sydney » Sat Aug 19, 2017 10:45 pm
The beeb doesn't have any swr but I tried it on a master and it failed in the same way. I was going to have a look at the code myself if I get a few minutes to myself.
Re: NuLA demos
Postby RobC » Mon Sep 04, 2017 7:11 pm
A few weeks ago, I came across this:
https://www.youtube.com/watch?v=4Logml664kk
I'd not seen it before and was quite impressed.
As I've been looking for a way to utilise VideoNuLA's sub-pixel scrolling, I thought I'd try doing something similar with VideoNuLA. Here's the result:
https://www.youtube.com/watch?v=wI0VlL7DEdk
It's using multiple vertical ruptures, palette changes, a main/shadow RAM screen swap (so is running on a M128) and sub-pixel horizontal scrolling at different speeds for each block. The hardware horizontal scrolling is perfectly smooth on the monitor but, unfortunately, the capture is a bit jerky :(
I've also uploaded a video of Simon's images:
https://youtu.be/tmeV6qYQ7yk
kieranhj
Re: NuLA demos
Postby kieranhj » Mon Sep 04, 2017 7:46 pm
:shock: :-D =D> That looks amazing Rob, great work!
Gah, having moved house all my Beeb hardware (including the NULA package) are in boxes until I have time & space to get them set up again. Must do this at the weekend!!
Rich Talbot-Watkins
Re: NuLA demos
Postby Rich Talbot-Watkins » Mon Sep 04, 2017 9:25 pm
Wow, crikey! :shock: That looks more Amiga than an Amiga! Fantastic work Rob!
Isn't there some way to upload a 50Hz video to YouTube (which can then be played at the right frame rate)?
Re: NuLA demos
Postby RobC » Mon Sep 04, 2017 9:31 pm
Rich Talbot-Watkins wrote:Wow, crikey! That looks more Amiga than an Amiga! Fantastic work Rob!
Thanks! It does look odd seeing it come out of a Beeb :D
Rich Talbot-Watkins wrote:Isn't there some way to upload a 50Hz video to YouTube (which can then be played at the right frame rate)?
Possibly but that's not the source of the problem here. I captured the output on an old DVD recorder and the stuttering was evident on the output from that. So, when I connected the Master directly to a monitor, the scrolling was perfectly smooth but it jittered when the output was routed through the DVD recorder.
simonm
Re: NuLA demos
Postby simonm » Mon Sep 04, 2017 11:54 pm
Outstanding Rob! It looks truly awesome. :shock: =D>
Re: NuLA demos
Postby steve3000 » Tue Sep 05, 2017 6:01 am
Wow, great work! :shock:
Even considering everything you've put into the NuLA, I never expected to see something like that from a beeb!
Re: NuLA demos
Postby tricky » Tue Sep 05, 2017 7:05 am
To get 50hz from YouTube, you need to upload at atleast 720p50, so 1280x720 at 50hz non interlaced, the resolution is as important as the frame rate.
Really great work rob, my targets we set much lower, but having seen your videos, I have to re-aim.
I really need to reserve some time to do something with my NuLA.
marcusjambler
Re: NuLA demos
Postby marcusjambler » Tue Sep 05, 2017 7:20 am
This is amazing Rob =D> =D> =D>
dominicbeesley
Re: NuLA demos
Postby dominicbeesley » Tue Sep 05, 2017 8:48 am
Nice on Rob, do you have an ssd?
D
Re: NuLA demos
Postby RobC » Tue Sep 05, 2017 11:49 am
dominicbeesley wrote:Nice on Rob, do you have an ssd?
Sure - it's attached.
This isn't quite the final version as I toyed about with some of the timings on the machine and still need to get that version off the SD card. However, it's pretty close.
It'll run in Kieran's modified B-Em (https://bitshifters.github.io/content/wip/b-em_170728.zip) but, as the smooth horizontal scrolling isn't supported, you'll just get the normal 6845 byte-wise scrolling. It's Master/Compact only as it uses shadow RAM...
sotb.zip
Shadow of the Beast VideoNuLA demo
(12.45 KiB) Downloaded 42 times
dominicbeesley
Re: NuLA demos
Postby dominicbeesley » Tue Sep 05, 2017 12:33 pm
WOW! =D>
trixster
Re: NuLA demos
Postby trixster » Wed Sep 06, 2017 9:05 pm
That's unreal!
Might you demo be made to work on a Beeb fitted with shadow ram?
A3020 | A3000 | BBC B + 128K RAM/ROM + 20K Shadow + Pi0 + VideoNuLA
BBC Master Turbo + DC | Atom | A1200 060 | A500 | Jaguar | A420/1
A4000/040 060 | Atari Falcon 060 | Saturn | PS1 | SNES | CPC6128 | C64 | 3DO | MD
Re: NuLA demos
Postby RobC » Thu Sep 07, 2017 7:41 am
trixster wrote:Might you demo be made to work on a Beeb fitted with shadow ram?
Have to admit that I've not used shadow RAM on the Beeb very much :oops:
The demo needs more than 20KB of screen RAM as it uses two copies of each character row to achieve the scrolling wrap-around.
Does anyone know of any shadow RAM boards that allow the CRTC to display the contents of the additional RAM? I have a Watford shadow RAM board but I don't think it allows this...
EDIT: Looking at the screen data requirements again, it might be possible to fit it in by using almost all of main RAM for the display and having the code run from sideways RAM on a B. I'll look into it.
The other possibility would be to load the screen data as required from a GoSDC or from a DC's 1MB RAM.
atcurtis
Re: NuLA demos
Postby atcurtis » Thu Sep 07, 2017 8:56 am
What would be fun would be a combination of the NuLA + ARM Copro (Pi) with BasicV and extra stuff so that one can use simple programming in Basic and the graphics output drive the NuLA to get the rich colour mode.
Re: NuLA demos
Postby RobC » Thu Sep 07, 2017 5:02 pm
atcurtis wrote:What would be fun would be a combination of the NuLA + ARM Copro (Pi) with BasicV and extra stuff so that one can use simple programming in Basic and the graphics output drive the NuLA to get the rich colour mode.
The VideoNuLA extended VDU drivers will work on the ARM copro as BASIC V just calls the OS on the host. So, you can do VDU 19,0,p,r,g,b and it will set physical colour p to analogue colour (r,g,b).
I use the Pi 6809 copro quite a bit for Flex and usually have the display setup as amber on dark blue.
paulv
Re: NuLA demos
Postby paulv » Thu Sep 07, 2017 5:40 pm
Wow!
On some levels, seeing a Beeb do that is all kinds of wrong! It's utterly astounding too. Speechless. Can't wait to drag the Master out of storage and fit all my upgrades to it including the VideoNuLA :D
Awesome work!
CharlesMouse
Re: NuLA demos
Postby CharlesMouse » Fri Sep 08, 2017 9:32 am
:shock: 8) :lol: =D>
Holy moley this is utterly amazing. I'm so glad Rob made these, and I'm lucky enough to have one of my own. This really needs to become a required upgrade for Beeb owners.
Charlie.
Are you pondering what I'm pondering? The Qube RiscOS Server
marcusjambler
Re: NuLA demos
Postby marcusjambler » Fri Sep 08, 2017 11:29 am
Looks like I'm gonna have to bite the bullet and de-solder a Master VidProc...
I may need some help with this since I would prefer that the chip was still useable afterwards.
Re: NuLA demos
Postby RobC » Fri Sep 08, 2017 11:37 am
marcusjambler wrote:Looks like I'm gonna have to bite the bullet and de-solder a Master VidProc... I may need some help with this since I would prefer that the chip was still useable afterwards.
If you can't find anyone near you and are happy to cover postage on the Master PCB, I'm happy to remove the existing ULA and fit a socket.
Alternatively, I'm hoping to be at the November ABUG so could do it there.
marcusjambler
Re: NuLA demos
Postby marcusjambler » Fri Sep 08, 2017 11:48 am
Sounds like a plan thanks Rob... I'll get a Master PCB off to you as soon as I can...
Also.. Please put me down for another Nula :D
Re: NuLA demos
Postby RobC » Tue Sep 12, 2017 9:14 am
Here's a version of my "Shadow of the Beast" demo that uses one bank of sideways RAM rather than relying on shadow RAM in the Master.
Almost all of main memory is used for the screen - only pages 0, 1 and 2 are left!
To run it, first load the SOTBROM ROM into sideways RAM using *SRLOAD or whichever command your RAM board uses. Then, do CHAIN"RUNME".
(The sideways RAM code is self-modifying so won't work if burnt to an EPROM.)
I've tested it in B-Em (in B and B+ mode) and on a real Compact so it should work on all machines.
I've also put up a video that I made a while back to get some screenshots for the manual: https://www.youtube.com/watch?v=65dyaePHH3Y
It's mainly me just playing around with the VideoNuLA board so probably nothing that hasn't been seen before...
sotb_sram.zip
Shadow of the Beast sideways RAM version
(7.1 KiB) Downloaded 26 times
grobda
Re: NuLA demos
Postby grobda » Tue Sep 12, 2017 6:49 pm
awesome stuff!
took me a while to get it running, beeb b with retroclinic SRAM mod & 1770 DFS
for any other noobs with same setup ( I had to google around a bit on how to use SRAM);
*SRLOAD SOTBROM 8000 7
ctrl-break
CH."RUNME"
Re: NuLA demos
Postby KarateEd » Sat Sep 16, 2017 7:44 pm
RobC wrote:
sydney wrote:Looking every bit as good as I thought it would! Is there any chance someone could have a go at recreating the amiga Tutankhamun image?
Already been done - it's on disk 2 and looks amazing on screen :D
This is from B-Em as I've lost my DVD recorder remote!
Holy crap!!! That's frikkin' unbelievable, with or without the tweaks you want to do.
sbadger
Re: NuLA demos
Postby sbadger » Mon Sep 18, 2017 9:31 am
I fitted the Nula at the weekend without problems, gladly.
I've been trying to use Simon's slide show but it just sticks on the VideoNula logo.
I'm running the image of an SD card with SmartSPI rom, is it not compatible?
stew
A3020| A3000x3| BBCBx3 | Electrn | Masterx3 |RiscPC| RPix3
A600 | C64 bbin x2|C64C | Toastrack |QL | XB360&1X |GB |GBC |GBA |GBASP | DS | 3DS XL x2| MD | MS
Atari 7600 | PS1-2-3-4| PSP |Vita |SNES |GC |N64 |Wii & U |Switch |JammaCab |Sony PVMx2
Re: NuLA demos
Postby RobC » Mon Sep 18, 2017 9:55 am
sbadger wrote:I'm running the image of an SD card with SmartSPI rom, is it not compatible?
It seems not - sydney reported problems with the gallery demos and SmartSPI earlier in the thread but Simon has said he'll look at it when he has some time.
Unfortunately, I don't have a SmartSPI/SD card but I have tested the demo disks successfully with GoSDC and DC (with DTRAP on).
If you have sideways RAM, my Shadow of the Beast demo should work.
sbadger
Re: NuLA demos
Postby sbadger » Mon Sep 18, 2017 12:51 pm
RobC wrote:It seems not - sydney reported problems with the gallery demos and SmartSPI earlier in the thread but Simon has said he'll look at it when he has some time.
must have missed that - thanks.
Yes, your SOTB demo works - it's looks amazing!
Return to “hardware”
Users browsing this forum: RobC and 12 guests
