The Master List for New Retro Hardware
Postby Elminster » Thu May 11, 2017 12:12 pm
Have a look at my original post below and follow the exciting histroy of the topic. But the short version is ...... I volunteered myself to create a list of all recent (i.e. not 'retro') hardware, hardware DIY and hardware integration projects for 8bit Acorn computers. This is temporarily sitting on my Github Wiki but will move somewhere else more appropriate at some point (and I shall update the link here as well). The rules for entry on the list are somewhat vague and random; formating is still to be done to make it pretty, I am waiting till it gets to a permanent home. But here is the URL to the list in all its gory glory.
List now moved to github pages
Elminster - My original post I wrote:I don't think we have this here but would it be worth having a pinned topic in the hardware section that either lists all the new (I.e. Not maxed in 80/90's) stuff that is available to buy/make or points to one or more websites that do.
My reasoning being I often see something on here and then spend ages later trying to remember/search for it. E.g. A table containing some thing like
Product
Description
Compatible
Category
Designer/s
URLs
Where urls could be purchase, design, docs and forums urls.
E.g.
AP5 - Electron Cart giving you missing ports - electron - Port expansion - Dave - <stardot AP5 topic URL>
Data centre - give Beeb cf, USB, RAM disks - Beeb, master - storage - Mark - retroclinic.com
There are websites with some stuff on but not come across a 'complete list' anywhere.
Hope that makes sense. Thoughts?
Re: Master New Retro List?
Postby BigEd » Thu May 11, 2017 12:19 pm
Sounds good to me, even if the head post is mostly a link to a well-maintained page elsewhere, or a wiki page.
Re: A Master List for New Retro Kit?
Postby Elminster » Thu May 11, 2017 12:32 pm
And also could have a couple of extra fields covering
Built: Full, partial or Kit
Type: Commercial or Open source
E.g. Datacentre is Fully built and commercial
MGC is Fully built and open
New ap6 is full or Kit and open
Postby Elminster » Thu May 11, 2017 12:33 pm
BigEd wrote:Sounds good to me, even if the head post is mostly a link to a well-maintained page elsewhere, or a wiki page.
Yep. If not maintain here would be good to go to one place, and referenced from here. I end up bouncing all over the place, using Google etc. Only to find dead links or partial info.
Postby BigEd » Thu May 11, 2017 12:34 pm
(I would prefer to say Proprietary vs Open Source: many commercial products are also Open.)
Postby Elminster » Thu May 11, 2017 12:39 pm
BigEd wrote:(I would prefer to say Proprietary vs Open Source: many commercial products are also Open.)
Hmm. Not quite got my thoughts worded right. Perhaps that should have been 3. Categories and not two.
- Proprietary and Open Source
- Commercial and Not for profit.
Postby BigEd » Thu May 11, 2017 12:43 pm
Sounds good. For me, a commercial product implies some level of support, whereas a not for profit means taking a bit of risk as to whether the thing will turn up, or work, or be replaced if it doesn't. (Should be lower risk for a well-established product from someone with a good reputation on this forum, could be higher risk for a new product or from someone who just popped up.)
Postby sydney » Thu May 11, 2017 12:43 pm
I'd say that's a good idea! You want to do it? If so go ahead and make a start and I'll make the thread a sticky. I had the more technical admins add some table tags to the bbcode but I'm at work at the moment so can't find out exactly how to use them. Have a look in the stardot high score table threads to see how they look.
Postby Elminster » Thu May 11, 2017 12:49 pm
BigEd wrote:Sounds good. For me, a commercial product implies some level of support, whereas a not for profit means taking a bit of risk as to whether the thing will turn up, or work, or be replaced if it doesn't. (Should be lower risk for a well-established product from someone with a good reputation on this forum, could be higher risk for a new product or from someone who just popped up.)
Yep exactly the lines I was thinking.
When i was fitting my Prime MBR recently (about a year after I bought it!) I think I jumped to about 3 *. posts and original manaul etc. to remind myself what I was doing. If we indexed that all in one place, for all products makes life easier. Or if people are in the market for storage and see TurboMMC and buy it and then realise later what they really wanted was a BeedSCSI, DC, GoSDC etc.
Edit: Also I some times disappear for a few months due to RL and find by accident that I completely missed some new product, e.g. the PI Tube Co Pro. (Just started building one)
Postby Elminster » Thu May 11, 2017 12:51 pm
sydney wrote:I'd say that's a good idea! You want to do it? If so go ahead and make a start and I'll make the thread a sticky. I had the more technical admins add some table tags to the bbcode but I'm at work at the moment so can't find out exactly how to use them. Have a look in the stardot high score table threads to see how they look.
Right ho. I can make a start. Do you want it in this post (moved to the top of the post)? Or create a new 'clean' post?
Postby sydney » Thu May 11, 2017 1:34 pm
Just start a new one. The table tags areas follows
[tr] row [td]column[/td][td]column[/td][/tr]
Postby Elminster » Thu May 11, 2017 1:40 pm
Right ho. Thanks. I shall knock something up
'You dont need to see their identification, these arent the drioids you are looking for' . ... what! .. how did I volunteer myself for my own idea?
Postby Elminster » Fri May 12, 2017 9:47 pm
Does this work if you click it?
Test List
BBCode Tables look dreadful. Maybe do something like the above. With a nicer output of course, currently above is just export of excel.
Just wanted to check I could actually publish something before spending days, weeks and months perfecting the list.
Postby davidb » Fri May 12, 2017 10:26 pm
Maybe we should just migrate the Retro Software Wiki content to the placeholder Wiki on GitHub and add the list there?
Postby Elminster » Fri May 12, 2017 11:40 pm
If you can do proper tables that arent in bbcode that sounds fine by me.
Limited to what can be done in the forum visual wise, just looked horrible. Wiki would give much more formatting options.
Postby BigEd » Sat May 13, 2017 6:00 am
Github's a good idea. You can do simple rectangular tables in markup, which get rendered nicely in a wiki:
| Tables        |      Are      |  Cool |
| col 3 is      | right-aligned | $1600 |
| col 2 is      |    centered   |   $12 |
| zebra stripes |    are neat   |    $1 |
Postby Elminster » Sat May 13, 2017 6:59 am
Agree that ascii tables are nice for small tables but get must less readable for big tables. I remember when we used to print off them in the old days on that stuff called 'paper' you needed either lined paper or a ruler and highlighter, or were unreadable.
Although hopefully we are not talking about a two hundred page report here, although people have been busy recently..
Postby daveejhitchins » Sat May 13, 2017 7:07 am
Elminster wrote:what! .. how did I volunteer myself for my own idea?
<Like> =D>
Postby hoglet » Sat May 13, 2017 8:05 am
Elminster wrote:Agree that ascii tables are nice for small tables but get must less readable for big tables. I remember when we used to print off them in the old days on that stuff called 'paper' you needed either lined paper or a ruler and highlighter, or were unreadable.
Just to be clear, github wiki tables are not just ascii tables, but are properly rendered. Some examples here:
https://github.com/hoglet67/AtomGodilVi ... escription
https://github.com/hoglet67/MMFS/wiki/Release-structure
The only problem I have is that wide tables wrap badly!
But I do think a github wiki is the right medium for this, then it can be maintained by the whole community, not just one person.
Postby Elminster » Sat May 13, 2017 8:11 am
hoglet wrote:Just to be clear, github wiki tables are not just ascii tables, but are properly rendered. Some examples here:
I don't think there was any confusion. Think we already said wiki would be good as bb code tables are rubbish and ascii tables don't scale.
I do have a GitHub account. But I can get on with filling out data for now that my main worry of how to display is resolved.
Postby Elminster » Sat May 20, 2017 9:00 pm
Getting there. I need to move it to https://github.com/stardot/retrosoftware/wiki soon. But when I looked earlier I seemed to have no permissions to add a page, and besides easier to just much about on my page and move it later. So for now I have stuffed it on my wiki here
Still has missing data, I keep coming across more, and I am playing with the format. It is in an excel spreadsheet and then converted to Markdown. Need to change the product names to hotlinks at some point. But will wait till the table is 'complete' as then I can just re-export from excel without destroying all the hotlinks.
flynnjs
Postby flynnjs » Sat May 20, 2017 11:03 pm
I would have thought a retrohardware wiki would be more appropriate.
Postby Elminster » Sat May 20, 2017 11:57 pm
flynnjs wrote:I would have thought a retrohardware wiki would be more appropriate.
I am assuming it is a logistics thing. I.e. Not wanting to create an empty GitHub project that just has a wiki, and not creating something on another dedicated wiki site due to user management hassel. Either way I can put it wherever.
Postby 1024MAK » Sun May 21, 2017 5:47 am
What about putting it in the ‪BeebWiki‬?
Postby MartinB » Sun May 21, 2017 6:30 am
Could UPURS get a mention please? :)
( It's very lonely over here in obscurity.... :( )
Postby 1024MAK » Sun May 21, 2017 6:32 am
Done by yourself in your own post :lol:
Or did you actually want it included on the list :?: :lol:
I also can't see your Magic thingy...
The DIY sideways ROM and / or SRAM modification/upgrade also needs adding (for the BBC machines, some info on RetroClinic's site).
And the user volume control Done by yourself in your own post :lol:
And the user volume control modification/upgrade (also BBC).
Postby MartinB » Sun May 21, 2017 6:37 am
No, you're quite right Mark, I've done the mention myself - job done... :D
(The tricky part was not having the post deleted by The Green, Amber & Pink Management... :lol: )
Postby 1024MAK » Sun May 21, 2017 6:38 am
See edit above..
Also your I2C bus stuff... linky
Postby danielj » Sun May 21, 2017 6:40 am
MartinB wrote:No, you're quite right Mark, I've done the mention myself - job done... :D
I don't think I've deleted any of your posts... Yet? :D
Postby MartinB » Sun May 21, 2017 6:59 am
ha! No, of course not, just joking - this management team is the best ever... =D> 8)
