Several lamer's questions
litwr
Postby litwr » Sat Mar 18, 2017 8:40 pm
1. Is there ways to make Archimedes of the 80s faster? To stop video or something else? Some magic Basic commands?
2. What does DEBUG-command make? I tried it with command line and got a prompt changed from * to DEBUG*. Any details or links?
A lot of thanks in advance. :)
sirbod
Re: Several lamer's questions
Postby sirbod » Sun Mar 19, 2017 12:38 am
litwr wrote:1. Is there ways to make Archimedes of the 80s faster? To stop video or something else? Some magic Basic commands?
What are you trying to speed up? You only get a minor speed improvement by shutting off MEMC Video and Sound DMA with OS_UpdateMEMC. You want to set bits 10 (video) and 11 (sound) to 0:
SYS "OS_UpdateMEMC",0,%11 << 10
Turn them back on with:
SYS "OS_UpdateMEMC",%11 << 10,%11 << 10
litwr wrote:2. What does DEBUG-command make? I tried it with command line and got a prompt changed from * to DEBUG*.
*DEBUG is just a command line shell.
litwr
Postby litwr » Sun Mar 19, 2017 5:59 am
More thanks for the detailed help. :) However the purpose of *DEBUG still misses me. I called it from BASIC and got DEBUG* prompt. I can't catch the difference between it and the standard *-prompt.
litwr
Postby litwr » Sun Mar 19, 2017 8:08 am
I have another question for Basic. I want to load a ML program. I use
OSCLI "LOAD PROGNAME "+STR$~ADDR
This doesn't work with GUI. I should add a path (folder) of PROGNAME before PROGNAME. How to get this path? Are there other ways?
sirbod
Postby sirbod » Sun Mar 19, 2017 8:37 am
litwr wrote:I can't catch the difference between it and the standard *-prompt.
There is no difference that I'm aware of. Under the hood it may install a different error handler, but it's not something you'd notice and certainly isn't documented.
litwr wrote:I have another question for Basic. I want to load a ML program. I use
Run programs from the GUI via an Obey script in the same directory and set an environmental variable. eg
Obey script:
Set myprog$Dir <obey$dir>
mybasicprog
mybasicprog
OSCLI "LOAD <myprog$dir>.PROGNAME "+STR$~ADDR
litwr
Postby litwr » Sun Mar 19, 2017 9:57 am
Thanks. :) However I can think that I have found a bit shorter way.
Obey script:
<obey$dir>.prog
I had to add <obey$dir> prefix. A script doesn't work with GUI without it for me.
Basic line:
OSCLI "LOAD <obey$dir>.PROGNAME "+STR$~ADDR
sirbod
Postby sirbod » Sun Mar 19, 2017 12:22 pm
Using Obey$Dir in a program is never a good idea, as it changes whenever an obey script is executed. It will be okay, provided you load all your files as soon as the program runs, and never have to access local files again.
Return to “software”
