Plans for ABUG North 18th-20th Nov.
threads relating to past classic gaming/computing events
Prime
Postby Prime » Thu Nov 03, 2016 10:45 am
Hi All,
Thought I'd give people a heads up as to one of the things I'm planning to do at the meetup.
I'd like to expand the list of tested motherboards / PC hardware that we know is good for imaging beeb floppies, so If anyone has any old motherboards (I'm thinking P3/P4 / Athlon timeframe or newer) that they could bring along and I could test, or even full PCs, I know that Arcadian has said he has some that he will be bringing.
I believe that Dave Hitchens said he had some 5.25" PC floppy drives that he'd like to get going, Dave if you want to bring those along we could have a look at them. I alsoi seem to remember that you had an Athlon board from me a couple of years back, if you bring that along we can test it too :)
I'll be bringing a couple of PSUs, various types of RAM, processors, cables etc to give us as good a chance as we can have of getting things going.
Phill.
lazarusr
Re: Plans for ABUG North 18th-20th Nov.
Postby lazarusr » Thu Nov 03, 2016 6:31 pm
I have a few. I will see what I can bring.
I maybe struggling for space in the boot of my car. I am going on to do some work in Leeds after the meet up and I need room for that. Plus it all needs to fit in the boot - I don't really want anything on display on the seats.
Postby danielj » Thu Nov 03, 2016 8:20 pm
I'll be bringing some disc duplication gubbins, I have it writ that I need to bring the bits to repair a riscPC around the battery area? (caps/resistors?)
Postby BeebMaster » Fri Nov 04, 2016 10:03 am
I'm possibly bringing my Domesday Machine - as long as I can get it there in one piece (well, 4 pieces plus cables), I haven't finalised my travel plans yet. That's if it still works, it's due out of the wardrobe at the weekend for a test.
I'd also like to bring a selection of battery-damaged kit if anybody fancies a challenge - 2 x RISC PC and 2 x MDFS main unit. I think the consensus is that the CMOS chips on the RISC PCs are bust - can I get new ones and can somebody fit them if I do?
What is the state of the Bolton Econet, is anything needed?
Postby danielj » Fri Nov 04, 2016 11:43 am
Ian - I'll be on a RiscPC mission with things like that, so if you can get new clock ICs I'll fit them. We'll see if we can have a bit more of a go at the MDFSs too if there's time?
I'll bring my MDFS and some cable/sockets.
Also bringing the Victor 9000 as frankly it's rather awesome.
lazarusr
Postby lazarusr » Fri Nov 04, 2016 12:15 pm
I would really appreciate it if there was someone who could help me get to the bottom of the issue with my flickering LCD tv/monitor. It works fine with my Master 128 but has significant problems with my Model B via both RGB and composite.
This makes me think that the problem is with the Beeb and not the TV. It looks like some kind of sync timing issue, but when I look at it on the 'scope, everything looks rock steady. But I am really exceptionally naive when it comes to things like this. So any help would be really appreciated.
Postby danielj » Fri Nov 04, 2016 1:30 pm
There are definitely some differences between the video on the Beeb/Master (my extron gives a perfect picture with the beeb, a slightly wibbly interlace with the master)
VincentVega
Postby VincentVega » Fri Nov 04, 2016 6:43 pm
danielj wrote:I'll be bringing some disc duplication gubbins, I have it writ that I need to bring the bits to repair a riscPC around the battery area? (caps/resistors?)
That was for me, if you still don't mind doing it; it would be hugely appreciated if you could. I have a new clock chip ready to go (the old one has parted company with the motherboard). I will also be bringing an Electron that hasn't worked since the late 1980s - if someone could have a look at it to see if it's salvageable, I'd be a happy bunny. It's my first ever computer, so has sentimental value.
danielj wrote:Ian - I'll be on a RiscPC mission with things like that, so if you can get new clock ICs I'll fit them.
I got mine from Farnell at a cost of £2.04:
http://uk.farnell.com/nxp/pcf8583t-5-51 ... 7-00001003
I'd also be interested in a 40/80 track disc drive (preferably dual) if anyone has one they'd like to sell.
Postby BeebMaster » Fri Nov 11, 2016 12:43 pm
Got the clock chips, exact same part. They've arrived sealed in tin foil with instructions on the front saying they need to be baked before use. So I haven't opened them to inspect, hopefully they will be right. We might need to use Gary's microwave. There's some spares if anybody needs one.
Postby flaxcottage » Fri Nov 11, 2016 3:06 pm
BeebMaster wrote:Got the clock chips, exact same part. They've arrived sealed in tin foil with instructions on the front saying they need to be baked before use. So I haven't opened them to inspect, hopefully they will be right. We might need to use Gary's microwave. There's some spares if anybody needs one.
Microwaves will not be good for ICs. :( A dry-heat oven will be best.
Currently running L4 Econet with BBC B, BBC B+ 128K, Master 128K, 4Mb A3000, 4Mb A3020, 4Mb A4000, 4Mb A5000 dual FDD; UK101; HP41CX setup; Psion 3a, 3mx and 5mx; Z88; TI-58c, TI-59 and printer, HP-16C programmer's calculator and a bakery of Pis.
jbnbeeb
Postby jbnbeeb » Fri Nov 11, 2016 4:24 pm
I'll be updating the games menu code for Dave H's Mega Games Cartridge and showing off the latest iteration of Tequila Worm which will feature graphics kindly provided by DethMunk.
I'd also be grateful for some help getting GEM to boot from SD card via matchbox co pro. This was working at Cambridge but hasn't booted since.. the GEM logo is corrupted at boot time and boot then hangs.
I'm going to ..
ABUG North Halifax June 10-12
Postby roland » Fri Nov 11, 2016 11:46 pm
My plans are meeting you guys and have a wonderful time :lol: I'm really looking forward to the next weekend.
256K + 6502 Inside
Postby BeebMaster » Sat Nov 12, 2016 10:20 am
jbnbeeb wrote:I'd also be grateful for some help getting GEM to boot from SD card via matchbox co pro. This was working at Cambridge but hasn't booted since.. the GEM logo is corrupted at boot time and boot then hangs.
I'll try to help...did I look at that at Wakefield?
lazarusr
Postby lazarusr » Thu Nov 17, 2016 1:13 pm
Prime, I'm really sorry, but I have run out of space. So I'm afraid I won't now be able to bring the motherboards. :(
Prime
Postby Prime » Thu Nov 17, 2016 1:39 pm
lazarusr wrote:Prime, I'm really sorry, but I have run out of space. So I'm afraid I won't now be able to bring the motherboards. :(
No worries :)
Phill.
Postby daveejhitchins » Thu Nov 17, 2016 3:37 pm
We will, of course, inspect your packing techniques when you arrive - I don't suppose you've considered dumping your weekend bag? Tut! thought not [-X Priorities, my boy . . . :wink:
Dave H :lol:
Postby 1024MAK » Thu Nov 17, 2016 5:04 pm
Dave H :lol:
I'l bring a tape measure then... :lol:
Return to “past events & exhibitions”
