ABug South - at Centre for Computing History, Cambridge August 26-28 2016
threads relating to past classic gaming/computing events
Re: ABug South - at Centre for Computing History, Cambridge August 26-28 2016
Postby Prime » Thu Aug 18, 2016 9:28 am
I'm quite happy to have a look at any Atoms / System machines that the centre has to see if I can get them repaired / going, it's actually one of the things I was planning on doing......
Other than that, anything anyone wants me to bring?
dp11
Postby dp11 » Thu Aug 18, 2016 8:53 pm
I'm thinking of popping along to meet people if you all don't mind. Which day would be better ?
jbnbeeb
Postby jbnbeeb » Fri Aug 19, 2016 11:14 am
dp11 wrote:I'm thinking of popping along to meet people if you all don't mind. Which day would be better ?
One of the "kitters" is Saturday only so suggest that Sunday would be better as we'll have a little more room.
I'm going to ..
ABUG North Halifax June 10-12
JimRussell
Postby JimRussell » Sun Aug 21, 2016 6:18 am
Hi Jason, can you put me down for the restaurant too please.
I will be bringing a Master with Beebflex in a cheese wedge and Eurobeeb in a 19 inch rack. It takes a fair bit of space so I hope there will be enough desk space. I don't have an Atom but all the Control Universal stuff uses the same expansion bus as the Atom. Jim
For some reason I don't have permission to send emails so I can't reply to those sent to me can you fix it please.
flynnjs
Postby flynnjs » Sun Aug 21, 2016 8:32 am
Have CCH made any demands for electrical safety, testing etc?
jbnbeeb
Postby jbnbeeb » Sun Aug 21, 2016 8:52 am
flynnjs wrote:Have CCH made any demands for electrical safety, testing etc?
No.. Should I check? They seem to be quite easy going..
I'm going to ..
Postby BigEd » Sun Aug 21, 2016 8:54 am
Oh dear - let's not ask for trouble! I'm sure my old telly and monitor are untested and are decades old. But what could possibly go wrong?
Postby oss003 » Sun Aug 21, 2016 9:08 am
Hi Jason,
Wim and I arrive at 21:05h in London so won't be in Cambridge before 22:00h. If it will be later, we will join you on Saterday, until what time will you be at the museum?
So we won't be there Friday afternoon.
flynnjs
Postby flynnjs » Sun Aug 21, 2016 11:44 am
I'm just saying, back in the Spring, I did another event and we tested about 100 pieces of
kit ranging from brand new to "older than any Acorn kit" and we had two failures which
could have ended up being lethal and this was a shock for me (pun intended) and I am far
more cautious now.
If they've not mentioned it, I wouldn't ask but we should have plenty of multimeters on
hand and at minimum make sure everything is vaguely earthed, if not to protect people
then at leat to protect inter-connected kit ;-)
I think many older Acorn kit would fail due to uninsulated plug prongs in an official test
but that's a manageable risk. An unforseen live Cub case isn't!
dp11
Postby dp11 » Sun Aug 21, 2016 12:32 pm
I can bring a Pat tester if people want.
I don't think uninsulated prongs are an issue for equipment made before the date that they where added to bs1363 .
Edit : Table v 111.1 in the COP say's - The regulation is not retrospective in that it does not apply to old plugs already in use, but such plugs should not be reused (ie not fitted to new cords) . the magic date is 1994
Postby 1024MAK » Sun Aug 21, 2016 1:03 pm
The most important thing with electrical safety is visual inspection of mains voltage plugs, connectors, cords (cables), cord grips, grommets and the case etc. Check to see if there is any damage to the insulation and check that the items continue to work as designed. Check for cracks in the case, and ensure that securing screws or clips are effective.
The next most important thing for class I equipment, is to ensure that the earthing of the case and any exposed metal parts is good. You can do a basic test with any good multimeter that has a low resistance range (200 ohms or lower). But a proper PAT tester will test using a high current to test the earthing system. This picks up poor connections.
These steps will pick up most problems.
You can also use a high voltage insulation tester. This tests at 250V DC, 500V DC or 1000V DC. It will pick up any electrical failure of the insulation. Most useful on class I equipment.
More on PAT here
dp11
Postby dp11 » Sun Aug 21, 2016 2:54 pm
Totally agree about visual inspection. I fail more items by visual inspection than using the Pat tester. Often these days I fail equipment that other people pass because they have only used the tester and not done a visual inspection.
dp11
Postby dp11 » Sun Aug 21, 2016 2:57 pm
A question that I often ask people who use a pat tester . You have a black fuse in a mains plug, what rating is it?
flynnjs
Postby flynnjs » Sun Aug 21, 2016 6:05 pm
It could all sorts of values other than 3 or 13.
I have 1,2,10 which are all black in addition to the common 5.
One of the items I failed before my spring event the mains plug was cracked in two and the live pin wobbled around.
The other item had no working earth and a metal chassis.
dp11
Postby dp11 » Sun Aug 21, 2016 6:58 pm
excellent too many people think all black fuses are 5amps.
Postby 1024MAK » Sun Aug 21, 2016 9:48 pm
flynnjs wrote:It could all sorts of values other than 3 or 13.
There are black 1 inch (25.4mm x 6.3mm) 1A fuses? The only 1A fuses (to a BS standard) that I have seen is the slightly smaller size (19.1mm x 5.3mm), as used in shaver adaptors, and maybe some of the the old clock connection units and industrial fuse holders...
jbnbeeb
Postby jbnbeeb » Mon Aug 22, 2016 9:47 am
Prime wrote:I'm quite happy to have a look at any Atoms / System machines that the centre has to see if I can get them repaired / going, it's actually one of the things I was planning on doing......
I've just spoken with Jason F from the Centre. Yes they have some poorly Atoms and some Atom econet bits by the sound of it. So they'd definitely be up for a bit of troubleshooting there.
He's also going to have a rummage around and get together "interesting" bits of Acorn kit for us (as to whether it's working or not, or what the kit is, I don't know, but I presume will be rarer kit)
I'm going to ..
jbnbeeb
Postby jbnbeeb » Mon Aug 22, 2016 9:48 am
oss003 wrote:Hi Jason,
I'm not sure how late we'll be there. The Centre seem fairly relaxed about how late we stay. I'll PM you; I'm going to guess that there won't be many of us there after 10pm Friday.
I'm going to ..
jbnbeeb
Postby jbnbeeb » Mon Aug 22, 2016 9:50 am
jbnbeeb wrote:Hi, I've added these requests to top post for me to pass on to the museum. Have I missed anything? Any more requests to add? I've mailed below to museum and will phone them tomorrow.
- Request to search the attic for "Missing in Action (MIA)" software titles for Acorn machines - and to archive and catalogue these items. Archiving meaning taking a dump of files on tape or disk for storing on the bbcmicro.co.uk website as well as cataloguing for the Centre.
- A request to take a number of software titles offsite (borrow) for archiving and return them by post by an acceptable time thereafter.
- A request to take a dump of a ROM in one of the Centre BBC Micros (an MIA version of Opus DOS)
- Several people have offered to catalogue items for the Centre
I've heard back now..The Centre are fine with all these requests except for taking items off site...
I'm going to ..
lazarusr
Postby lazarusr » Mon Aug 22, 2016 10:25 am
jbnbeeb wrote:I'm not sure how late we'll be there. The Centre seem fairly relaxed about how late we stay. I'll PM you; I'm going to guess that there won't be many of us there after 10pm Friday.
Looked at from the other end of the spectrum (pun intended), what is the earliest time the Centre will allow us to drop off kit? I am probably going to arrive in Cambridge around 2pm and would prefer to leave my kit at the Centre before checking in to my hotel.
jbnbeeb
Postby jbnbeeb » Mon Aug 22, 2016 10:29 am
I'm planning to arrive at that time to help them clear the room they've allocated to us. I'm sure some of us dropping off kit before 4pm will be fine.
I'm going to ..
lazarusr
Postby lazarusr » Mon Aug 22, 2016 10:30 am
jbnbeeb wrote:I'm planning to arrive at that time to help them clear the room they've allocated to us. I'm sure some of us dropping off kit before 4pm will be fine.
Great thanks. Happy to help with the clearing too if an extra pair of hands would be useful.
jbnbeeb
Postby jbnbeeb » Tue Aug 23, 2016 8:36 am
** REQUEST FOR HELP WITH ARCHIVING**
Lee has sent me a list of software to hunt down at Cambridge.
I think Jon is going to bring kit to archive - would this include a tape deck and cables..? Can anyone else bring down tape and disk archiving kit? I believe Jon will be with us for Saturday only.
Thanks,
Jason
I'm going to ..
Multiwizard
Postby Multiwizard » Tue Aug 23, 2016 12:52 pm
is there perhaps someone coming to the meeting this weekend and fancy a Issue 5 Atom board? :D
I am looking for a good working atom Issue 4 PCB with also a good/neat and complete working key-caps... [-o<
So if anyone is willing to trade his Issue 4 board with one of my Issue 5 boards I will bring one with me... :D
It comes without the semiconductors/IC's, this because of the customs of the airports...
Greetings, Wim... :-)
Thanks in advance...
Postby daveejhitchins » Tue Aug 23, 2016 1:07 pm
Multiwizard wrote:It comes without the semiconductors/IC's, this because of the customs of the airports...
:shock: I've got to ask WHY? :shock:
p.s. Sorry, everyone . . . B*%%#y leg's still giving me problems so I'm giving my place over to someone else. Next year! Lots of photos and comments, please [-o<
lazarusr
Postby lazarusr » Tue Aug 23, 2016 3:06 pm
Really sorry to hear that. :(
jbnbeeb
Postby jbnbeeb » Tue Aug 23, 2016 3:16 pm
In addition to the "bring tape/disk archiving kit" request upthread - is anyone able to bring an EPROM blower + blank EPROMs ? I'd like some MMFS EPROMs to go on my ABR in a bid to get my Master with modem port/6522 , to boot Dos plus via matchbox co pro
thanks,
Jason
I'm going to ..
Postby oss003 » Tue Aug 23, 2016 3:33 pm
Prime wrote:Other than that, anything anyone wants me to bring?
Phill,
are you planning to bring a cassetteplayer with you, if not are you willing to take one with you so I can have a look at the Atom tape archive?
It would be perfect if the output of the cassette player is a jackplug so that I can record the tape with the soundcard in my laptop.
Thanks.
Postby leenew » Tue Aug 23, 2016 4:20 pm
^^ I Think this may be a better idea than trying to "crack" the tapes on site.
If we could record all the MIA tapes into digital format then crack them at our leisure, that makes more sense.
Lee.
Postby Prime » Tue Aug 23, 2016 4:26 pm
Phill,
Will pack one of my Tandy/Radio Shack recorders, used with a whole load of vintage computers. I believe it has been used with the Atom in the past.
Return to “past events & exhibitions”
