with little shame update smartest1613
duikkie
Re: NEW SMART rom: don't mis sept 2015 update
Postby duikkie » Fri Sep 25, 2015 7:25 pm
little thing file T.dfstemp is different. i will next time rename it in file make with j.dfstemp
you can't use the old t.dfstemp.
at &93ed : LDA #&FF:pha:jmp &9341. this is the soft reset :)
normal :
&9338 lda #&ff
&933A PHA
&933B JSR CLEARAREA / clears &d00..&d6f
&933E JSR ORGBEEB / fill &d70 with beeb .mmb
&933F NOP
&9340 NOP
&9341 JSR ......
&9338 is start point *dmmc
&933B is jump adress after S-BREAK or X-BREAK
duikkie
Postby duikkie » Fri Oct 02, 2015 7:15 pm
discover a bug : when you have *drom it delete the beeb.mmb variable
so fixed it
replace beeb.mmb at &d80 (was &d70)
SMARTEST0210.zip
(60.29 KiB) Downloaded 70 times
Re: NEW SMART rom: *drom/beeb bug solved
Postby danielj » Sun Oct 18, 2015 9:06 am
I'm qualified to say "Awesome work!" now :D - 50p sd card reader, bodged cable, and it's working perfectly with an 8gb kingston sd card.
Am I right in thinking you can have multiple MMB files? I can't quite see how that works (but I'm probably being a bit stupid/lazy).
Re: working on new MMC rom testers wanted
Postby DutchAcorn » Sun Oct 18, 2015 9:44 am
danielj wrote:...
Am I right in thinking you can have multiple MMB files? ...
Somewhere on the first page of this thread:
duikkie wrote:...
you can use multi beeb.mmb files on 1 sd card
the limit is 510 files of 200mb :)
*beeb is the standaard file beeb.mmb
*beebxxxx is the file of the next => xxxx is from 0 to 510
Postby danielj » Sun Oct 18, 2015 11:11 am
You see, I looked through that page and totally didn't spot that. #-o Thanks :)
duikkie
Postby duikkie » Sun Oct 18, 2015 1:53 pm
read the manual :lol:
viewtopic.php?f=2&t=9913
Postby danielj » Mon Nov 02, 2015 3:35 pm
Should the new ROM remember which beeb.mmb file you've selected on break? Mine seems to just default back to beeb.mmb when I hit break, even if I've selected a different one? This is the latest version, on a master...
duikkie
Postby duikkie » Mon Nov 02, 2015 10:02 pm
which commando do you use after the break ?
i have dfs (discdrive) in my beeb.
if i hit break then default is discdrive
but if i use *card to go back to sd card it remembers the beebxxxx.mmb
if you use *dmmc it always go back to default.
what hapens when you only have smart- spi rom ?? tomorrow maybe i can try that #-o
danielj wrote:Should the new ROM remember which beeb.mmb file you've selected on break? Mine seems to just default back to beeb.mmb when I hit break, even if I've selected a different one? This is the latest version, on a master...
Postby danielj » Mon Nov 02, 2015 10:11 pm
On the master it sticks with the last file system on break, unless you use ctrl-break in which case it goes to default filesystem (1770 dfs for me).
If I hit break then *. it goes back to beeb.mmb, not beebxxx.mmb. Same if I ctrl-break then *CARD again. :?
duikkie
Postby duikkie » Tue Nov 03, 2015 11:04 am
i will look at it , i don't have a master. but i know what the problem is. somewhere it reset the smart spi rom. on the beeb it is the same, except when using *card.
i don't no if i can fix this , because on default and start-up it must be beeb.mmb. :(
maybe i have to check if warm or cold break ?
danielj wrote:On the master it sticks with the last file system on break, unless you use ctrl-break in which case it goes to default filesystem (1770 dfs for me).
duikkie
Postby duikkie » Fri Jan 15, 2016 2:01 pm
in cooperation with hoglet , we proudly present you while bill was not looking
SMARTEST1513 for beeb and ELK with fixed bug in osword7f calls with copro.
update SMART spi rom date 1513 :shock: , 15 jan (13-12=01)
SMARTEST1513.zip
(65.34 KiB) Downloaded 38 times
duikkie
Postby duikkie » Sat Jan 16, 2016 1:39 pm
there was still a bug, so with a little bit of shame here a update smartest1613 :oops: :oops: :^o
duikkie wrote:in cooperation with hoglet , we proudly present you while bill was not looking
SMARTEST1613.zip
(65.28 KiB) Downloaded 120 times
rharper
Re: with little shame update smartest1613
Postby rharper » Wed Mar 29, 2017 10:39 am
Is there any chance of an Electron version for the Printer port like the recent MMFS version?
Ray :)
Raycomp
duikkie
Postby duikkie » Wed Mar 29, 2017 11:30 am
i don't know yet , i rather see my SMART-USB with a usb stick working out. i think it is faster and the parts are as cheap as modifing the printerport. ch376s module is 2 ponds, a chip selector 0.5 ? board and eeprom ?
the ch376s module in parallel bit transfer.
but if anyone want to modify the smelk rom go ahead . all are there in a ssd file
rharper wrote:Is there any chance of an Electron version for the Printer port like the recent MMFS version?
Ray :)
spookyone
Postby spookyone » Sun Jul 09, 2017 5:30 pm
Duikkie,
I recently made an SDCard drive for my beeb using your great Smart SPI rom & I'm really pleased with it. Now someone has asked if I would be willing to sell some of these card readers. Therefore I was wondering if I could have your permission to supply the card readers with your Smart SPI rom image?
I'm not a commercial business and I only intend to make a small batch of these card readers.
Many Thanks,
Jason.
duikkie
Postby duikkie » Mon Jul 10, 2017 5:55 am
it is freeware , so no permission needed from my side
if you like Smart-spi , maybe later you like my new software
it is summer and to hot to program
but i am working on USER DOS and TUBE DOS rom
allso i see more in my ch375/6 module project ( on the tube)
spookyone wrote:Duikkie,
Many Thanks,
Jason.
spookyone
Postby spookyone » Mon Jul 10, 2017 11:22 am
Thanks Duikkie!
I certainly will be looking out for your future projects - the USER/TUBE DOS sounds interesting - how will that work?
Jason.
duikkie
Postby duikkie » Mon Jul 10, 2017 2:59 pm
sssssssssssssssssssssssss for my eyes only sssssssssssssssssssss
you take a sd card from your pc with beeb stuff on it ( like ssd files / roms (maybe) )
put it in the beeb sd card holder or ch375b (usb stick)
and load it in beeb memory like a drive or in mem (uploading to rom)
commands like dosdir ( displays dosdirectory (filenames )on beeb screen)
doscd ( to change directory on sd card)
dosload or import ( to load a ssd file)
no beeb.mmb anymore :) and all its commands.
spookyone wrote:Thanks Duikkie!
Jason.
spookyone
Postby spookyone » Mon Jul 10, 2017 8:58 pm
So, a kind of native DOS FAT support for the Beeb? - that would be good.
Return to “software: other”
