Tree of Knowledge loading programs
pau1ie
Postby pau1ie » Sun Nov 12, 2017 10:17 pm
I am confused as to how this works. I suspect this has been copied from tape and altered to run on disc, There is a bootfile:
CHAIN "LOGO"
This program is as follows (Hand typed so may be transcription errors.:
  0REM  ...Tree of Knowledge V1
 10REM
 20REM  Copyright (C) Acornsoft 1982
 30REM
 40MODE7:VDU23;10,32,0;0;0;
 50FORI%=0TO&400STEP4:I%!&7C00=I%!TOP:NEXT
 60VDU28,11,22,30,20
 70PAGE=&E00
 80CHAIN"Tree"
This displays the acornsoft logo. How? I assume it has something to do with the loop at line 50.
But it keeps saying "Bad Program", presumably because it is setting PAGE to &E00 which is wrong for a system with DFS. So I changed line 70 to
70PAGE=&1400
But it doesn't display the logo properly any more.
It does however load and run the main program fine. But if I save the program, then change it back and save it again, it still doesn't display. Is there some hidden code that doesn't save when I change it? How do I diagnose this?
Re: Tree of Knowledge loading programs
Postby lurkio » Sun Nov 12, 2017 11:01 pm
The Acornsoft loading screen data is stored in memory starting at TOP, which is the memory location that immediately follows the last byte of the BASIC loader program. Because you increased the size of the BASIC program (albeit only by one byte), by changing E00 to 1400, you made the BASIC program overwrite the start of the loading screen data.
The loading screen data is at the end of the original file that contains the BASIC loader program. To see this, load the original program and type PRINT ~TOP-PAGE to get the size of the BASIC program. Then compare that with the file-length that you get when you do *INFO filename
:idea:
Postby crj » Sun Nov 12, 2017 11:09 pm
What that does is copy a kilobyte (&400 bytes) from immediately above the program into screen memory.
A BBC BASIC program has a terminator at the end of it. Normally - and certainly when you SAVE - that will be the last thing before the end of the file. However, if there's more data beyond that it gets loaded and just sits there in memory like a lemon. "LOGO" has a kilobyte of extra data BASIC knows nothing about.
The keyword TOP denotes the end of the program, so the start of that extra data.
If you want to modify the program without damaging the logo, you'll need to do something like:
PRINT ~TOP
*SAVE LogoTmp <top>+400
REM Make your changes here
PRINT ~TOP
*LOAD LogoTmp <newtop>
PRINT ~PAGE, ~(TOP+&400)
*SAVE LOGO <page> <topplus400>
pau1ie
Postby pau1ie » Sun Nov 12, 2017 11:36 pm
Thanks both. I will give this a go tomorrow.
billcarr2005
Postby billcarr2005 » Mon Nov 13, 2017 12:49 am
Or just use the native disk version? :)
FRUIT and CLASS are ready made trees
Tree of Knowledge.zip
Tree of Knowledge
(10.27 KiB) Downloaded 13 times
joachim
Postby joachim » Mon Nov 13, 2017 7:48 pm
crj wrote:What that does is copy a kilobyte (&400 bytes) from immediately above the program into screen memory.
Why did they do it that way? Surely they could have stored the Acornsoft logo just once (&100 bytes) then manually added the colours and the filing system dialogue window, thus making the loader 2–3 tape blocks shorter.
pau1ie
Postby pau1ie » Mon Nov 13, 2017 8:29 pm
billcarr2005 wrote:Or just use the native disk version? :)
Thanks - that is much easier!
Postby crj » Tue Nov 28, 2017 3:28 am
joachim wrote:Why did they do it that way?
Who can say?
I seem to recall they did do that on some games. They also sometimes just used PRINT statements instead of messing around with memory beyond the end of the program. Ironically, given the size of the copy routine, using PRINT instead may even have saved them memory. Not that memory is really that tight in the loading screen program in the first place...
Return to “software: other”
