Acornsoft Workshop inlay instructions?
pau1ie
Postby pau1ie » Sat Nov 11, 2017 11:06 pm
A UEF of this is in Flaxcottages educational archive, but without instructions. It seems impossible to play without instructions. Does anyone have the cassette inlay that they could scan/photograph/transcribe?
Hoglet may have had it at some stage?
hoglet wrote:E23 Workshop (BBC 198?, Electron 1984)
Re: Acornsoft Workshop inlay instructions?
Postby hoglet » Sun Nov 12, 2017 9:40 am
pau1ie wrote:Hoglet may have had it at some stage?
Sorry Paul, I just checked (and looked at the pictures in the thread above again), and I don't think I ever had this.
The list I quoted seems to be the full list from here.
billcarr2005
Postby billcarr2005 » Sun Nov 12, 2017 11:55 am
I'll try to get this sorted, when time permits, unless somebody posts it in the meantime...
Any specific settings i should be using when scanning?
It's a little A5-ish size booklet.
I've got the keystrip too!
And the disk image :)
Postby lurkio » Sun Nov 12, 2017 12:32 pm
billcarr2005 wrote:Any specific settings i should be using when scanning? It's a little A5-ish size booklet.
If you're scanning monochrome (black and white) text -- and if you DON'T want high-resolution archive-quality scans -- then use your scanner's "Text" setting (image bit-depth = 1). And 300 dpi. If there's too much "noise" in the scanned image, adjust the scanner's "Threshold" setting.
But if you're scanning in colour... you're on your own!
:idea:
pau1ie
Postby pau1ie » Sun Nov 12, 2017 8:47 pm
billcarr2005 wrote:I'll try to get this sorted, when time permits, unless somebody posts it in the meantime...
Wow, Thanks, that would be brilliant.
I don't know. 300dpi seems reasonable. I will probably create a PDF version.
billcarr2005 wrote:I've got the keystrip too!
Yes please, I will include that too...
billcarr2005 wrote:And the disk image :)
I think the disc image I have is assembled from a tape image, so that would be handy if you have time.
billcarr2005
Postby billcarr2005 » Sun Nov 26, 2017 7:01 pm
Enjoy! :)
WORKSHOP INSTRUCTIONS.zip
WORKSHOP function key strip & booklet
(1.35 MiB) Downloaded 10 times
WORKSHOP.zip
WORKSHOP Disk image
(16.25 KiB) Downloaded 6 times
pau1ie
Postby pau1ie » Mon Nov 27, 2017 12:03 am
billcarr2005 wrote:Enjoy
Thanks! That is excellent!
Return to “software: other”
Users browsing this forum: Yahoo [Bot] and 4 guests
