Odd Message; Tube On! with SD Card/MMFS/PiTubeDirect
sfdNut
Postby sfdNut » Thu Jul 20, 2017 4:54 pm
Hi All;
This was working before (i.e. yesterday) and today it doesn't.
BBC Micro Issue 7 board + SD Card (SirMorris) + MMFS + PiTubeDirect(Diamondback) on Pi Zero with Interface board from Kjell
Yesterday got the tube running and was able to run the BBC.MMB games disk without issue.
Today however when I type "*EXEC!BOOT!" I get:
*TV255
*MENU
Tube on!
and that's it!
Can ayone shed a light as to what is going on?
Removing the PiTube resolves the problem
Simon
Re: Odd Message; Tube On! with SD Card/MMFS/PiTubeDirect
Postby DutchAcorn » Thu Jul 20, 2017 5:05 pm
The menu software is incompatilble with a second processor so it checks if something is on the tube and exits with "Tube on!" if it detects a second processor.
sfdNut
Postby sfdNut » Thu Jul 20, 2017 7:07 pm
Fair enough, so you can't play Tube Elite with this menu system?
I need a tutorial on how to use SD cards on a BBC system ...
Postby sydney » Thu Jul 20, 2017 8:35 pm
sfdNut wrote:Fair enough, so you can't play Tube Elite with this menu system?
You can't use the menu system to play tube elite but it's on disc 45 (I think) so try the following:
*DIN 45
*TUBEELT
This will run the game. It would be a good idea to mount a blank disk image in drive 1 to store save games:
*DNEW 1
You should be informed which disk is being used - make a note of it for future reference and next time insert it using:
*DIN 1 disknumber
I'm not sure which version you are using but here is a link to the manual for the original MMBEEB ROM which most others seem to be based on:
MMBEEB manual
sfdNut
Postby sfdNut » Thu Jul 20, 2017 10:57 pm
*DIN 45
*TUBEELT
*DNEW 1
*DIN 1 disknumber
MMBEEB manual
Fantastic! Thanks Sydney :)
Return to “software: other”
