8271FDC & 3.5" drives, DFS1.20+hacks
Postby CMcDougall » Tue Jul 18, 2017 10:04 pm
maybe one for jgharston :?
One of my beebs does not like the original DFS1.20 with 31/2" drives,
so gave the ones a try from JGH site, being: http://mdfs.net/Apps/Filing/
now, the version DNFS302 (v1.21) was blown onto a 16k eprom, some games now work
but, when I save something, the drive makes the noise and steps up while saving,
then, after a hard break, either the disc is corrupt or the saved file is gone :(
it's not the drives, as tried 6 brand 'new' ones different makes, & 3x 8271FDCs
is this known? as when back on the other/s 1770FDC DFS2.26 they save fine & disc not corrupt.
going by the info for DNFS303 (v1.22), it just helps the NFS printers, so prob no change in the FS
I also found this version many moons ago, flip knows where from, so may try too......
dnfs120a_for_8271_bbc_with_3-5drive.zip
DFS1.20 hack ROM
(12.71 KiB) Downloaded 12 times
Re: 8271FDC & 3.5" drives, DFS1.20+hacks
Postby flaxcottage » Tue Jul 18, 2017 10:55 pm
The 8271 does not like 3.5" floppy drives. There are mods that can be done to drives and there is a modified DFS available. If you Google it the page comes up.
Best to use a 177x chip and DFS 2.26 with 3.5" drives.
Currently running L4 Econet with BBC B, BBC B+ 128K, Master 128K, 4Mb A3000, 4Mb A3020, 4Mb A4000, 4Mb A5000 dual FDD; UK101; HP41CX setup; Psion 3a, 3mx and 5mx; Z88; TI-58c, TI-59 and printer, HP-16C programmer's calculator and a bakery of Pis.
duikkie
Postby duikkie » Wed Jul 19, 2017 4:18 am
the 3.5 inch disks has not hole :) ti index that is the problem. the 8271 need a hole ! so to mod is to think that there is a pulse from index hole .
Postby lurkio » Wed Jul 19, 2017 9:00 am
I used Acorn DFS 1.20 in an 8271 Model B with 3.5" drive to test Raven Wood. The drive had been modded by Sprow, to try to restore missing index pulses, but I still kept getting the error "Drive fault 10 at 43/C1 at line 2540".
So I replaced DFS 1.20 with jgh's patched DFS 1.21 (DNFS 3.01), and the error went away.
BBCB+64K
Postby BBCB+64K » Wed Jul 19, 2017 1:17 pm
ISTR one of my BBC B's is fitted with a Watford DFS 1.44 and don't remember any issues saving to 3.5" DD disks. Give that a try.
Steve
My current setup...
BBC B+ 128k with external DataCentre with 2GB CF Card, 64MB ARM7TDMI Co-Processor and BeebOPL.
Postby CMcDougall » Thu Jul 20, 2017 8:03 pm
lurkio wrote:drive had been modded by Sprow, to try to restore missing index pulses, but I still kept getting the error "Drive fault
glad I did not waste £24! :D
regarding the 'keyboard' setting on bottom right, the keyboard with this beebB had it, so gave them a go....
so putting switch up to on for 3&4 ..... done nothing apart from different sounds from drive when loading/saving :?
BBCB+64K wrote:one of my BBC B's is fitted with a Watford DFS 1.44 and don't remember any issues saving to 3.5" DD disks
gave that a go cheers Steve, but is actually worse, even with switch 3&4 on/off off/on done no difference,
games do not load, give Drive Fault too :(
So, I would say, as John said, the hacks are utter useless, BUT, when loading ADFS1.30
the 8271FDC does not even look at the rom at all, so least it's not that daft! :lol: :mrgreen:
IF :-k :?: someone does another DFS1.20 hack (or 0.90) then the best test is this, as a bullet proof test:
put any file 3/4 of the way on the disc, in my case 'MENU'
LOAD"MENU"
*VER.0
beeb hangs here, so if anyone can get round this (on Drive0 80T) then it's a winner,
as DNFS301/2 (1.21/1.22) and my upload at start of thread is [-(
BBCB+64K
Postby BBCB+64K » Fri Jul 21, 2017 12:34 pm
Colin, are the drives PC 3.5" HD ones? When I tested my Beeb B with 3.5" disks, it was a Cumana DD drive. So maybe your particular machine doesn't like HD drives :-k
Steve
My current setup...
Postby CMcDougall » Fri Jul 21, 2017 6:35 pm
^they are yes, only maybe got a DD drive in my master compact PSU unit, but not taking that to bits to confirm these errs.
defo using the blue discs with one hole as always 8)
Return to “software: other”
