second attempt pictures of adfs ?
duikkie
Postby duikkie » Sat Jul 15, 2017 9:58 am
because i dont have adfs i want some pictures of the stucture of the directory
so if someone can give my
*cat (picture)
save a file name a :)
make a sub dir called map1
*cat (picture)
save a file in map1 called b
make a sub in map1 called map2
*cat (piture)
save a file in map2 called c
*cat (picture)
in dos you get
if you do cd
c:\map1\map2
if you do cd .
c:\map1\map2
if you do cd ..
c:\map1
if you do cd \
c:
i don't know how adfs is working ??
Re: second attempt pictures of adfs ?
Postby sydney » Sat Jul 15, 2017 10:33 am
The output will look different depending on which screen mode you are in. Not sure exactly what you wanted so Ive done the following:
1 A picture of a *. of an empty drive modes 3 & 7.
2 A picture of a *. of a root directory with a file named A in modes 3 & 7.
3 A picture of a *. of a root directory with a file named A and a directory named MAP1 in modes 3 & 7.
4 A picture of a *. of a directory called MAP1 with 1 file named B in modes 3 & 7.
5 A picture of a *. of a directory called MAP1 with 1 file named B and a sub directory called MAP2 in modes 3 & 7.
6 A picture of a *. of a directory called MAP2 with 1 file named C in modes 3 & 7.
A picture of a *. of an a root directory with 5 files and 5 directories in modes 3 & 7.
duikkie
Postby duikkie » Sat Jul 15, 2017 2:37 pm
oke you don't see that map2 is under map1 :(
in dos you see c:/map1/map2
allso why DLR ?? and not DIR ??
i am thinking about a dos sd card printing on beeb screen
but i have to think about the layout
allso troubles with showing path of directory
in dos
you have . and .. and \
in dos root a directory is like a file with clusternumber
like map1 00 00 05 00 =cluster 5
a dir of map1 gives
. 00 00 05 00
.. 00 00 00 00 (root)
map2 00 00 0A 00 = cluster 10
a dir of map2 gives
. 00 00 0A 00
.. 00 00 05 00
so printing the command cd on beeb if you are in map 2 is like c:\map1\map2
the things to do is holding cluster 10 , look at .. if 0 then root else print name before 00 00 05 00
but before printing you must find a .. with 00 00 00 00
i am thinking printing backwards map2\map1\$ then somehow printing that backwards so you get $\map1\map2
in the mean time not forgetting your file are at cluster 10 , for printing filenames in map2 #-o
duikkie
Postby duikkie » Sat Jul 15, 2017 2:42 pm
pushing it on stack but stack is only 256 bytes
so troubles with c:\map1\map\map3\ ..... map256 will give stack overflow
Postby sydney » Sat Jul 15, 2017 2:49 pm
I'm not really an expert on ADFS. Would the manual help at all?
ADFS User Guide
Page 33 describes the DLR as being attributes.
Postby jgharston » Sat Jul 15, 2017 4:22 pm
duikkie wrote:oke you don't see that map2 is under map1 :(
also why DLR ?? and not DIR ??
D 'cos it's a Directory
L 'cos it's Locked
R 'cos it's Readable
duikkie wrote:i am thinking about a dos sd card printing on beeb screen
Cataloguing a DOS disk on a BBC filing system will look as near to identical as makes no difference to cataloging a non-DOS disk on a BBC filing system, like this.
duikkie wrote:also troubles with showing path of directory
You normally don't show the path of the directory, just the leafname of the directory.
duikkie wrote:in dos you have . and .. and \
On the BBC you have @ (current directory) / (extension seperator) ^ (parent directory) and . (directory seperator).
:drive.$.directory.filename/ext
has a one-to-one mapping to and from
drive:\directory\filename.ext on DOSy systems
and
drive:/directory/filename.ext on Unixy systems
If just dealing with leafnames, and not full pathnames:
filename/ext on BBC systems maps directly to
filename.ext on non-BBC systems.
The simplest translation if just translating leafnames is to bidirectionally swap '.' and '/' which can be easily done with code such as:
REM B%=character
IF (B%AND&FE)=46 THEN B%=B%EOR1
(there are a few other characters you need to swap, but that covers 99% of cases. There's some badly-written articles on the Wiki covering pathname and filename translation link)
duikkie wrote:(snip)
Everything you can do in DOS from the command prompt you can do on the BBC from the command prompt, just swapping
DOS <-> BBC
DIR <-> CAT
CD <-> DIR
. (extension) <-> /
. (directory) <-> @
\ (root) <-> $
drive: <-> :drive
Are you actually asking for the filesystem structure?
Postby jgharston » Sat Jul 15, 2017 4:26 pm
duikkie wrote:i am thinking printing backwards map2\map1\$ then somehow printing that backwards so you get $\map1\map2 in the mean time not forgetting your file are at cluster 10 , for printing filenames in map2 #-o
pushing it on stack but stack is only 256 bytes so troubles with c:\map1\map\map3\ ..... map256 will give stack overflow
You do it with this standard code, and yes, you will get String too long with a pathname that is longer than 255 characters, because it's longer than 255 characters.
Return to “software: other”
