BCPL examples
Lardo Boffin
BCPL examples
Postby Lardo Boffin » Mon May 29, 2017 7:17 am
A while ago I decided to learn some BCPL but couldn't find many generic examples or specific Beeb examples beyond a couple in the Acornsoft book so while figuring it out I made a note of the ones I did and stuck them on GitHub. I say a while ago - it was about a year ago looking at the dates of the files...
Anyway if anyone is interested in learning BCPL they may be of interest:-
https://github.com/LardoBoffin
If you are going to give it a go I strongly recommend running it from a co-processor as otherwise you will constantly run out of RAM.
Lardo
bear
Re: BCPL examples
Postby bear » Tue May 30, 2017 6:17 pm
About a year ago I started a project to do a simple benchmark that pretty much any '80s home micro could participate in. This took the form of a BASIC program to calculate prime numbers by trial division. I decided I was interested in comparing the performance of BASIC to APL on my IBM 5100, wrote an APL version of the benchmark, and things went out of control from there.
I mention it because one of the most recent versions I produced was BCPL, for the purposes of benchmarking it on my Master 512.
http://typewritten.org/Articles/Benchma ... /bcpl.html
Sorted results:
http://typewritten.org/Articles/Benchmarks/primes.html
Lardo Boffin
Re: BCPL examples
Postby Lardo Boffin » Tue May 30, 2017 9:10 pm
Interesting tests thanks. So BCPL is approximately 3.5 times faster than BASIC IV. I'm surprised it is faster than Fourth - I thought that was supposed to be a really fast language?
Re: BCPL examples
Postby Coeus » Wed May 31, 2017 12:29 am
Interesting BCPL example. You reminded me that back in the 1980s our local radio station had a competition to write the fastest program to find all the primes up to a given number, which I now forget. The program I came up with was something like this:
GET "libhdr"
MANIFEST $( N=100
            //N=1000
            //N=10000
            V=541
LET start() BE
$( LET i, j, primes = ?, ?, ?
   primes := GETVEC (V)
   FOR j = 0 TO V $(
      primes!j := 0
   FOR i = 2 TO V $(
      IF primes!i = 0
      THEN $( writef("%n*n", i)
              j := i
              $( primes!j := 1
                 j := j+i
              $) REPEATUNTIL (j >= V)
except that is a new copy of the source hacked from your trial division version because I have no idea where I put the original. I later discovered that this is a well-known algorithm called the Sieve of Eratosthenes (https://en.wikipedia.org/wiki/Sieve_of_Eratosthenes)
Timnings, on B-Em: Trial Division 11.62s, sieve 4.94s
But for the final surprise, this implementation in BASIC 2:
   10V%=541
   20DIMP%(V%)
   30FORI%=2TOV%
   40IFP%(I%)=0THENPROCfound
   50NEXTI%
   60END
   70DEFPROCfound
   80PRINTI%
   90FORJ%=I%TOV%STEPI%
  100P%(J%)=1
  110NEXTJ%
  120ENDPROC
runs even faster at 4.1s It seems once the core algorithm is faster the execution time depends significantly on I/O. In the BCPL version if I replace the writef calls with writed so there are no newlines between the number and less scrolling I can get the BCPL version down to 3.8s
SteveF
Re: BCPL examples
Postby SteveF » Thu Jun 01, 2017 7:48 pm
Interesting that it's I/O bound it's an I/O test as well as a computation test...
Putting that to one side, are you comparing like with like here on the calculations? BBC BASIC will be using 32-bit integers, whereas I'd guess (i.e. I could be wrong!) the BBC version of BCPL will be using 16-bit words.
bear
Re: BCPL examples
Postby bear » Tue Oct 24, 2017 8:56 pm
SteveF wrote:Interesting that it's I/O bound it's an I/O test as well as a computation test...
Yeah, it's deliberately simplistic in this regard. A fast machine with slow console performance will get a slow result... mainly because the project started as a benchmark for '80s home micros, where a lot of the time the two couldn't really be separated. The limitations of the various built-in BASICs are also why the algorithm isn't particularly sophisticated (one area for obvious improvement is to stop checking factors at the square root of the candidate prime, but a number of BASICs don't have square root functions).
SteveF wrote:Putting that to one side, are you comparing like with like here on the calculations? BBC BASIC will be using 32-bit integers, whereas I'd guess (i.e. I could be wrong!) the BBC version of BCPL will be using 16-bit words.
I'm not, no. Whatever features and limitations of the language... that's all part of the ultimate result. The whys of the various results can get quite interesting. Maybe I'll start a column for people who want to guest-write analyses of the results. (@;
Re: BCPL examples
Postby crj » Wed Oct 25, 2017 1:40 am
If comparing BCPL with BASIC, it's worth tying to find primes up to a much larger number than 100.
Although the BCPL runtime is pretty lightweight, setting it up and tearing it down still isn't free. And, depending on precisely how you measure, much of BASIC's setup happens long before you type RUN.
Also, as noted, when the numbers are small, IO dominates. When the numbers are larger, ticking off the multiples takes the bulk of the time.
Incidentally, I believe the Level 2 and Level 3 fileservers are written in BCPL. For all I know they're the only non-toy uses ever made of the Beeb's BCPL compiler. (-8
Equally incidentally, Sieve of Eratosthenes was the first ARM program I ever wrote. Needless to say, it went obscenely quickly by 8-bit standards.
Re: BCPL examples
Postby danielj » Wed Oct 25, 2017 3:16 am
Domesday was written in BCPL on the beeb.
Return to “software: other”
