Easiest hackable Menu
pau1ie
Postby pau1ie » Fri Dec 29, 2017 12:50 am
I am working through John's educational archive and have got to a tape which accompanies a book (Basic Graphics and Sound - Addison Wesley) which has over 70 files on side 1. For ease of use with jsbeeb I decided to create an ADFS disc image, as I can create directories with files in, each file being a smallish basic program.
To make it easier to use it strikes me I should create a menu. To save me reinventing the wheel, what is the most easily hackable menu system?
Re: Easiest hackable Menu
Postby sweh » Sun Dec 31, 2017 9:33 pm
I put together a very very simple Menu program to work with MB's disks; the "build SSD" routines parsed his disks and generated the data file ("DSKDATA" and "GAMDATA") that the main MENU program used. The code is at https://github.com/sweharris/split_md_dsd
It's not pretty, but it has a simple search, and 'cos it's in BASIC you can modify it easily enough.
Postby jgharston » Mon Jan 01, 2018 7:40 am
There's some menu programs in Menus.ssd. EcoMenu is the simplest, an ECOnomical menu program that reads a simple text file in each directory describing what to display in that directory.
pau1ie
Postby pau1ie » Mon Jan 01, 2018 7:28 pm
Thanks both, I will have a look and see what I like best!
Postby lurkio » Mon Jan 01, 2018 8:30 pm
pau1ie wrote:Thanks both, I will have a look and see what I like best!
Here's a simple menu prog I used to use BITD:
    menu.ssd.zip
    DFS .SSD disc-image
    (1.2 KiB) Downloaded 7 times
You can tinker with the function params to change the colours, number of menu items, etc.
Return to “software: other”
