Help! Any ideas what is wrong with my RISC PC?
Any podule I use is never detected correctly. I've had two ScanLight podules, a ScanLight with Video 256 podule and a Morely 16-bit SCSI podule. All of them appear as seen in the screenshot via *Podules.
I've used both my 2 slot backplane and my 4 slot backplane. The 4 slot is brand new. I've tried every combination of podule and backplane. At worst I get an Internal Error and a lock up before !Boot, at best with the ScanLight in Podule 0 and SCSI in Podule 3 the OS loads, but nothing from the Podules. No SCSIFS or SCSICDFS under *Modules.
Could track damage that I can't see, and that affects nothing else be the cause of this? Garbled communication between podule card, backplane, backplane slot, MOBO to CPU and then to the OS?
Tried with 3.70 in ROM, 4.02 softloaded, 4.02 in ROM, 4.39 softload, 6.20 softload etc. With StrongARM CPU and ARM610, with the 486 card and without it, with the NIC and without it etc.
Unless I'm missing a setting somewhere along the line either every single full size podule I have are fscked or my RISC PC is fscked!
Many Delete power ons. The Morely SCSI utils just say "No SCSI card installed" exactly the same as the ScanLight software.
Are the podules supposed to report as "Expansion card 0: Extended type &0000"?
This is the error when it occurs on POST. Not every time and seems quite random. I've also had it lock RISC OS 4.02 up once and the power cycle pushed this error message out.
Also showing off my new AKF-53 monitor!
