Replacing A30x0 battery
JCUK
Postby JCUK » Tue Nov 21, 2017 1:44 pm
Hi folks,
A bit of advice - if I want to replace the CMOS battery on an A30x0/A4000, will a rechargeable AA battery be ok? Rather than a non rechargeable one with a diode.
Cheers!
Re: Replacing A30x0 battery
Postby danielj » Tue Nov 21, 2017 1:50 pm
Yes, use a NiMH, preferably with a low-self discharge rate such as an eneloop. Low capacity are often better in this regard (usually AAAs rather than AAs).
JCUK
Postby JCUK » Tue Nov 21, 2017 2:01 pm
Thanks danielj!
Postby danielj » Tue Nov 21, 2017 2:03 pm
You're welcome, and welcome to the forum!
Return to “hardware”
Users browsing this forum: Bing [Bot] and 1 guest
