A3000 lost Hard Disk, a noob's story
kppot
Postby kppot » Thu Nov 09, 2017 6:59 pm
Hello everyone,
I am new to this forum and I am totally noobish with Acorn computers. I recently aquired an A3000 model, last of BBC branded, as a tribute to BBC Micro, which was my first machine, back in 1988. Cant stand those red functional keys. Just joking. My A3000 has 2Mb of RAM extension and HCCS IDE interface. And brand new battery, of course!
So I presume it worked correctly. Also it has formatted CF card (but not installed) as bonus.
So first thing I decided to do was remove Econet module and check J25 jumper (it needed to be switched from monochrome video, as I do use SCART cable). Also before first power up I did reset CMOS with DEL key.
As a result, looks like I've lost my Hard Disk icon and the disk itself.
I've inspected A3000 motherboard to see if serial port chips are installed, then assembled everything back, but Econet podule. Now I hear HD is rotating (making its usual noise), but RISC OS does not shows HD icon. I started my quest to bring HD back
I posted this story on facebook group (link to full story proveded below) and I was told to perform such configuration
*configure idefsdiscs 1
*idefs
*dr. 4
With such I got my Icon back
but Risc OS gives me FileCore Error
and there is no catalogue
*. gives error in return
I attached a CF card (preformatted with APLD when they were still open, so I expected it should work automatically) and with card I have very same File Core error, no drive or catalogue, but I got new
Armstrong Walker IDFS
instead of old
Acorn ADFS
So I give up, help, help, help!
Note I have no mice yet so I cannot run !Configure system programm :(
Full story on Facebook is here
https://www.facebook.com/groups/2204586 ... 465916456/
ajw99uk
Re: A3000 lost Hard Disk, a noob's story
Postby ajw99uk » Thu Nov 09, 2017 7:33 pm
For the Watford Electronics interface there was a utility to initialise the drive and set CMOS. If the APDL CF was initialised for another IDE interface, you may need the equivalent for HCCS IDEFS.* I did briefly have a machine wirh one those interfaces but it's too long ago to recall details, sorry.
* http://chrisacorns.computinghistory.org ... idemgr.arc in case you've not already got it.
kppot
Postby kppot » Fri Nov 10, 2017 12:36 am
Right, thanks for the answer. So, basically, I did not broke anything? And I do not need re-format old HD disk or CF card?
And should I use *configure boot and *opt 4,2?
The reason I am asking is just I have no clue how to get any utility software from my PC (which has no floppy) to A3000
jms2
Postby jms2 » Fri Nov 10, 2017 6:52 am
Здравствуйте kppot,
I have got the same system as you (with same HCCS podule) so hopefully I can help you! I don't think you have broken anything.
So.. did the machine have a traditional hard disc when you got it? Did that work? If so, we should try to get that working first.
*Configure filesystem idefs
Is right, and should give the Armstrong Walker line when you boot. Can you do *status and tell me what the results are for everything (a screen shot will do). If you create a task window first by right clicking on the Acorn you can scroll the window to review the results easily.
Postby DutchAcorn » Fri Nov 10, 2017 7:01 am
HCCS IDE User Guide wrote:To advise the machine that an IDE hard drive is present the following commands should be entered in Supervisor Mode;
*Con. IDEFSDiscs 1 [RETURN]
*Con. IDEFSDrive 4 [RETURN]
*Con. IDEFSDelay 8 [RETURN]
*Con. IDEFSTimer 4 [RETURN]
*Con. IDEFSDircache 32 [RETURN]
[CTRL] + [BREAK]
jms2
Postby jms2 » Fri Nov 10, 2017 8:00 am
Nice one! That is what I was trying to remember.
This should make the hard disc work. However, whether the SD card works or not will depend on whether it was formatted correctly using the HCCS utility.
kppot
Postby kppot » Fri Nov 10, 2017 12:14 pm
Hey guys, thanks for helping me!
jms2 wrote: did the machine have a traditional hard disc when you got it? Did that work? If so, we should try to get that working first.
yes it has HD drive onboard in working condition.
So I detached CF and attached old HD back
Then i did
after shift+break i did
*Configure filesystem IDEFS
from supervisor prompt and shift+break
Still I have same error at the boot up
IDEFS expected more devises - it says and
Filecore error
And here what it says if you do *.
Here is *status screenshot (sorry I can't right click - have no mice yet)
Postby DutchAcorn » Fri Nov 10, 2017 1:02 pm
Try all the configuration commands from the userguide as quoted in my earlier post. Notably the IDEFSDelay is now set to 0 on your machine.
sirbod
Postby sirbod » Fri Nov 10, 2017 1:18 pm
You should configure HardDiscs to 0 if you're using IDEFS
jms2
Postby jms2 » Fri Nov 10, 2017 5:09 pm
Jon is right - Harddiscs is the number of ST506 drives in the machine, and so should be zero.
However there is another problem which is that the number of IDEFSdiscs is showing as zero after *status, but you set it to one earlier. does your machine have a new battery in it ?
Postby DutchAcorn » Fri Nov 10, 2017 5:32 pm
jms2 wrote:... However there is another problem which is that the number of IDEFSdiscs is showing as zero after *status, but you set it to one earlier. does your machine have a new battery in it ?
Or perhaps a <ctrl><break> instead of a <shift><break> after entering the config commands?
kppot
Postby kppot » Fri Nov 10, 2017 5:35 pm
Alright, we positively have some movement ahead!
I tried all commands and set Hard Discs to 0. You were absolutely right about Harddiscs. Now I have the number of IDEFSdiscs = 1
Now my
*status
looks this way
but still I do have that exclamation FileCore Error
How can I check contents of hard drive with no mice? May be this error not that critical?
kppot
Postby kppot » Fri Nov 10, 2017 5:47 pm
Ok, I did hard reset (powered off) and then poweren on the machine and came to interesting result. No error at boot up, and IDEFS 4 icon has turned to HardDisk icon
There were no BEEP sound as well. Have we won this round?
jms2
Postby jms2 » Fri Nov 10, 2017 6:21 pm
I’m worried about the battery. What does *status say now? If it has changed, your battery is dead. The battery is soldered to the pub, so if it is leaking it could destroy the machine.
Postby danielj » Fri Nov 10, 2017 6:41 pm
Should be OK, first post said it's a new one. What does a *cat say now it's stopped moaning about filecore errors?
kppot
Postby kppot » Fri Nov 10, 2017 6:50 pm
the battery
Yes, I think the battery is the root of such glitches (?)
Mine was replaced, so it looks like AA size rechargeable one, so please have no worries. I will leave the machine for half of the night to let the battery charge, meanwhile I will play with BBC Basic.
So i DO hope everything will be fine.
*status is still same at the moment
So many thanks for all who gave me a helpful hand! I will pop up again with next question about CF card right after I will get the mice :)
kppot
Postby kppot » Fri Nov 10, 2017 7:06 pm
danielj wrote:What does a *cat say now it's stopped moaning about filecore errors?
Looks like it gives me an actual HD catalogue!
So I hope it will last for quite some time now.
Bottomline - I blame battery, as I wasn't charged and CMOS was not w/r correctly
Postby DutchAcorn » Fri Nov 10, 2017 7:07 pm
kppot wrote:Ok, I did hard reset (powered off) and then poweren on the machine and came to interesting result. No error at boot up, and IDEFS 4 icon has turned to HardDisk icon
Looks promising. What do you see if you enter a *cat or *. command after pressing F12?
kppot
Postby kppot » Fri Nov 10, 2017 7:15 pm
DutchAcorn wrote:
kppot wrote: What do you see if you enter a *cat or *. command after pressing F12?
I believe I have an actual HD catalogue, I posted photo of my screen just above
Postby flaxcottage » Fri Nov 10, 2017 9:39 pm
Good work. =D>
Postby DutchAcorn » Fri Nov 10, 2017 9:53 pm
Yes, was cross-posted, glad you got it working!
kppot
Postby kppot » Fri Nov 10, 2017 10:12 pm
Once again thanks to everyone for your support! :D
jms2
Postby jms2 » Sat Nov 11, 2017 8:04 am
=D>
Return to “hardware”
Users browsing this forum: paulv, VincentVega and 4 guests
