A5000 IDE interface just died... what to try next?
Postby steve3000 » Mon Sep 25, 2017 10:30 pm
Well there I was minding my own business playing a quick game of Arc Elite on my A5000, popped back to the desktop to save my position and was greeted by a "Broken directory" error, followed by "Disc not understood, has it been formatted?" when I clicked on the hard disc icon. :shock:
Resetting the computer gave an unusually long-reboot time, typical of a failure to identify the HDD, and sure enough when the desktop appeared the hard disc icon just said "4" instead of the drive name. Clicking on the icon gave the same "Disc not understood, has it been formatted?" error. :(
The "hard disc" itself is actually a SD card fitted to a SD to IDE adaptor, so of course this was the first suspect, but upon testing in my A4000 the adaptor and card were fine - loading up perfectly.
Next I tried swapping the IDE data cable (it was fine), and then tested the continuity of all the 40 pins of the IDE plug on the A5000, but all were fine to their respective destination ICs...
I then popped the SD to IDE adaptor back in the A5000 and interrogated it using !HForm. This gave very interesting results, in particular see the "Description" field in the pic below:
When the same adaptor is plugged into the A4000, the "Description" reads correctly:
Any thoughts as to what could be wrong here and where to check next?
*Ignore the different number of cylinders in the two pics, I was experimenting with different SD cards to ensure the cards were not the problem.
Re: A5000 IDE interface just died... what to try next?
Postby DutchAcorn » Tue Sep 26, 2017 5:52 am
I've had issues with A5000 IDE data corruption that were caused by a faulty buffer chip: IC49. You could check out IC37 and IC49.
Postby RobC » Tue Sep 26, 2017 7:43 am
That looks like D4 is getting stuck high on every other byte (e.g. 'e' -> 'u' but 'm' -> 'm' in "Mem").
I'd look at the schematic and look for the buffering on the data lines from the IDE interface.
EDIT: It's a 16-bit interface so it'll be D4 or D12 causing the problem. Looking at the schematic, IC49 buffers D0-D6 (not a typo) and IC37 buffers D8-D15. If the IDE socket's connections to them are good, I'd look at scoping their inputs and outputs.
Postby steve3000 » Tue Sep 26, 2017 10:26 pm
Thanks for the replies!
DutchAcorn wrote:I've had issues with A5000 IDE data corruption that were caused by a faulty buffer chip: IC49. You could check out IC37 and IC49.
Ahh, yes, that could be it - I had also noticed a couple of seemingly random write errors occurring recently when using the SD to IDE adaptor, but again I suspected the adaptor since the errors seemed random and I couldn't get them to appear when using a real hard disc. (...although thinking about it, the lower write speed of a real HDD might have avoided a slightly slow/sticky bit on the buffer IC?)
RobC wrote:That looks like D4 is getting stuck high on every other byte (e.g. 'e' -> 'u' but 'm' -> 'm' in "Mem").
Bingo!
I had just been thinking this - after looking at the "0 0 0 0 "s at the end of the description - these should all be spaces (ascii 32) but the "0" every other letter is ascii 48, showing bit 4 is set (or bit 12 of 16bit, as you say).
I don't have a scope and can't think of a sensible way to test these using just a logic probe on the live system. So I've gone ahead and ordered a couple of replacement buffer ICs.
I'd guess IC37 is suspect, assuming the start of the description text is the low byte of the 16 bit data transfer... (unless it is reversed?). Looking at the schematic now, I see what you say about bit 7 - this goes via a different route...which is odd? But this leaves a spare gate on IC49. If I get a free few minutes tomorrow I might just patch the suspect bit 12 from IC37 over to this spare gate on IC49 and see if that solves things.
Postby jgharston » Thu Sep 28, 2017 3:24 am
Similar thing happened to my A5000 a few weeks ago, the battery had eaten through the tracks.
Postby steve3000 » Thu Sep 28, 2017 11:10 pm
steve3000 wrote:If I get a free few minutes tomorrow I might just patch the suspect bit 12 from IC37 over to this spare gate on IC49 and see if that solves things.
Patching bit12 from IC37 over to the spare gate on IC49 didn't solve the problem... :(
However, patching bit4 on IC49 to the spare gate did fix the problem! :D :D
So this means that for every 2 bytes in the description text, the first is transferred in the upper bits (8-15) and the second byte in the lower bits (0-7) of the 16-bit interface.
Postby DutchAcorn » Fri Sep 29, 2017 5:56 am
Nice fix! Looks like a belated battery leak damage. It is very possible that other gates will fail in the near future, but at least you'll know the most likely culprit then :D
Postby flaxcottage » Fri Sep 29, 2017 10:23 am
Nice job of soldering. :D =D>
Postby RobC » Fri Sep 29, 2017 10:43 am
Good job - glad you got this sorted and useful to know for future reference.
Postby steve3000 » Fri Sep 29, 2017 8:56 pm
Yes - most likely battery damage related, there was quite a lot of corrosion to clean up, but it's been running fine for a long time.
Two new buffer chips arrived this morning, so when I get a chance these will go in, but am very happy with the temporary fix for the moment.
Soldering is always 'fun' with these SMDs, especially lifting two of the pins from midway along the chip, but in this case the solder hadn't been badly degraded by the battery damage, so they pins lifted much more easily than I expected :)
Postby jgharston » Sat Oct 21, 2017 11:59 pm
Replacement battery arrived in the post a few days ago, so removed the dead battery, cleaned up the fuzz and leakage, and cleaned the board. I'm leaving it now to dry before going any further.
The symptom of the battery leaking was the IDE interface stopping working. Is there anywhere I should be targetting looking for damage? The bottom of the PCB is completely untouched, and looking I can't see anything other obvious on the top. This is the best photo I could manage, I really need a camera stand to eliminate hand wobble.
Postby jgharston » Sun Oct 22, 2017 10:32 pm
Well, I'm stumped. I cleaned up the PCB and looked for damage. I couldn't find anything, all the tracks looked undamaged, so today soldered the new battery in. Everything works fine battery-wise, but the it's still not noticing the IDE drive.
This is after R-PowerOn, *Configure IDEDiscs 1, Ctrl-Reset, with known working IDE drive with known contents:
Will there be anybody going to ABUG Leicester who knows what they're looking for who could have a prod at it?
Postby steve3000 » Sun Oct 22, 2017 11:14 pm
jgharston wrote:Well, I'm stumped. I cleaned up the PCB and looked for damage. I couldn't find anything, all the tracks looked undamaged, so today soldered the new battery in. Everything works fine battery-wise, but the it's still not noticing the IDE drive.
Question - does your computer detect a floppy drive, and can it read discs correctly?
If so, then your superIO controller is functioning and the fault is likely to be either a dead track (which you've ruled out) or a dead buffer IC - like mine above, which are relatively easy to replace :)
...but if you can't get floppy to work either, then the fault is possibly a dead controller and you can't get replacements of these :( (...even if you could, they are very fine pitch smd, so would need some serious expertise to replace)
Postby danielj » Mon Oct 23, 2017 7:03 am
You say looks fine, but have you checked continuity from each ide pin back to the controller? Sorry, sounds pedantic but just trying to get a handle...
philb
Postby philb » Mon Oct 23, 2017 7:39 pm
steve3000 wrote:...but if you can't get floppy to work either, then the fault is possibly a dead controller and you can't get replacements of these :( (...even if you could, they are very fine pitch smd, so would need some serious expertise to replace)
There seems to be a guy on ebay selling 82C711s at the moment. I don't remember what the difference was between the '710 and the '711 though or whether the two parts are footprint-compatible.
Postby steve3000 » Mon Oct 23, 2017 8:55 pm
philb wrote:There seems to be a guy on ebay selling 82C711s at the moment. I don't remember what the difference was between the '710 and the '711 though or whether the two parts are footprint-compatible.
Interesting find! If you mean item #172883263746, the IC in the picture definitely isn't pin compatible (wrong pitch and nowhere near enough pins), but it's probably just a generic picture of any of IC...
I think the '710 and '711 may be pin compatible, as I recall the A5000 used one and the A30x0s used the other...? But would definitely need to double check, if it comes to that.
Postby jgharston » Mon Oct 23, 2017 11:06 pm
It detects the floppy ok. By "the tracks looked undamaged" that's exactly what I mean. Close-up visual inspection did not show anything that to me appeared to be damaged tracks, but that doesn't mean I've eliminated damaged tracks as I don't really know what I'm looking for.
No, as I don't know what I'd be looking for.
Postby DutchAcorn » Tue Oct 24, 2017 5:31 am
You'd be looking for non-conducting (broken) tracks using a multimeter.
You may find this post useful as a guide: http://stardot.org.uk/forums/viewtopic.php?f=16&t=11059&p=137068#p137579
Postby danielj » Tue Oct 24, 2017 6:44 am
Attached is the relevant schematic.
The IDE connector's in the middle towards the bottom. I'd check each pin on the IDE connector is connected to its destination - particularly ICs 37, 49 & 26.
Acorn_A5000TRM_MainPCBCircuitDiagram2of4.pdf
(915.82 KiB) Downloaded 11 times
Postby jgharston » Wed Oct 25, 2017 12:15 am
danielj wrote:Attached is the relevant schematic.
Bingo! That's the sort of think I need. :D
Return to “hardware”
