RiscPC 600 display problem
Sanxion
Postby Sanxion » Wed Aug 16, 2017 3:43 pm
Hi all
This is my first post in the forum and hope you can help me...I recently bought a RiscPC 600 having never owned an Archimedes before, however I desperately wanted to experience ArcElite and Zarch...after waiting almost 30 years :D
So...I acquired a Viewsonic P220f CRT monitor for that authentic experience. However, upon connection and boot, I just see a few lines of very fuzzy text and what appears to be a command prompt.
These are the specs of the monitor:
https://www.cnet.com/products/viewsonic ... ies/specs/
Therefore, my question is: will this monitor work with my RiscPC?
Do I need to alter a setting?
Thank-you in advance.
dp11
Re: RiscPC 600 display problem
Postby dp11 » Wed Aug 16, 2017 3:47 pm
Try turning on the computer 1 or 2 or 3 on the numeric kaypad held down.
I suspect the CMOS needs resetting. Try turning on the computer with R held down.
Sanxion
Postby Sanxion » Wed Aug 16, 2017 3:53 pm
Thanks, I will try that.
Does it matter that I am using a standard USB PC keyboard connected via a PS/2 adaptor?
dp11
Postby dp11 » Wed Aug 16, 2017 3:54 pm
I don't think so.
Sanxion
Postby Sanxion » Wed Aug 16, 2017 5:38 pm
Thank-you! It worked by holding down the R key on startup!
Return to “hardware”
Users browsing this forum: Bing [Bot] and 2 guests
