ICS Wizzo IDEFS for A5000/A4 (+A3020/A4000...) improves CF card support!
Re: ICS Wizzo IDEFS for A5000/A4 (+A3020/A4000...) improves CF card support!
Postby steve3000 » Fri Oct 20, 2017 8:26 pm
sirbod wrote:The source has a 30 sec timeout for reads, so is it actually waiting 30 seconds before reporting the error?
Yes, at least 30 seconds. It felt like longer, but maybe I was impatient, or possibly it tries more than once...?
sirbod
Postby sirbod » Fri Oct 20, 2017 8:36 pm
steve3000 wrote:Yes, at least 30 seconds. It felt like longer, but maybe I was impatient, or possibly it tries more than once...?
See what it does if you remove the timeout, I've not tested this but hopefully you'll get just one hit:
DIM temp% 8
P%=temp%
[OPT 2
SUBS R0,R0,#1
STR R0,[R12,#504]
C%=!temp%
D%=temp%?6
E%=temp%?7
SYS "OS_Module",18,"ADFS" TO ,,,A%
S%=!(A%-4)
DIM adfs% S%
FOR L%=0 TO S% STEP 4
  Z%=A%!L%:X%=?(A%+L%+6):Y%?(A%+L%+7)
  IF Z%=C% AND X%=D% AND Y%=E% THEN
    adfs%!L%=&E1A00000
    PRINT "Read timeout removed ("+STR$~L%+")"
  ELSE
    adfs%!L%=Z%
  ENDIF
NEXT
OSCLI "SAVE $.ADFS "+STR$~adfs%+"+"+STR$~S%
*SetType $.ADFS Module
EDIT: There are four occurrences of Disc error 23, we need to figure out which one is being generated:
adfs13 #1
adfs13 #2
adfs14 #1
adfs14 #2
I suspect it might be adfs13 #1
EDIT 2: There's actually a bug in adfs13 #1 as the STR R5,WinTickCount should occur inside the loop which starts after the next line, labelled 10. As it stands, should the whole transfer take more than 10 seconds, it will generate Disc Error 23.
Return to “hardware”
Users browsing this forum: Bing [Bot] and 4 guests
