Problem with BBC Master
finnfoyle
Postby finnfoyle » Sun Feb 05, 2012 12:37 am
Hello all
I'm from Derry in Ireland.
I bought, on eBay, a BBC micro 128+. Delighted with it. So much so that when a BBC Master 128, in good condition and fully working, became available I bought it, at a reasonable price. One key was defective but it was easily fixed.
However, when I was getting to grips with it (playing around with it!) I attempted to set the Time on it with *TIME. I must have altered the default set up because I got error message"This is not a language" This was remedied by *CONFIGURE LANG 12"
But it is still not configured properly as it responds to commands with "NO DIRECTORY". I cannot format floppy disks on the BBC Master as I can on the 128+ Is it possible to get a backup from another Master and load it on my machine?
How can I restore the original settings? I have many books on the BBC micro but no reference to my problem.
I would be grateful for any help. I have screen pictures but not sure how to send them.
retroclinic
Re: Problem with BBC Master
Postby retroclinic » Sun Feb 05, 2012 2:46 am
Hi. Welcome to the forums.
Are you in DFS or ADFS? Try
*CONFIGURE FILE 9
reset, and try again.
Mark.
AndyF
Postby AndyF » Sun Feb 05, 2012 8:56 am
Welcome :)
finnfoyle
Postby finnfoyle » Sun Feb 05, 2012 10:34 am
thanks for your v. prompt reply.
Opening screen shows Acorn MOS, Acorn ADFS, BASIC. Tried *CONFIGURE FILE 9 No change.
Still getting "No directory" when I enter commands such as *FORM80 or *INFO 0
My other machine (BBC micro 128+) responds correctly to the above commands.
I already had your contact details in my address book. I think that I might have been an unsucessful bidder on your site. Took your contact details, as I thought that you would be a handy person to know re BBC micros. How right I was.
This is a well maintained Master new CMOS battery installed. My fault that it is not well!
When would be a convenient time to phone you?
Thanks in anticipation of your help.
Liam
Advance
Postby Advance » Sun Feb 05, 2012 11:17 am
Hi Liam
Welcome from an East Antrim member of the forums. Norn Iron folk are few and far between here but you will find there is an abundance of very clever, knowledgeable and helpful enthusiasts who form a very helpful community.
Hope you get your Master sorted. I've got three in various configurations so if I can help let me know - although my expertise is in the lower divisions.
Hugh
Postby paulv » Sun Feb 05, 2012 11:30 am
Hello :D
retroclinic
Postby retroclinic » Sun Feb 05, 2012 11:54 am
Hi.
Try
*DISC
then doing something, does that work? Try that configure file 9 command then do
*STATUS
See if file comes up as 9 afterwards, if not, then you've got a problem with the CMOS RAM, either the chip itself, the System VIA or one of the support ICs causing it not to store & retrieve data correctly.
Mark.
finnfoyle
Postby finnfoyle » Sun Feb 05, 2012 1:27 pm
Thanks. When I do *DISK I get "No directory"
When *STATUS I get as follows:
Configuration status:
Baud 8
No Boot
Caps
Data 3
Delay 247
No Directory
External Tube
FDrive 3
File 9
Hard
No Ignore
Lang 12
Mode 135
No Tube
Loud
Print 5
Repeat 252
Scroll
TV 255,1
retroclinic
Postby retroclinic » Sun Feb 05, 2012 2:08 pm
Could you do *ROMS see what that gives? It should be DFS in 09.
Mark.
finnfoyle
Postby finnfoyle » Sun Feb 05, 2012 2:34 pm
*Roms gives:
ROM F TERMINAL 01 unplugged
ROM E VIEW 04
ROM D Acorn ADFS 50
ROM C BASIC 04
ROM B Edit 01
ROM A ViewSheet 02
ROM 9 DFS 79 unplugged
ROM 8 ?
ROM 7 ? unplugged
ROM 6 ?
ROM 5 ?
ROM 4 ?
ROM 3 ?
ROM 2 ?
ROM 1 ?
ROM 0 ? unplugged
retroclinic
Postby retroclinic » Sun Feb 05, 2012 2:35 pm
Ahh....
*INSERT 9
You may benefit from a complete CMOS reset then reconfigure it from there, and have you changed the battery pack, or did the seller do it?
Mark.
finnfoyle
Postby finnfoyle » Sun Feb 05, 2012 3:01 pm
* INSERT 9 no change. Still getting "No directory" with *Disk
The seller made a point of saying that the battery had been renewed.
How do I do a CMOS reset?
We/You are getting there!
Liam
finnfoyle
Postby finnfoyle » Sun Feb 05, 2012 3:30 pm
found the instructions re CMOS reset and replace the internal battery battery.
Will tell you how I get on.
I am going to get a former BBC micro owner to help me to do this.
However I would welcome any additional advice re CMOS reset.
Many thanks again for your help.
retroclinic
Postby retroclinic » Sun Feb 05, 2012 3:36 pm
finnfoyle wrote:Mark
Liam
Hold down the "R" key while turning the machine on, should say CMOS RAM reset, then do a ctrl-break to reset it.
After that reset, it should come up in mode 0, saying Acorn ADFS, and either hang, or say this is not a language. If it hangs, press "F" and break to get a * prompt, then type
CONF.FILE 9
CONF.MODE 7
CONF.LANG 12
Then do a CTRL-BREAK, should come up in mode 7, in BASIC, with Acorn 1770 DFS - if it doesn't work after that, then I would assume there is a fault on the board.
Mark.
finnfoyle
Postby finnfoyle » Sun Feb 05, 2012 5:44 pm
many,many thanks for your help and especially your patience.
Did as I was told and now everything now back as it should be.
All commands responded to correctly. (touch wood)
Liam
videofx
Postby videofx » Mon Feb 06, 2012 1:59 am
Welcome to the forums!
Postby CMcDougall » Mon Feb 06, 2012 8:55 pm
welcome Liam :)
ya wee fecker :wink:
Postby jgharston » Mon Feb 27, 2012 12:01 am
http://mdfs.net/Docs/Comp/BBC/ReConfig
JGH PD Disk 18 at
http://mdfs.net/Mirror/Archive/JGH/ and
http://mdfs.net/Mirror/Image/JGH/
also have *SaveCMOS and *LoadCMOS command, giving the same functionality as the RISC OS commands.
unixbob
Postby unixbob » Sun Jun 25, 2017 9:55 pm
A 5 year old thread but really helped me out this afternoon.
Thanks if you guys are still around
Postby 1024MAK » Sun Jun 25, 2017 11:43 pm
At least three of them are still around :D
Users browsing this forum: Baidu [Spider] and 5 guests
